Testing if DAC pins are working
Projectitis
Hi all,
I may have fried my DAC pins on T_3.6 (but I'm unsure how). I just stopped getting audio while debugging a project.
I've tried a very simple sketch (below) to see if they are working, but I read no voltage between the pin and AGND (either pin).
Is my sketch correct? Do I need to initialise the DAC pins first? Or is there another way to test for fried DAC pins?
	analogWrite( 21, (uint32_t)(4095 * 1) );
	analogWrite( 22, (uint32_t)(4095 * 0.5) );
Sorry, basic mistake. The pins aren't 21 and 22, they are A21 and A22!
	analogWrite( A21, (uint32_t)(4095 * 1) );
	analogWrite( A22, (uint32_t)(4095 * 0.5) );
Running on a 3.6 here the code points to digital pin21/22 not A21/22
try
    analogWrite( A21, (uint32_t)(0) );
  analogWrite( A22, (uint32_t)(0) );
Edit - looks like you already found it -though I see the same upper value for A21 and A22 so looks like some integer math going on.
Thanks GremlinWrangler. Almost all of the DAC examples and threads I can find are specifically for the Audio shield, so finding relevant info is quite tricky!
