Watchdog timer and audio SGTL5000
Stanleyvc
The watchdog timer works well on my Teensy 3.6
But after a sound play, the watchdog reset somtimes.
what is heppents
I believe you can feed the watchdog every quarter of the total time, if your feeding it too fast you could also cause a WTG reset
interrupts must be disabled as well when feeding
This code feeds it
  __disable_irq();
  WDOG_REFRESH = 0xA602;
  WDOG_REFRESH = 0xB480;
  __enable_irq();
I have this function for reset the watchdog.
void reset_watchdog() {
noInterrupts();
interrupts();
This is the watchdog start function:
void start_watchdog() {
Serial.println("Start WatchDog!");
noInterrupts();
WDOG_UNLOCK = WDOG_UNLOCK_SEQ1;
WDOG_UNLOCK = WDOG_UNLOCK_SEQ2;
delayMicroseconds(1); // Need to wait a bit..
WDOG_STCTRLH = 0x0001; // Enable WDG
WDOG_TOVALH = 1;//0x166d;
WDOG_TOVALL = 30;
WDOG_PRESC = 30;//0x400;
WDOG_STCTRLH |= WDOG_STCTRLH_ALLOWUPDATE |
WDOG_STCTRLH_WDOGEN | WDOG_STCTRLH_WAITEN |
WDOG_STCTRLH_STOPEN | WDOG_STCTRLH_CLKSRC;
interrupts();
And this is the watchdog reset function:
unsigned long wdt_millis = 0;
if ((millis() - wdt_millis) > 1000) {
wdt_millis = millis();
noInterrupts();
interrupts();
I have a test routine, after 64633 millis, the Teensy 3.6 have a watchdog reset.
Somtimes after a sdplay, the sound file is 6 seconds, the Teensy have a watchdog reset.
Hmmm, I didn't test, but your WDOG config looks suspicious.
1) WDOG_PRESC needs to set the lower 3 bits of the upper byte of the register, so your 30 is meaningless, prescale is 0 (no prescale)
2) you have selected WDOG_STCTRLH_CLKSRC as clock source, e.g., F_BUS (60 mhz for T3.6)
3) your timeout value is 65566 ticks, so @60mhz that's about 1 ms ??
if you omit WDOG_STCTRLH_CLKSRC, WDOG will use LPO at 1khz (10% accuracy)
for your amusement, here is a sketch that will test the WDOG using either F_BUS or LPO
// duff from https://forum.pjrc.com/threads/25370-Teensy-3-0-Watchdog-Timer
//  LPO @1khz 10% err,  4s WDOT timer
#define PRREG(x) Serial.print(#x" 0x"); Serial.println(x,HEX)
  pinMode(LED_BUILTIN, OUTPUT);
  // You have about 4 secs to open the serial monitor before a watchdog reset
  while (!Serial);
  printResetType();
  KickDog();
  PRREG(WDOG_STCTRLH);
  PRREG(WDOG_PRESC);
  PRREG(WDOG_TOVALL);
  PRREG(WDOG_TOVALH);
  PRREG(WDOG_RSTCNT);
  for (int i = 1; i <= 5; i++) {
    Serial.print("loop "); Serial.println(i);
    KickDog();
  Serial.println("long delay reset");
  delay(5000);
  Serial.println("never gets here ...");
  delay(3000);
void KickDog() {
  Serial.println("Kicking the dog!");
  digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
  noInterrupts();
  interrupts();
void printResetType() {
  if (RCM_SRS1 & RCM_SRS1_SACKERR)   Serial.println("[RCM_SRS1] - Stop Mode Acknowledge Error Reset");
  if (RCM_SRS1 & RCM_SRS1_MDM_AP)    Serial.println("[RCM_SRS1] - MDM-AP Reset");
  if (RCM_SRS1 & RCM_SRS1_SW)        Serial.println("[RCM_SRS1] - Software Reset");
  if (RCM_SRS1 & RCM_SRS1_LOCKUP)    Serial.println("[RCM_SRS1] - Core Lockup Event Reset");
  if (RCM_SRS0 & RCM_SRS0_POR)       Serial.println("[RCM_SRS0] - Power-on Reset");
  if (RCM_SRS0 & RCM_SRS0_PIN)       Serial.println("[RCM_SRS0] - External Pin Reset");
  if (RCM_SRS0 & RCM_SRS0_WDOG)      Serial.println("[RCM_SRS0] - Watchdog(COP) Reset");
  if (RCM_SRS0 & RCM_SRS0_LOC)       Serial.println("[RCM_SRS0] - Loss of External Clock Reset");
  if (RCM_SRS0 & RCM_SRS0_LOL)       Serial.println("[RCM_SRS0] - Loss of Lock in PLL Reset");
  if (RCM_SRS0 & RCM_SRS0_LVD)       Serial.println("[RCM_SRS0] - Low-voltage Detect Reset");
#ifdef __cplusplus
extern "C" {
void startup_early_hook();
extern "C" {
  void startup_early_hook() {
#if 1
    // clock source 0 LPO 1khz, 4 s timeout
    WDOG_TOVALL = 4000; // The next 2 lines sets the time-out value. This is the value that the watchdog timer compare itself to.
    WDOG_TOVALH = 0;
    WDOG_STCTRLH = (WDOG_STCTRLH_ALLOWUPDATE | WDOG_STCTRLH_WDOGEN | WDOG_STCTRLH_WAITEN | WDOG_STCTRLH_STOPEN); // Enable WDG
#else
    // bus clock  4s timeout
    uint32_t ticks = 4000 * (F_BUS / 1000); // ms
    WDOG_TOVALL = ticks & 0xffff; // The next 2 lines sets the time-out value. This is the value that the watchdog timer compare itself to.
    WDOG_TOVALH = (ticks >> 16) & 0xffff;
    WDOG_STCTRLH = (WDOG_STCTRLH_ALLOWUPDATE | WDOG_STCTRLH_CLKSRC | WDOG_STCTRLH_WDOGEN | WDOG_STCTRLH_WAITEN | WDOG_STCTRLH_STOPEN);
    WDOG_PRESC = 0; // prescaler
#ifdef __cplusplus
and there is https://github.com/adafruit/Adafruit_SleepyDog
earlier thread https://forum.pjrc.com/threads/25370-Teensy-3-0-Watchdog-Timer
