Page 11 of 11 FirstFirst ... 9 10 11
Results 251 to 264 of 264
Thread: Audio Recording / Logging to SD card --> microSoundRecorder
  1. #251
    Great thread - I will assemble a recorder for a last minute add-on (non critical path) for some field work in the Arctic Circle.
    Have any users experimented with additiional lowering of the Clock speed (below the currently configured 96MHz)? My MEMS mcis should arrive in a week, so I don't have the ability to experiment currently.
    This is a potentially good way to reduce power consumption when recording, assuming it doesn't compromise the recordings due to overflow or inability to write data at sufficiently high rates (I haven't dug into the firmware to see if things are DMA or not).
    Thank you
  2. #252
    3,368
    @frostylaughlin,
    listening for puffins?
    from the programming point of view, you can use also 24 or 48 MHz. The PLL is then always 96 MHz, so I'm not sure to reduce much the current.
  3. #253
    Oct 2019
    8
    Thanks so much for microSoundRecorder. Is it possible to use the Teensy Audio Shield and its SGTL5000 codec? I selected ACQ _I2S and tried it, but the recorded files are silent. (I understand that this combination is listed as "untested" on the wiki.) I know I need to instantiate the AudioControlSGTL5000 object, enable it, and set the inputs, but I'm not sure where to add it. I tried adding the following to MyApp.cpp starting at line 88:
    #if ACQ == _I2S
    #include "control_sgtl5000.h"
      AudioControlSGTL5000     audioShield;
      audioShield.enable();
      audioShield.volume(0.5);
      audioshield.inputSelect(AUDIO_INPUT_LINEIN);
    But it throws an error: "audioShield" does not name a type
  4. #254
    3,368
    @zlp
    there are two issues
    - typo: "audioshield.inputSelect(AUDIO_INPUT_LINEIN)" has "s" and not "S" (this results in error)
    - the calls to audioShield.xxxx must be within setup()
  5. #255
    Oct 2019
    8
    Thanks for pointing me in the right direction! I just achieved a stereo test recording with the Teensy 3.6 + Teensy Audio Shield Rev C. (using the uSD slot on the Teensy). In config.h I set ACQ to _I2S. In MyAPP.cpp I added:
    Around Line 80:
    #if ACQ == _I2S
    Around line 400:
    #if ACQ == _I2S
      audioShield.inputSelect(AUDIO_INPUT_LINEIN);
    In my application I'm using low noise electret capsules + preamp for better SNR than MEMS options (PUI AOM-5024), so I went with the Audio Shield. I hope to try the Teensy built-in ADCs as well for comparison since it would simplify the setup. Thanks so much for this project. I'm amazed and humbled.
  6. #256
    3,368
    @zlp
    yes, that sounds right
    Meanwhile I added a _I2S_SGTL5000 symbol to config.h and changed a little bit the main program to make use of, and changes for audio board a little bit easier
  7. #257
    Nov 2013
    19
    Continued from other thread.
    OK, so i had to go to another PC to download the .zip, as my XP PC would just sit there with an eternal loading icon when clicking on the green "code" button.
    Arduino: 1.8.5 (Windows XP), TD: 1.56, Board: "Teensy 3.6, Serial, 96 MHz, Faster, US English"
    C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Documents and Settings\Greg\Local Settings\Application Data\Arduino15\packages -hardware C:\Documents and Settings\Greg\My Documents\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Documents and Settings\Greg\Local Settings\Application Data\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Documents and Settings\Greg\My Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=96,opt=o2std,keys=en-us -ide-version=10805 -build-path C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_593391 -warnings=none -build-cache C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_cache_867262 -verbose C:\Documents and Settings\Greg\My Documents\Arduino\microSoundRecorder\microSoundRecorder.ino
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash\SerialFlashDirectory.cpp" -o "nul"
    Generating function prototypes...
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_593391\sketch\microSoundRecorder.ino.cpp" -o "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_593391\preproc\ctags_target_for_gcc_minus_e.cpp"
     Used: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SD
     Not used: C:\Program Files\Arduino\libraries\SD
    ctags pattern is missing
    Using library Audio at version 1.3 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio
    Using library SdFat at version 2.1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat
    Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI
    Using library Time at version 1.6.1 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Time
    Using library Wire at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire
    Using library SD at version 2.0.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SD
    Using library SerialFlash at version 0.5 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash
    Error compiling for board Teensy 3.6.
