Hi all, this should be an easy one for you probably, since i guess this is where the knowledge comes in..
The Teensy 3.2
Ive uploaded the script, use a jumper cable to check the pins, and they work.. a combination of the pins i test translates as a button press, as the code is designed to do. This works
Then i solder in about 8 header pins, as this is the exact same loadout as the previous project
Another test: Descriptor failure
Now, without trying to sound arrogant in any way: i know the soldering is good. I work in electronics and ive soldered more pcb's than i can count.. its a lot
Way of soldering is standard stuff, in and out as quickly as possible,between 350 and 400 degrees and looking nice, so i dont think thats the problem here.
Also, this isnt the first time this time around a Teensy failed me, i resorted to another supplier to take that out of the equasion.
Last time, all was good, buttons and lighting and LED's connected.. then suddenly 3 days later it died
Next time, same setup and route, it failed the next day
Now, with yet another Teensy, it failes almost immediatly: in the device manager i get the Descriptor error 43
Tried different cable, reboot, different port, basically jumped all the hoops and then some!
So... what is going on here??
The emphasis is on the fact that half an hour later theres no more working Teensy, while all i did is put the header pins in place
This project is 10 times less complicated than the one i did before with this setup, and that one works flawlessly
Im lost.. and more out of pocket too
Any help or follow info would be massively appreciated
The Teensy 3.2
