Results 1 to 4 of 4
Thread: LFO/VCO with Map & Constrain
    May 2018
    11
    Hi all,
    I'm using 2 x waveforms going into a mixer & trying to map/constrain each so that one acts as an LFO and one acts as an audible range oscillator.
    Having a strange issue where knob2/4 are mapping/constraining correctly, but knob6/7 does not seem to read the potentiometer whatsoever and stays at the same rate, regardless of the pot value unless map/constrain is done after the following line:
    waveform3.frequency(360 * knob6 + 0.25);
    Meaning that the mapping/constraining of the values is done after the frequency is set. So obviously does nothing.
    In the commented code, you can see how I tried to do this initially.
    I could not figure out how to do that way, by mapping/constraining waveform1.frequency, etc.
    I do not have access to an oscilloscope until next week, but I was wondering what the maximum/minimum frequency of the waveform object is?
    My guess was 20Hz-20kHz, hence 1.023 = 20Hz & 1023.0 = 20kHz...
      // use the knobs to adjust parameters
      //float knob1 = (float)analogRead(A1) / 1023.0;
      float knob2 = (float)analogRead(A2) / 1023.0;
      knob2 = map(knob2, 0.0, 1023.0, 0.0, 1.023);
      knob2 = constrain(knob2, 0.0, 1.023);
      waveform1.frequency(360 * knob2 + 0.25);
      float knob3 = (float)analogRead(A3) / 1023.0;
      sine_fm1.frequency(knob3 * 1500 + 50);
      float knob6 = (float)analogRead(A18) / 1023.0;
      knob6 = map(knob6, 0.0, 1023.0, 1.023, 1023.0);
      knob6 = constrain(knob6, 1.023, 1023.0);
      //map(waveform1.frequency, 0.0, 20000.0, 0.0, 20.0);
      //constrain(waveform1.frequency, 0.0, 20.0);
      //map(waveform3.frequency, 0.0, 20000.0, 20.0, 20000.0);
      //constrain(waveform3.frequency, 20.0, 20000.0);
      float knob4 = (float)analogRead(A6) / 1023.0;
      knob4 = map(knob4, 0.0, 1023.0, 0.0, 1.023);
      knob4 = constrain(knob4, 0.0, 1.023);
      waveform2.frequency(360 * knob4 + 0.25);
      float knob5 = (float)analogRead(A7) / 1023.0;
      sine_fm2.frequency(knob5 * 1500 + 50);
      float knob7 = (float)analogRead(A20) / 1023.0;
      waveform4.frequency(360 * knob7 + 0.25);
      knob7 = map(knob7, 0.0, 1023.0, 1.023, 1023.0);
      knob7 = constrain(knob7, 1.023, 1023.0);
    Any clarification on this would be much appreciated.
    May 2018
    11
    Apologies for not posting the complete code:
    #include <Bounce.h>
    Bounce button0 = Bounce(0, 15);
    Bounce button1 = Bounce(1, 15);  // 15 = 15 ms debounce time
    Bounce button2 = Bounce(2, 15);
    Bounce button3 = Bounce(3, 15);
    Bounce button4 = Bounce(4, 15);  // 15 = 15 ms debounce time
    Bounce button5 = Bounce(5, 15);
    Bounce button6 = Bounce(24, 15);
    Bounce button7 = Bounce(25, 15);
    // copy the Design Tool code here
    #include <SerialFlash.h>
    AudioSynthWaveform       waveform1;      //xy=140,129
    AudioSynthWaveform       waveform2;      //xy=170,392
    AudioSynthWaveformSineModulated sine_fm2;       //xy=214,452
    AudioSynthWaveformSineModulated sine_fm1;       //xy=219,187
    AudioSynthWaveform       waveform3;      //xy=226,234
    AudioSynthWaveform       waveform4;      //xy=235,498
    AudioSynthKarplusStrong  string1;        //xy=242,535
    AudioSynthSimpleDrum     drum1;          //xy=251,280
    AudioEffectEnvelope      envelope1;      //xy=414,294
    AudioMixer4              mixer1;         //xy=425,183
    AudioEffectEnvelope      envelope2;      //xy=437,542
    AudioMixer4              mixer3;         //xy=444,464
