// duff from https://forum.pjrc.com/threads/25370-Teensy-3-0-Watchdog-Timer
// LPO @1khz 10% err, 4s WDOT timer
#define PRREG(x) Serial.print(#x" 0x"); Serial.println(x,HEX)
pinMode(LED_BUILTIN, OUTPUT);
// You have about 4 secs to open the serial monitor before a watchdog reset
while (!Serial);
printResetType();
KickDog();
PRREG(WDOG_STCTRLH);
PRREG(WDOG_PRESC);
PRREG(WDOG_TOVALL);
PRREG(WDOG_TOVALH);
PRREG(WDOG_RSTCNT);
for (int i = 1; i <= 5; i++) {
Serial.print("loop "); Serial.println(i);
KickDog();
Serial.println("long delay reset");
delay(5000);
Serial.println("never gets here ...");
delay(3000);
void KickDog() {
Serial.println("Kicking the dog!");
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
noInterrupts();
WDOG_REFRESH = 0xA602;
WDOG_REFRESH = 0xB480;
interrupts();
void printResetType() {
if (RCM_SRS1 & RCM_SRS1_SACKERR) Serial.println("[RCM_SRS1] - Stop Mode Acknowledge Error Reset");
if (RCM_SRS1 & RCM_SRS1_MDM_AP) Serial.println("[RCM_SRS1] - MDM-AP Reset");
if (RCM_SRS1 & RCM_SRS1_SW) Serial.println("[RCM_SRS1] - Software Reset");
if (RCM_SRS1 & RCM_SRS1_LOCKUP) Serial.println("[RCM_SRS1] - Core Lockup Event Reset");
if (RCM_SRS0 & RCM_SRS0_POR) Serial.println("[RCM_SRS0] - Power-on Reset");
if (RCM_SRS0 & RCM_SRS0_PIN) Serial.println("[RCM_SRS0] - External Pin Reset");
if (RCM_SRS0 & RCM_SRS0_WDOG) Serial.println("[RCM_SRS0] - Watchdog(COP) Reset");
if (RCM_SRS0 & RCM_SRS0_LOC) Serial.println("[RCM_SRS0] - Loss of External Clock Reset");
if (RCM_SRS0 & RCM_SRS0_LOL) Serial.println("[RCM_SRS0] - Loss of Lock in PLL Reset");
if (RCM_SRS0 & RCM_SRS0_LVD) Serial.println("[RCM_SRS0] - Low-voltage Detect Reset");
#ifdef __cplusplus
extern "C" {
void startup_early_hook();
extern "C" {
void startup_early_hook() {
#if 1
// clock source 0 LPO 1khz, 4 s timeout
WDOG_TOVALL = 4000; // The next 2 lines sets the time-out value. This is the value that the watchdog timer compare itself to.
WDOG_TOVALH = 0;
WDOG_STCTRLH = (WDOG_STCTRLH_ALLOWUPDATE | WDOG_STCTRLH_WDOGEN | WDOG_STCTRLH_WAITEN | WDOG_STCTRLH_STOPEN); // Enable WDG
#else
// bus clock 4s timeout
uint32_t ticks = 4000 * (F_BUS / 1000); // ms
WDOG_TOVALL = ticks & 0xffff; // The next 2 lines sets the time-out value. This is the value that the watchdog timer compare itself to.
WDOG_TOVALH = (ticks >> 16) & 0xffff;
WDOG_STCTRLH = (WDOG_STCTRLH_ALLOWUPDATE | WDOG_STCTRLH_CLKSRC | WDOG_STCTRLH_WDOGEN | WDOG_STCTRLH_WAITEN | WDOG_STCTRLH_STOPEN);
WDOG_PRESC = 0; // prescaler
#ifdef __cplusplus
