M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:24:10: error: 'SdVolume' has not been declared
uint32_t SdVolume::cacheBlockNumber_ = 0XFFFFFFFF;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:25:10: error: 'SdVolume' has not been declared
cache_t SdVolume::cacheBuffer_; // 512 byte cache for Sd2Card
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:26:1: error: 'Sd2Card' does not name a type
Sd2Card* SdVolume::sdCard_; // pointer to SD card object
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:27:10: error: 'SdVolume' has not been declared
uint8_t SdVolume::cacheDirty_ = 0; // cacheFlush() will write block if true
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:28:10: error: 'SdVolume' has not been declared
uint32_t SdVolume::cacheMirrorBlock_ = 0; // mirror block for second FAT
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:31:9: error: 'SdVolume' has not been declared
uint8_t SdVolume::allocContiguous(uint32_t count, uint32_t* curCluster) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:25:57: error: 'void (* SdFile::dateTime_)(uint16_t*, uint16_t*)' is not a static data member of 'class SdFile'
void (*SdFile::dateTime_)(uint16_t* date, uint16_t* time) = NULL;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:33:28: error: no 'uint8_t SdFile::addCluster()' member function declared in class 'SdFile'
uint8_t SdFile::addCluster() {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:46:35: error: no 'uint8_t SdFile::addDirCluster()' member function declared in class 'SdFile'
uint8_t SdFile::addDirCluster(void) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:61:1: error: 'dir_t' does not name a type
dir_t* SdFile::cacheDirEntry(uint8_t action) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp: In function 'uint8_t allocContiguous(uint32_t, uint32_t*)':
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:47:18: error: 'allocSearchStart_' was not declared in this scope
bgnCluster = allocSearchStart_;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:74:27: error: no 'uint8_t SdFile::close()' member function declared in class 'SdFile'
uint8_t SdFile::close(void) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:91:71: error: no 'uint8_t SdFile::contiguousRange(uint32_t*, uint32_t*)' member function declared in class 'SdFile'
uint8_t SdFile::contiguousRange(uint32_t* bgnBlock, uint32_t* endBlock) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:56:21: error: 'clusterCount_' was not declared in this scope
uint32_t fatEnd = clusterCount_ + 1;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:130:44: error: no 'uint8_t SdFile::createContiguous(SdFile*, const char*, uint32_t)' member function declared in class 'SdFile'
const char* fileName, uint32_t size) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:158:26: error: 'uint8_t SdFile::dirEntry' is not a static data member of 'class SdFile'
uint8_t SdFile::dirEntry(dir_t* dir) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:68:31: error: 'fatGet' was not declared in this scope
if (!fatGet(endCluster, &f)) return false;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:158:26: error: 'dir_t' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:158:33: error: 'dir' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:158:38: error: expected ',' or ';' before '{' token
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:178:28: error: 'dir_t' does not name a type
void SdFile::dirName(const dir_t& dir, char* name) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:178:50: error: no 'void SdFile::dirName(const int&, char*)' member function declared in class 'SdFile'
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:79:28: error: 'fatPutEOC' was not declared in this scope
if (!fatPutEOC(endCluster)) return false;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:201:46: error: no 'void SdFile::ls(uint8_t, uint8_t)' member function declared in class 'SdFile'
void SdFile::ls(uint8_t flags, uint8_t indent) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:245:58: error: no 'uint8_t SdFile::make83Name(const char*, uint8_t*)' member function declared in class 'SdFile'
uint8_t SdFile::make83Name(const char* str, uint8_t* name) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:83:43: error: 'fatPut' was not declared in this scope
if (!fatPut(endCluster - 1, endCluster)) return false;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:284:57: error: no 'uint8_t SdFile::makeDir(SdFile*, const char*)' member function declared in class 'SdFile'
uint8_t SdFile::makeDir(SdFile* dir, const char* dirName) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:88:40: error: 'fatPut' was not declared in this scope
if (!fatPut(*curCluster, bgnCluster)) return false;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:384:74: error: no 'uint8_t SdFile::open(SdFile*, const char*, uint8_t)' member function declared in class 'SdFile'
uint8_t SdFile::open(SdFile* dirFile, const char* fileName, uint8_t oflag) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:476:68: error: no 'uint8_t SdFile::open(SdFile*, uint16_t, uint8_t)' member function declared in class 'SdFile'
uint8_t SdFile::open(SdFile* dirFile, uint16_t index, uint8_t oflag) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:94:17: error: 'allocSearchStart_' was not declared in this scope
if (setStart) allocSearchStart_ = bgnCluster + 1;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:502:64: error: no 'uint8_t SdFile::openCachedEntry(uint8_t, uint8_t)' member function declared in class 'SdFile'
uint8_t SdFile::openCachedEntry(uint8_t dirIndex, uint8_t oflag) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:550:26: error: 'uint8_t SdFile::openRoot' is not a static data member of 'class SdFile'
uint8_t SdFile::openRoot(SdVolume* vol) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:550:26: error: 'SdVolume' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp: At global scope:
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:99:9: error: 'SdVolume' has not been declared