    AudioMixer4              mixer2;         //xy=561,264
    AudioMixer4              mixer4;         //xy=564,524
    AudioOutputI2S           i2s1;           //xy=702,335
    AudioConnection          patchCord1(waveform1, sine_fm1);
    AudioConnection          patchCord2(waveform1, 0, mixer1, 0);
    AudioConnection          patchCord3(waveform2, sine_fm2);
    AudioConnection          patchCord4(waveform2, 0, mixer3, 0);
    AudioConnection          patchCord5(sine_fm2, 0, mixer3, 2);
    AudioConnection          patchCord6(sine_fm1, 0, mixer1, 2);
    AudioConnection          patchCord7(waveform3, 0, mixer1, 1);
    AudioConnection          patchCord8(waveform4, 0, mixer3, 1);
    AudioConnection          patchCord9(string1, 0, mixer3, 3);
    AudioConnection          patchCord10(drum1, 0, mixer1, 3);
    AudioConnection          patchCord11(envelope1, 0, mixer2, 1);
    AudioConnection          patchCord12(mixer1, 0, mixer2, 0);
    AudioConnection          patchCord13(mixer1, envelope1);
    AudioConnection          patchCord14(envelope2, 0, mixer4, 1);
    AudioConnection          patchCord15(mixer3, 0, mixer4, 0);
    AudioConnection          patchCord16(mixer3, envelope2);
    AudioConnection          patchCord17(mixer2, 0, i2s1, 0);
    AudioConnection          patchCord18(mixer4, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=424,110
      AudioMemory(20);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.32);
      pinMode(0, INPUT_PULLUP);
      pinMode(1, INPUT_PULLUP);
      pinMode(2, INPUT_PULLUP);
      pinMode(3, INPUT_PULLUP);
      pinMode(4, INPUT_PULLUP);
      pinMode(5, INPUT_PULLUP);
      mixer1.gain(0, 0.75);
      mixer1.gain(1, 0.0);
      mixer1.gain(2, 0.0);
      mixer1.gain(3, 0.0);
      mixer2.gain(0, 0.15);
      mixer2.gain(1, 0.0);
      mixer2.gain(2, 0.0);
      mixer2.gain(3, 0.0);
      mixer3.gain(0, 0.75);
      mixer3.gain(1, 0.0);
      mixer3.gain(2, 0.0);
      mixer3.gain(3, 0.0);
      mixer4.gain(0, 0.15);
      mixer4.gain(1, 0.0);
      mixer4.gain(2, 0.0);
      mixer4.gain(3, 0.0);
      waveform1.begin(WAVEFORM_SAWTOOTH);
      waveform1.amplitude(0.75);
      waveform1.frequency(50);
      waveform1.pulseWidth(0.15);
      sine_fm1.frequency(440);
      sine_fm1.amplitude(0.75);
      waveform3.begin(WAVEFORM_SAWTOOTH);
      waveform3.frequency(200);
      waveform3.amplitude(0.75);
      waveform3.pulseWidth(0.15);
      //pink1.amplitude(0.75); //
      envelope1.attack(10);
      envelope1.hold(10);
      envelope1.decay(25);
      envelope1.sustain(0.4);
      envelope1.release(70);
      waveform2.begin(WAVEFORM_SAWTOOTH);
      waveform2.amplitude(0.75);
      waveform2.frequency(50);
      waveform2.pulseWidth(0.15);
      sine_fm2.frequency(440);
      sine_fm2.amplitude(0.75);
      waveform4.begin(WAVEFORM_SAWTOOTH);
      waveform4.frequency(200);
      waveform4.amplitude(0.75);
      waveform4.pulseWidth(0.15);
      //pink2.amplitude(0.75); //
      envelope2.attack(10);
      envelope2.hold(10);
      envelope2.decay(25);
      envelope2.sustain(0.4);
      envelope2.release(70);
    int waveform_type = WAVEFORM_SAWTOOTH;
    int mixer1_setting = 0;
    int mixer2_setting = 0;
    int mixer3_setting = 0;
    int mixer4_setting = 0;
    elapsedMillis timeout = 0;
    bool mixer2_envelope = false;
    bool mixer4_envelope = false;
      button0.update();
      button1.update();
      button2.update();
      button3.update();
      button4.update();
      button5.update();
      //button6.update();
      //button7.update();
      // Left changes the type of control waveform
