shazznasty
i'd like to be able to connect multiple audio/midi sources to ableton, and each source have it's own separate footswitch control of record on/off, play/mute on/off (with each clip being synced in terms of tempo). essentially so multiple instruments can be added to the loop, with each instrument having separate controls as to when to record and when the loop plays. all that is fine, i've used tutorials to get everything together, and the switches/buttons are working fine and showing up in ableton etc etc.
but i'd also like to have each footswitch have an LED, so you know if you are recording (red), if the clip is playing (green), etc. i can't find any good instructionals online for how to get the teensy to read info from ableton. i'm a little surprised this project hasn't been uploaded by someone else because it seems pretty obvious (footswitch controller with an LED notification light).
can anyone point me to some code that will pull info from ableton, specifically when a track looper is recording, etc? if it doesn't exist, i'd be willing to pay someone to write the code for me.
