Wifi library on SPI2
Armadafg
eng:
Hello, I would like to know if adapting the wifi library to use the bus SPI2 would be complicated to do
fra:
Bonjour, j'aimerai savoire si adapter la library wifi pour utliser le bus SPI2 serait compliqué a faire
not sure which library your referring to
if its hardcoded you could do a search and replace for all "SPI." to "SPI2." in the library and it should be okay
eng:
Thank you for your answer. It's great if it's so easy. If a person who already had the experience could share it will be super cool
Fra:
Merci pour ta réponse. Ca super si c'est aussi facile. Si une personne ayen deja fat l'experience pouvais la partager ca serai super cool
eng:
fra:
Do you mean Ethernet library instead of WiFi library? I'm not aware of a WiFi library for Teensy models since none of the Teensies have WiFi hardware.
eng:
effectively. I have not decided yet on the chip to use, there is ESP8266 or winc1500. I do not know if the price gap is justifying. In both cases I want to use them in SPI
fra:
effectivement. Je ne me suis pas encore décidé sur la puse a utlisiser, il y a ESP8266 ou le winc1500. Je ne sais pas si l'ecart de prix est justifier. Dans les deux cas je veux les utiliser en SPI
