Results 1 to 2 of 2
Thread: T3.5 w/ Lidar Lite V3 - Nothing but Nacks!
    Hey guys, I'm trying to get my Teensy 3.5 to work with a Lidar Lite V3, but I'm getting all nacks.
    Setup:
    - 4.7K external pullups to 5V
    - Using port I2C2 (pins 3 and 4)
    Schematic/Board Layout:
    #include <LIDARLite.h>
    LIDARLite myLidarLite;
      pinMode(13,OUTPUT);
      digitalWrite(13,HIGH);
      Wire.setSDA(4);
      Wire.setSCL(3);
      myLidarLite.begin(0, true); // Set configuration to default and I2C to 400 kHz
      myLidarLite.configure(0);
      // Take a measurement with receiver bias correction and print to serial terminal
      Serial.println(myLidarLite.distance());
      delay(10);
      // Take 99 measurements without receiver bias correction and print to serial terminal
      for(int i = 0; i < 99; i++)
        Serial.println(myLidarLite.distance(false));
        delay(10);
    Any thoughts?
    Nvm, I got it to work!
    I used the "extern TwoWire Wire2;" method found here: https://forum.arduino.cc/index.php?topic=216359.0.
    Unfortunately, I had to change the LiDAR Lite library with the above patch in order for it to work.
