DSP block - Optimize FIR filters?
Hello guys,
I'm using this code, for the teensy 3.6, to do system identification in the audio range based on adaptive filtering.
Is working really well but I would really like to know if there is a way of optimizing the code so I can use bigger filters with the same sampling rate. I've been working with signal processing for a while but I'm fairly new to embedded systems.
I read that the ARM cortex M4 has some built-in optimized DSP functions. How can I use them to make the code run faster? How can I make the Fir filtering with those functions?
I'm accepting any advices and tips.
Obs: Im not using the audio shield
Created in : 15/06/2017 11:26:03
Author: Artur Zorzo
/* System Identification with LMS and white noise //
// Teensy 3.6 */
#include <arduino.h>
// Declaration
long int a = 0; // Stop criterion
const int taps = 50; // Fir filter size
float w[taps]; // Fir filter vector
unsigned int x[taps]; // Signal Vector
signed int e; // Error variable
unsigned int r; // Random number
unsigned int y = 0; // Filter output
unsigned int d; // Input
float g; // Sum
//CONFIGURATIONS
analogReadResolution(12); // AD Resolution
analogWriteResolution(12); // DAC Resolution
Serial.begin(19200); // Serial communication
analogWrite(A22, 2048);
delayMicroseconds(30);
}// Setup end
//Loop
r = random(4095); // White noise generation
x[0] = r;
analogWrite(A22, r);
y = 0; // y initialization
for (int i = 0; i <= (taps - 1); i++) // Convolution
y = y + w * x;
d = analogRead(A0);
e = d - y; // Error calculation
for (int i = 0; i <= (taps - 1); i++) // Filter refresh
g = (((float)x * e) / (400000000.00));
w = w + g;
for (int i = (taps - 1); i >= 1; i--) // Signal vector refresh
x = x[i - 1];
// Show filter coeficients
if (a == 50000)
Serial.print(w);
Serial.print("\t");
while (1)
a = a + 1;
} // End Loop
Even without the audio shield, you should use the audio library (using the ADC and DAC objects as input and output). This gives you great access to a large selection of DSP optimized audio generation, modification and analysis objects with a few mouse clicks.
Hi Theremingenieur,
I tried to use them, but afterwards I couldn't find a way of acessing the individual samples and adjusting the sampling rate :/. I need to do this processing at each sample read by the ADC, no buffers involved.
ok... If you need to go with a variable sampling rate, these audio objects might not be the best solution. But studying their source code should tell you how to use the Cortex-M4 DSP extensions, though.
The optimized FIR filter stuff is in arm_math.h.
These are the files from the audio lib which use it. Maybe they can help you?
https://github.com/PaulStoffregen/Audio/blob/master/filter_fir.h
https://github.com/PaulStoffregen/Audio/blob/master/filter_fir.cpp
The basic idea is you create an "arm_fir_instance_q15" and an array of "q15". Before doing any filtering, you call arm_fir_init_q15(). Then to actually compute the filter output, call arm_fir_fast_q15().
The speed optimization comes from operating on blocks. If you process just 1 sample at a time, you'll never reap the benefit of the Cortex-M4 DSP extensions.
Likewise, by using analogRead() and consuming CPU time to handle each sample, you're never going to get anywhere close to the kind of performance the audio library achieves using efficient DMA to get the data in and out of the chip.
If you absolultely must have "no buffers involved", the cost will be poor performance. All the good ways to optimize involve working with buffers.
Thank you Paul.
That really cleared things for me. Im using this codes to run an active noise control system, and the processing has to be done at each sample. The latency that the buffering brings impairs significantly the control's performance since it is a phase-based control.