uint8_t SdVolume::cacheFlush(void) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:550:36: error: 'vol' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:550:41: error: expected ',' or ';' before '{' token
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp: In function 'uint8_t cacheFlush()':
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:101:10: error: 'sdCard_' was not declared in this scope
if (!sdCard_->writeBlock(cacheBlockNumber_, cacheBuffer_.data)) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:106:12: error: 'sdCard_' was not declared in this scope
if (!sdCard_->writeBlock(cacheMirrorBlock_, cacheBuffer_.data)) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:116:9: error: 'SdVolume' has not been declared
uint8_t SdVolume::cacheRawBlock(uint32_t blockNumber, uint8_t action) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp: In function 'uint8_t cacheRawBlock(uint32_t, uint8_t)':
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:119:10: error: 'sdCard_' was not declared in this scope
if (!sdCard_->readBlock(blockNumber, cacheBuffer_.data)) return false;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:127:9: error: 'SdVolume' has not been declared
uint8_t SdVolume::cacheZeroBlock(uint32_t blockNumber) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp: In function 'uint8_t cacheZeroBlock(uint32_t)':
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:135:17: error: 'cacheSetDirty' was not declared in this scope
cacheSetDirty();
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:140:9: error: 'SdVolume' has not been declared
uint8_t SdVolume::chainSize(uint32_t cluster, uint32_t* size) const {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:140:63: error: non-member function 'uint8_t chainSize(uint32_t, uint32_t*)' cannot have cv-qualifier
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp: In function 'uint8_t chainSize(uint32_t, uint32_t*)':
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:143:34: error: 'fatGet' was not declared in this scope
if (!fatGet(cluster, &cluster)) return false;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:144:19: error: 'clusterSizeShift_' was not declared in this scope
s += 512UL << clusterSizeShift_;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:145:26: error: 'isEOC' was not declared in this scope
} while (!isEOC(cluster));
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:151:9: error: 'SdVolume' has not been declared
uint8_t SdVolume::fatGet(uint32_t cluster, uint32_t* value) const {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:151:61: error: non-member function 'uint8_t fatGet(uint32_t, uint32_t*)' cannot have cv-qualifier
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp: In function 'uint8_t fatGet(uint32_t, uint32_t*)':
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:152:18: error: 'clusterCount_' was not declared in this scope
if (cluster > (clusterCount_ + 1)) return false;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:153:18: error: 'fatStartBlock_' was not declared in this scope
uint32_t lba = fatStartBlock_;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:154:10: error: 'fatType_' was not declared in this scope
lba += fatType_ == 16 ? cluster >> 8 : cluster >> 7;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:156:29: error: 'CACHE_FOR_READ' was not declared in this scope
if (!cacheRawBlock(lba, CACHE_FOR_READ)) return false;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:161:51: error: 'FAT32MASK' was not declared in this scope
*value = cacheBuffer_.fat32[cluster & 0X7F] & FAT32MASK;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:167:9: error: 'SdVolume' has not been declared
uint8_t SdVolume::fatPut(uint32_t cluster, uint32_t value) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp: In function 'uint8_t fatPut(uint32_t, uint32_t)':
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:172:18: error: 'clusterCount_' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:175:18: error: 'fatStartBlock_' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:176:10: error: 'fatType_' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:179:29: error: 'CACHE_FOR_READ' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:187:17: error: 'cacheSetDirty' was not declared in this scope
cacheSetDirty();
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:190:7: error: 'fatCount_' was not declared in this scope
if (fatCount_ > 1) cacheMirrorBlock_ = lba + blocksPerFat_;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:190:48: error: 'blocksPerFat_' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:195:9: error: 'SdVolume' has not been declared
uint8_t SdVolume::freeChain(uint32_t cluster) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp: In function 'uint8_t freeChain(uint32_t)':
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:197:3: error: 'allocSearchStart_' was not declared in this scope
allocSearchStart_ = 2;
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:207:26: error: 'isEOC' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:227:9: error: 'SdVolume' has not been declared
uint8_t SdVolume::init(Sd2Card* dev, uint8_t part) {
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:227:24: error: 'Sd2Card' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:227:33: error: 'dev' was not declared in this scope
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:227:46: error: expected primary-expression before 'part'
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:227:50: warning: expression list treated as compound expression in initializer [-fpermissive]
M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp:227:52: error: expected ',' or ';' before '{' token
Mehrere Bibliotheken wurden für "SD.h" gefunden
Benutzt: M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\hardware\teensy\avr\libraries\SD
Nicht benutzt: M:\Privat\AMATEURFUNK\Ardunio IDE T4\arduino-1.8.13 TD 1_53_HIER\libraries\SD
Fehler beim Kompilieren für das Board Teensy 3.6.
