/* Sound Recorder for Teensy 3.6
* Copyright (c) 2018, Walter Zimmer
* THE SOFTWARE.
/*********************** Begin possible User Modifications ********************************/
// possible modifications are marked with //<<<======>>>
#define DO_DEBUG 1 // print debug info over usb-serial line //<<<======>>>
#define F_SAMP 48000 // desired sampling frequency //<<<======>>>
* NOTE: changing frequency impacts the macros
* AudioProcessorUsage and AudioProcessorUsageMax
* defined in stock AudioStream.h
// ------------------------- Acquisition interface control ----------------------------
// possible ACQ interfaces
#define _ADC_0 0 // single ended ADC0
#define _ADC_D 1 // differential ADC0
#define _ADC_S 2 // stereo ADC0 and ADC1
#define _I2S 3 // I2S (16 bit stereo audio)
#define _I2S_32 4 // I2S (32 bit stereo audio), eg. two ICS43434 mics
#define _I2S_QUAD 5 // I2S (16 bit quad audio)
#define _I2S_32_MONO 6 // I2S (32 bit mono audio), eg. one ICS43434 mic
#define _I2S_TYMPAN 7 // I2S (16 bit tympan stereo audio audio) for use the tympan board
#define _I2S_TDM 8 // I2S (8 channel TDM) // only first 5 channels are used (modify myAcq.h if less or more channels)
#define ACQ _I2S_32_MONO // selected acquisition interface //<<<======>>>
// For ADC SE pins can be changed
#if ACQ == _ADC_0
#define ADC_PIN A2 // can be changed //<<<======>>>
#define DIFF 0
#elif ACQ == _ADC_D
#define ADC_PIN A10 //fixed analog pin
#define DIFF 1
#elif ACQ == _ADC_S
#define ADC_PIN1 A2 // can be changed //<<<======>>>
#define ADC_PIN2 A3 // can be changed //<<<======>>>
#define DIFF 0
#elif (ACQ == _I2S_32) || (ACQ == _I2S_32_MONO) || (ACQ == _I2S_TDM)
#define NSHIFT 12 // number of bits to shift data to the right before extracting 16 bits //<<<======>>>
#define MDEL -1 // maximal delay in buffer counts (128/fs each; for fs= 48 kHz: 128/48 = 2.5 ms each) //<<<======>>>
// MDEL == -1 connects ACQ interface directly to mux and queue
// MDEL >= 0 switches on event detector
// MDEL > 0 delays detector by MDEL buffers
#define MDET (MDEL>=0)
#define GEN_WAV_FILE // generate wave files, if undefined generate raw data (with 512 byte header) //<<<======>>>
// some structures to be used for controlling acquisition
// -----------------------scheduled acquisition------------------------------------------
typedef struct
{ uint32_t on; // acquisition on time in seconds
uint32_t ad; // acquisition file size in seconds
uint32_t ar; // acquisition rate, i.e. every ar seconds (if < on then continuous acquisition)
uint32_t T1,T2; // first acquisition window (from T1 to T2) in Hours of day
uint32_t T3,T4; // second acquisition window (from T1 to T2) in Hours of day
uint32_t rec; // time when recording started
char name[8]; // prefix for recorder file names
} ACQ_Parameters_s;
// T1 to T3 are increasing hours, T4 can be before or after midnight
// choose for continuous recording {0,12,12,24}
// if "ar" > "on" the do dutycycle, i.e.sleep between on and ar seconds
// Example
// ACQ_Parameters_s acqParameters = {120, 60, 180, 0, 12, 12, 24, 0, "WMXZ"};
// acquire 2 files each 60 s long (totaling 120 s)
// sleep for 60 s (to reach 180 s acquisition interval)
// acquire whole day (from midnight to noon and noot to midnight)
ACQ_Parameters_s acqParameters = { 60, 10, 120, 0, 12, 12, 24, 0, "WMXZ"}; //<<<======>>>
//---------------------------------- snippet extraction module ---------------------------------------------
typedef struct
{ int32_t iproc; // type of detection processor (0: high-pass-threshold; 1: Taeger-Kaiser-Operator)
int32_t thresh; // power SNR for snippet detection (-1: disable snippet extraction)
int32_t win0; // noise estimation window (in units of audio blocks)
int32_t win1; // detection watchdog window (in units of audio blocks typically 10x win0)
int32_t extr; // min extraction window
int32_t inhib; // guard window (inhibit follow-on secondary detections)
int32_t nrep; // noise only interval (nrep =0 indicates no noise archiving, TBD)
int32_t ndel; // pre trigger delay (in units of audio blocks)
} SNIP_Parameters_s;
// Note: 375 blocks is 1s for 48 kHz sampling
#if MDEL<0
// continuous acquisition; disable detector
#define THR -1
#else
#define THR 100 // detection threshold (on power: 100 == 20 dB) //<<<======>>>
SNIP_Parameters_s snipParameters = { 0, THR, 1000, 10000, 38, 375, 0, MDEL}; //<<<======>>>
//-------------------------- hibernate control---------------------------------------------------------------
// The following two lines control the maximal hibernate (sleep) duration
// this may be useful when using a powerbank, or other cases where frequent booting is desired
// is used in audio_hibernate.h
//#define SLEEP_SHORT // comment when sleep duration is not limited //<<<======>>>
#define ShortSleepDuration 60 // value in seconds //<<<======>>>
//------------------------- Additional sensors ---------------------------------------------------------------
#define USE_ENVIRONMENTAL_SENSORS 0 // to use environmental sensors set to 1 otherwise set to 0 //<<<======>>>
//------------------------- special Hardware configuration ----------------------------------------------------
#if ACQ == _I2S_TYMPAN
#undef USE_ENVIRONMENTAL_SENSORS
#define USE_ENVIRONMENTAL_SENSORS 0 // for tympan switch off environmental sensors
#define TYMPAN_REVISION TYMPAN_REV_C //TYMPAN_REV_C or TYMPAN_REV_D //<<<======>>>
#define TYMPAN_INPUT_DEVICE TYMPAN_INPUT_ON_BOARD_MIC // use the on-board microphones //<<<======>>>
//TYMPAN_INPUT_JACK_AS_MIC // use the microphone jack - defaults to mic bias 2.5V
//TYMPAN_INPUT_JACK_AS_LINEIN // use the microphone jack - defaults to mic bias OFF
#define input_gain_dB 10.5f //<<<======>>>
/*********************** End possible User Modifications ********************************/