    I shortened the verbose message as it was pages and pages, but this is the result. I feel closer to having it working though.
    Another question, what would you think the detection threshold might be for triggering on gunshots at 100 to 150m?
  8. #258
    Jul 2020
    1,458
    Quote Originally Posted by gregs78cam View Post
    You've no actual errors in that snippet - please post the entire verbose compiler output.
  9. #259
    Nov 2013
    19
    OK, i found this thread
    https://forum.pjrc.com/threads/68579...ensyduino-1-55
    Used option 3, to delete SD Library, and now I get this far:
    C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Documents and Settings\Greg\Local Settings\Application Data\Arduino15\packages -hardware C:\Documents and Settings\Greg\My Documents\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Documents and Settings\Greg\Local Settings\Application Data\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Documents and Settings\Greg\My Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=96,opt=o2std,keys=en-us -ide-version=10805 -build-path C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_521695 -warnings=none -build-cache C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_cache_141250 -verbose C:\Documents and Settings\Greg\My Documents\Arduino\microSoundRecorder\microSoundRecorder.ino
    C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Documents and Settings\Greg\Local Settings\Application Data\Arduino15\packages -hardware C:\Documents and Settings\Greg\My Documents\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Documents and Settings\Greg\Local Settings\Application Data\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Documents and Settings\Greg\My Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=96,opt=o2std,keys=en-us -ide-version=10805 -build-path C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_521695 -warnings=none -build-cache C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_cache_141250 -verbose C:\Documents and Settings\Greg\My Documents\Arduino\microSoundRecorder\microSoundRecorder.ino
    Using board 'teensy36' from platform in folder: C:\Program Files\Arduino\hardware\teensy\avr
    Using core 'teensy3' from platform in folder: C:\Program Files\Arduino\hardware\teensy\avr
    WARNING: Category 'Utility' in library FlexIO_t4 is not valid. Setting to 'Uncategorized'
    Detecting libraries used...
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_521695\sketch\microSoundRecorder.ino.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_521695\sketch\myAPP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_521695\sketch\myAPP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_521695\sketch\myAPP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_521695\sketch\myAPP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_521695\sketch\myAPP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_521695\sketch\src\control_tlv320aic3206.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\Quantizer.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\Resampler.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_fft1024.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_fft256.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_notefreq.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_peak.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_print.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_rms.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_tonedetect.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\async_input_spdif3.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_ak4558.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_ak4558.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_cs42448.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_cs4272.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_sgtl5000.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_tlv320aic3206.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_wm8731.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\data_bandlimit_step.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\data_spdif.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\data_ulaw.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\data_waveforms.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\data_windows.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_bitcrusher.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_chorus.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_combine.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_delay.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_delay_ext.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_envelope.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_fade.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_flange.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_freeverb.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_granular.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_multiply.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_rectifier.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_reverb.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_wavefolder.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_waveshaper.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\filter_biquad.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\filter_fir.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\filter_ladder.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\filter_variable.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_adc.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_adcs.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_hex.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_oct.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_quad.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_pdm.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_pdm_i2s2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_spdif3.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_tdm.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_tdm2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\memcpy_audio.S" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\mixer.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_adat.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_dac.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_dacs.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_hex.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_oct.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_quad.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_mqs.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211_2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_pwm.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif3.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_tdm.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_tdm2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_memory.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_queue.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_sd_raw.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_sd_raw.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_sd_wav.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_serialflash_raw.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_serialflash_raw.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\record_queue.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\spi_interrupt.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_dc.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_karplusstrong.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_pinknoise.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_pwm.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_sine.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_tonesweep.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_waveform.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_wavetable.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_whitenoise.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility\imxrt_hw.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility\sqrt_integer.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatDbg.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFile.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFilePrint.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFileWrite.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFormatter.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatName.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatPartition.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatVolume.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatDbg.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFile.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFileLFN.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFilePrint.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFileSFN.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFormatter.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatName.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatPartition.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatVolume.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FreeStack.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FsLib\FsFile.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FsLib\FsNew.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FsLib\FsVolume.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\MinimumSerial.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SdCard\SdCardInfo.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SdCard\SdSpiCard.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SdCard\SdioTeensy.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiArtemis.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiChipSelect.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiDue.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiESP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiParticle.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiSTM32.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiSTM32Core.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiTeensy3.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FmtNumber.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsCache.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsDateTime.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsGetPartitionInfo.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsName.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsStructs.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsUtf.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\upcase.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\StdioStream.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\StreamBaseClass.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\istream.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\ostream.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI\SPI.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Time\DateStrings.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Time\Time.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\Wire.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\WireIMXRT.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\WireKinetis.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\utility\twi.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\libraries\SD\src\File.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\libraries\SD\src\SD.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\libraries\SD\src\utility\Sd2Card.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\libraries\SD\src\utility\SdFile.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\libraries\SD\src\utility\SdVolume.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash\SerialFlashChip.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash\SerialFlashDirectory.cpp" -o "nul"
    Generating function prototypes...
