audio board and byte manipulation
eldecog
New member
Hello World,
I would like to manipulate the values from AUDIO_INPUT_LINEIN.
I use memcpy(buffer, queue1.readBuffer(), 256) to read the values and store them to a byte called buffer.
But the values are not byte(8 bits) but int16.
I have to combine them somehow.
I use this command to do it : intValeurR = (buffer[i+1] << 8) | buffer;
but it doesn't work.
My question is simple: how to get the integer 16 values from AUDIO_INPUT_LINEIN on the audio board in order to manipulate them the way I want in my program ?
Thank you all
Just create buffer as an array of int16_t.
int16_t buffer[128];
Then you can access the samples directly from the array. Easy!
Thanks a lot Paul!!
Then I think my problem is something else because for both input, left and right I get the same value, and those values don't seems to be right. never change and both the same.
This is my code:
AudioInputI2S i2s1; //xy=223,143
AudioRecordQueue fileL; //xy=632,116
AudioRecordQueue fileR; //xy=650,182
AudioConnection patchCord1(i2s1, 0, fileL, 0);
AudioConnection patchCord2(i2s1, 1, fileR, 0);
// which input on the audio shield will be used?
//Permet de stocker le temps en ms et savoir où on en est.
unsigned long ulngTime;
AudioMemory(60);
pinMode(13, OUTPUT);
//Enable the audio shield
sgtl5000_1.enable();
void loop(){
int16_t bufferL[128];
int16_t bufferR[128];
memcpy(bufferL, fileL.readBuffer(), 128);
fileL.freeBuffer();
memcpy(bufferR, fileR.readBuffer(), 128);
fileR.freeBuffer();
for (int i=0;i<128;i++){
Serial.println(bufferR);
delay(1);
Ok I found my error it was very simple after have read the doc :/
I had to add this line in setup :
fileR.begin();
of course
You should also call available() and only attempt to read when it tell you 1 or more buffers are actually waiting in the queue for you.
