GeppettoLab
Hi, I'm sorry for this huge post but I need to explain it clearly.
I'm working on the realization of an Escape Room.
I would use Teensy as controller of each game, connected via Ethernet to a PC.
After the first trial I found some problem with the communication with the software due by the server.available() function.
This is my configuration:
From the modem of my office (and later from the one of the escape room) I connect a Router (netgear R6220). From the router I connect my pc and a switch (TL-SG1024D (1Gbit)).
I use the router as a DHCP server reserving all the IP that I need (with the correspondent MAC address).
Then I use a Teensy 3.2 and a Teensy 3.5 with the WIZ820io Adaptor and the WIZ820io Module, and an Arduino Mega with an Ethernet shield based on W5100.
These three board are connected to the switch and are uploaded with the following code (with the right configuration of IPs and MAC addresses)
This code is given by the Escape room software developer to connect an Arduino to his browser based software (Escape Room Master.com).
I set the room for a test and all the connection works in the test mode. The teensy answer to requests (using the /reset and /trigger stirngs) from the software in the right way.
But when I launch the room (open the webpage of the live view of my room) if the Teensy are running, the sketches return false as output of server.available() and the board cannot communicate with the software.
Returning from there in the test mode the server.available() continue to return false (but the sketch is running).
If I restart the Teensy when the live view of my room is open, they begin to communicate correctly with the software.
This does not happen with the Arduino board...
There is an alert on the manual that say "Please make sure you are using the w5500 adapters, and NOT using the w5100 adapters as they do not conform to current hardware and network specifications." can the w5100 on the arduino board generate a connection problem for the Teensy?
How can I resolve without power on the boards after the software is started?
Luca
A prop with a button that sends a signal to ERM & can also trigger a relay
#include <Ethernet.h>
#define BUTTON_PIN 5
//A14 per teensy, 5 per Mega
#define RELAY_PIN 6
bool useDHCP = false;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {0x04, 0xE9, 0xE5, 0x06, 0xE1, 0x2B}; //Dipende da ogni dispositivo, da trovare con T3_readmac.ino (Teensy) o generare (Arduino)
IPAddress ip(10, 0, 0, 103);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// Track the room game state
bool relayTriggered = false; // has the button in the room been pressed?
//start serial connection (debugging)
pinMode(9, OUTPUT);
digitalWrite(9, LOW); // begin reset the WIZ820io
pinMode(10, OUTPUT);
digitalWrite(10, HIGH); // de-select WIZ820io
digitalWrite(9, HIGH); // end reset pulseo
// NOTE: pin 1 & 2 are used for Serial
// 4 & 10 - 13 are used for ethernet
pinMode(BUTTON_PIN, INPUT_PULLUP); // Game btn
pinMode(RELAY_PIN, OUTPUT); // Control mag lock or lights
// start the Ethernet connection and the server:
if (useDHCP) {
Serial.println("Using DHCP");
Ethernet.begin(mac); // Use DHCP instead of ip
else {
Serial.println("Not using DHCP");
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// Initial game state
//read the pushbutton value into a variable
int gameBtnVal = digitalRead(BUTTON_PIN);
//print out the value of the pushbutton
//Serial.println(gameBtnVal);
// Keep in mind the pullup means the pushbutton's
// logic is inverted. It goes HIGH when it's open,
// and LOW when it's pressed
if (gameBtnVal == LOW) {
trigger();
} else reset();
// listen for incoming Ethernet connections:
listenForEthernetClients();
// Maintain DHCP lease
if (useDHCP) {
Ethernet.maintain();
// Use serial for debugging to bypass web server
if (Serial.available()) {
//read serial as a character
char ser = Serial.read();
switch (ser) {
case 'r': // reset prop
reset();
case 'b': // button press
trigger();
Game states
// actions after button has been pressed
void trigger() {
// While the code below is safe to run multiple times
// it's best not to re-run it in case an expensive operation
// is later added
if (relayTriggered) {
return;
relayTriggered = true;
digitalWrite(RELAY_PIN, HIGH);
Serial.println("solved");
// Reset the prop
void reset() {
digitalWrite(RELAY_PIN, LOW);
URL routing for prop commands and polling
// This function dictates what text is returned when the prop is polled over the network
String statusString() {
return relayTriggered ? "solved" : "not solved";
// Actual request handler
void processRequest(EthernetClient& client, String requestStr) {
Serial.println(requestStr);
// Send back different response based on request string
if (requestStr.startsWith("GET /status")) {
Serial.println("polled for status!");
writeClientResponse(client, statusString());
} else if (requestStr.startsWith("GET /reset")) {
Serial.println("Room reset");
reset();
writeClientResponse(client, "ok");
} else if (requestStr.startsWith("GET /trigger")) {
Serial.println("Network prop trigger");
trigger();
writeClientResponseNotFound(client);
HTTP helper functions
void listenForEthernetClients() {
// listen for incoming clients
EthernetClient client = server.available();
if (client) {
Serial.println("Got a client");
// Grab the first HTTP header (GET /status HTTP/1.1)
String requestStr;
boolean firstLine = true;
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
processRequest(client, requestStr);
if (c == '\n') {
// you're starting a new line
firstLine = false;
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
if (firstLine) {
requestStr.concat(c);
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
void writeClientResponse(EthernetClient& client, String bodyStr) {
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/plain");
client.println("Access-Control-Allow-Origin: *"); // ERM will not be able to connect without this header!
client.println();
client.print(bodyStr);
Serial.println(bodyStr);
void writeClientResponseNotFound(EthernetClient& client) {
client.println("HTTP/1.1 404 Not Found");
client.println();
Luca