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_521695\sketch\microSoundRecorder.ino.cpp" -o "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_521695\preproc\ctags_target_for_gcc_minus_e.cpp"
    ctags pattern is missing
    Using library Audio at version 1.3 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio
    Using library SdFat at version 2.1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat
    Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI
    Using library Time at version 1.6.1 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Time
    Using library Wire at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire
    Using library SD at version 1.1.1 in folder: C:\Program Files\Arduino\libraries\SD
    Using library SerialFlash at version 0.5 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash
    Error compiling for board Teensy 3.6.
    I will continue to research.
  10. #260
    3,368
    after deleting the utility folder, you should force a complete recompile
    this can be done by, for example, changing the CPU speed.
  11. #261
    Nov 2013
    19
    OK, tried that...... this is what I get, orange text is the only thing in orange in the compile window.
    Arduino: 1.8.5 (Windows XP), TD: 1.56, Board: "Teensy 3.6, Serial, 96 MHz, Faster, US English"
    C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Documents and Settings\Greg\Local Settings\Application Data\Arduino15\packages -hardware C:\Documents and Settings\Greg\My Documents\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Documents and Settings\Greg\Local Settings\Application Data\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Documents and Settings\Greg\My Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=96,opt=o2std,keys=en-us -ide-version=10805 -build-path C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_153176 -warnings=none -build-cache C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_cache_303467 -verbose C:\Documents and Settings\Greg\My Documents\Arduino\microSoundRecorder\microSoundRecorder.ino
    C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Documents and Settings\Greg\Local Settings\Application Data\Arduino15\packages -hardware C:\Documents and Settings\Greg\My Documents\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Documents and Settings\Greg\Local Settings\Application Data\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Documents and Settings\Greg\My Documents\Arduino\libraries -fqbn=teensy:avr:teensy36:usb=serial,speed=96,opt=o2std,keys=en-us -ide-version=10805 -build-path C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_153176 -warnings=none -build-cache C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_cache_303467 -verbose C:\Documents and Settings\Greg\My Documents\Arduino\microSoundRecorder\microSoundRecorder.ino
    Using board 'teensy36' from platform in folder: C:\Program Files\Arduino\hardware\teensy\avr
    Using core 'teensy3' from platform in folder: C:\Program Files\Arduino\hardware\teensy\avr
    WARNING: Category 'Utility' in library FlexIO_t4 is not valid. Setting to 'Uncategorized'
    Build options changed, rebuilding all
    Detecting libraries used...