      if (button0.fallingEdge()) {
        Serial.print("Control waveform 1: ");
        if (waveform_type == WAVEFORM_SAWTOOTH) {
          waveform_type = WAVEFORM_SINE;
          Serial.println("Sine");
        } else if (waveform_type == WAVEFORM_SINE) {
          waveform_type = WAVEFORM_SQUARE;
          Serial.println("Square");
        } else if (waveform_type == WAVEFORM_SQUARE) {
          waveform_type = WAVEFORM_TRIANGLE;
          Serial.println("Triangle");
        } else if (waveform_type == WAVEFORM_TRIANGLE) {
          waveform_type = WAVEFORM_PULSE;
          Serial.println("Pulse");
        } else if (waveform_type == WAVEFORM_PULSE) {
          Serial.println("Sawtooth");
        waveform1.begin(waveform_type);
        waveform3.begin(waveform_type);
        if (button3.fallingEdge()) {
        Serial.print("Control waveform 2: ");
        waveform2.begin(waveform_type);
        waveform4.begin(waveform_type);
      // middle button switch which source we hear from mixer1
      if (button1.fallingEdge()) {
        if (mixer1_setting == 0) {
          Serial.println("Mixer1: LFO");
          mixer1_setting = 1;
        } else if (mixer1_setting == 1) {
          mixer1.gain(0, 0.0);
          mixer1.gain(1, 0.75);
          Serial.println("Mixer1: VCO");
          mixer1_setting = 2;
        } else if (mixer1_setting == 2) {
          mixer1.gain(2, 0.75);
          Serial.println("Mixer1: FM");
          mixer1_setting = 3;
        } else if (mixer1_setting == 3) {
          mixer1.gain(3, 0.75);
          Serial.println("Mixer1: DRUM");
          mixer1_setting = 0;
      if (button4.fallingEdge()) {
        if (mixer3_setting == 0) {
          Serial.println("Mixer3: LFO");
          mixer3_setting = 1;
        } else if (mixer3_setting == 1) {
          mixer3.gain(0, 0.0);
          mixer3.gain(1, 0.75);
          Serial.println("Mixer3: VCO");
          mixer3_setting = 2;
        } else if (mixer3_setting == 2) {
          mixer3.gain(2, 0.75);
          Serial.println("Mixer3: FM");
          mixer3_setting = 3;
        } else if (mixer3_setting == 3) {
          mixer3.gain(3, 0.75);
          Serial.println("Mixer3: STRING");
          mixer3_setting = 0;
      // Right button activates the envelope
      if (button2.fallingEdge()) {
        mixer2.gain(0, 0.0);
        mixer2.gain(1, 1.0);
        mixer2_envelope = true;
        timeout = 0;
        envelope1.noteOn();
      if (button2.risingEdge()) {
        envelope1.noteOff();
        timeout = 0;
      if (button5.fallingEdge()) {
        mixer4.gain(0, 0.0);
        mixer4.gain(1, 1.0);
        mixer4_envelope = true;
        timeout = 0;
        envelope2.noteOn();
      if (button5.risingEdge()) {
        envelope2.noteOff();
        timeout = 0;
      // after 4 seconds of inactivity, go back to
      // steady listening instead of the envelope
      if (mixer2_envelope == true && timeout > 4000) {
        if (mixer4_envelope == true && timeout > 4000) {
        if (button6.fallingEdge) {
        Serial.println("VCO");
        constrain(waveform1.frequency, 20.0, 20000.0)
        else if ({
    My aim is for this to be made for Eurorack, hence the left and right channels acting as separate mono channels.
    May 2018
    11
    Anyone have any clue about this, it seems like a really strange problem.
    May 2018
    11
    Quote Originally Posted by Lightbluehue View Post
    Sorry, meant to say 0Hz-20kHz here. 20Hz for the audible rate oscillator.
    Also I am using the beta, does the above issue relate to that possibly?
Tags for this Thread