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_153176\sketch\microSoundRecorder.ino.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_153176\sketch\myAPP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_153176\sketch\myAPP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_153176\sketch\myAPP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_153176\sketch\myAPP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_153176\sketch\myAPP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_153176\sketch\src\control_tlv320aic3206.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\Quantizer.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\Resampler.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_fft1024.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_fft256.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_notefreq.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_peak.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_print.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_rms.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\analyze_tonedetect.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\async_input_spdif3.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_ak4558.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_ak4558.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_cs42448.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_cs4272.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_sgtl5000.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_tlv320aic3206.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\control_wm8731.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\data_bandlimit_step.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\data_spdif.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\data_ulaw.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\data_waveforms.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\data_windows.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_bitcrusher.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_chorus.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_combine.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_delay.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_delay_ext.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_envelope.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_fade.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_flange.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_freeverb.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_granular.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_multiply.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_rectifier.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_reverb.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_wavefolder.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\effect_waveshaper.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\filter_biquad.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\filter_fir.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\filter_ladder.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\filter_variable.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_adc.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_adcs.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_hex.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_oct.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_quad.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_pdm.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_pdm_i2s2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_spdif3.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_tdm.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\input_tdm2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\memcpy_audio.S" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\mixer.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_adat.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_dac.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_dacs.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_hex.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_oct.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_quad.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_mqs.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211_2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_pwm.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif3.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_tdm.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\output_tdm2.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_memory.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_queue.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_sd_raw.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_sd_raw.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_sd_wav.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_serialflash_raw.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\play_serialflash_raw.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\record_queue.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\spi_interrupt.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_dc.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_karplusstrong.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_pinknoise.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_pwm.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_sine.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_tonesweep.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_waveform.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_wavetable.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\synth_whitenoise.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility\imxrt_hw.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio\utility\sqrt_integer.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatDbg.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFile.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFilePrint.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFileWrite.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatFormatter.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatName.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatPartition.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatVolume.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatDbg.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFile.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFileLFN.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFilePrint.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFileSFN.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatFormatter.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatName.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatPartition.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FatLib\FatVolume.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FreeStack.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FsLib\FsFile.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FsLib\FsNew.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\FsLib\FsVolume.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\MinimumSerial.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SdCard\SdCardInfo.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SdCard\SdSpiCard.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SdCard\SdioTeensy.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiArtemis.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiChipSelect.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiDue.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiESP.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiParticle.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiSTM32.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiSTM32Core.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\SpiDriver\SdSpiTeensy3.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FmtNumber.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsCache.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsDateTime.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsGetPartitionInfo.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsName.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsStructs.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\FsUtf.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\common\upcase.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\StdioStream.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\StreamBaseClass.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\istream.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src\iostream\ostream.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI\SPI.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Time\DateStrings.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Time\Time.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\Wire.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\WireIMXRT.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\WireKinetis.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\utility" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire\utility\twi.c" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\libraries\SD\src\File.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\libraries\SD\src\SD.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\libraries\SD\src\utility\Sd2Card.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\libraries\SD\src\utility\SdFile.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\libraries\SD\src\utility\SdVolume.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash\SerialFlashChip.cpp" -o "nul"
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash\SerialFlashDirectory.cpp" -o "nul"
    Generating function prototypes...
    "C:\Program Files\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=156 -DARDUINO=10805 -DARDUINO_TEENSY36 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Time" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files\Arduino\libraries\SD\src" "-IC:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash" "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_153176\sketch\microSoundRecorder.ino.cpp" -o "C:\DOCUME~1\Greg\LOCALS~1\Temp\arduino_build_153176\preproc\ctags_target_for_gcc_minus_e.cpp"
    ctags pattern is missing
    Using library Audio at version 1.3 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio
    Using library SdFat at version 2.1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SdFat
    Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI
    Using library Time at version 1.6.1 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Time
    Using library Wire at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire
    Using library SD at version 1.1.1 in folder: C:\Program Files\Arduino\libraries\SD
    Using library SerialFlash at version 0.5 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash
    Error compiling for board Teensy 3.6.
  12. #262
    Nov 2013
    19
    Update: I decided to download Arduino on my wife's laptop (win10) along with the latest TD, zipped microSoundRecorder, and the GUI, and it compiles and uploads. Only issue I was running into was that I tried editing the config.h so that it would default to the event triggered settings by swapping the comment marks between these two lines, and it just would not upload with these default settings. So I closed everything, re-opened made sure the settings were commented correctly and uploaded, and magically it was right. I will test out the settings tomorrow. I set the threshold at 200, I will see if it records only records rifle shots.
    //ACQ_Parameters_s acqParameters = { 60, 10, 120, 0, 12, 12, 24, 0, "WMXZ"}; //<<<======>>>
    ACQ_Parameters_s acqParameters = { 300, 300, 3600, 0, 12, 12, 24, 0, "WMXZ"}; //<<<======>>
  13. #263
    3,368
    Quote Originally Posted by gregs78cam View Post
    When you change the default values in config.h, you must also delete the config.txt file on disk. the values in the file override the default values.
    IOW, no need to change Parameters in config.h, but in config.txt on disk
  14. #264
    Nov 2013
    19
    Ok. I think I figured that out after I saw the config file on the uSD when I went to see what it recorded during the setup.
    Thanks again Walter, I'll post back to let you know how it works for me.
