Results 1 to 5 of 5
Thread: MIDI DJ Controller using Teensy 3.6 - am I doing this right?
    So I got the crazy idea to create a MIDI DJ Controller using a Teensy 3.6. I'll do a nice write up when I'm finished.
    I am comfortable doing some MIDI stuff, writing C code, some soldering and like to tinker. I do not have much microcontroller experience though. I already have the Teensy 3.6, and I have ordered some hardware. I also have written some software and made a little design. Can you guys please check whether I am missing some big things?
    For now, this is my design. The three multiplexers on the left will be connected to simple button switches. The two on the right will get all the middle pins from many rotary and slider 10k Ohm potentiometers.
    Things I am unsure of:
    • Do I need to connect some/all unused pins to GND?
    • Should I use external power for potentiometers and the Teensy? If so, can I combine that with the usb-power safely?
    • Can I use multiplexers to power LEDs?
    • Am I using correct wire colors?
    • Will multiplexing analog and digital signals like this work?
    • Are there any best practises for MIDI signals/channels/messages?
    Here is my code:
    // analog smoothing
    // include the Bounce library for 'de-bouncing' switches -- removing electrical chatter as contacts settle
    #include <Bounce.h>
    // usbMIDI.h library is added automatically when code is compiled as a MIDI device
    // Multiplexer selector pins on teensy
    int SELECTOR_PINS[] = {32, 31, 30, 29};
    // pins to read
    const int AN = 2; // number of analog pins
    const int DN = 3; // number of digital pins
    const int ANALOG_PINS[AN] = {A0, A1}; // teensy mapping, pin 14,15
    const int DIGITAL_PINS[DN] = {0,1,2}; // teensy mapping
    const int MAX_PINS = 16; // max number of pins multiplexed per multiplexer
    const int ANALOG_MUX_PINS[AN] = {16, 16}; // number of pins on multiplexer used for signals
    const int DIGITAL_MUX_PINS[DN] = {16, 16, 16}; // number of pins on multiplexer used for signals
    // analog[i][j] corresponds to analog pin i on Teensy, pin j on multiplexer
    ResponsiveAnalogRead *analog[AN][MAX_PINS];
    byte analog_data[AN][MAX_PINS];
    byte analog_data_prev[AN][MAX_PINS];
    // digital[i][j] corresponds to digital pin i on Teensy, pin j on multiplexer
    Bounce *digital[DN][MAX_PINS];
    const int BOUNCE_TIME = 5; // 5 ms is usually sufficient
    const int ON_VELOCITY = 127; // pressed button "note" velocity
      setupAnalog();
      setupDigital();
    void setupAnalog() {
      for (int i = 0; i < AN; i++) {
        for (int j = 0; j < ANALOG_MUX_PINS[i]; j++) {
          analog[i][j] = new ResponsiveAnalogRead(ANALOG_PINS[i], true); // initialize
    void setupDigital() {
      for (int i = 0; i < DN; i++) {
        for (int j = 0; j < DIGITAL_MUX_PINS[i]; j++) {
          digital[i][j] = new Bounce(DIGITAL_PINS[i], true); // initialize
        pinMode(DIGITAL_PINS[i], INPUT_PULLUP); // internal pullup resistors for digital section
      for (int j = 0; j < MAX_PINS; j++) { // loop over multiplexer
        setSelectorPins(j);
        readAnalogs(j);
        readDigitals(j);
      while (usbMIDI.read()) {
        // read & ignore incoming messages
    void readAnalogs(int j) {
      for (int i = 0; i < AN; i++) { // loop over analog inputs
        if (j < ANALOG_MUX_PINS[i]) { // pin j on multiplexer is actually used
          analog[i][j]->update();
          if (analog[i][j]->hasChanged()) {
            analog_data[i][j] = analog[i][j]->getValue() >> 3;
            if (analog_data[i][j] != analog_data_prev[i][j]) {
              analog_data_prev[i][j] = analog_data[i][j];
              usbMIDI.sendControlChange(16 + j, analog_data[i][j], i + 1);
              // I use CCID 16-31 which are General Purpose Controllers or Undefined:
              // https://www.midi.org/specifications-old/item/table-3-control-change-messages-data-bytes-2
              // the channel is the index of current analog teensy pin index (i)
    void readDigitals(int j) {
      for (int i = 0; i < DN; i++) { // loop over digital inputs
        if (j < DIGITAL_MUX_PINS[i]) { // pin j on multiplexer is actually used
          digital[i][j]->update();
          if (digital[i][j]->fallingEdge()) {
            usbMIDI.sendNoteOn(j+i*MAX_PINS, ON_VELOCITY, AN + i + 1);
            // note is 16*current digital teensy pin index (i) + current mux pin index (j)
            // velocity is pressing a note (should be 65 to 127)
            // channel is one above the analog + index of current digital teensy pin index (i)
          if (digital[i][j]->risingEdge()) {
            usbMIDI.sendNoteOff(i+j*MAX_PINS, 0, AN + i + 1);
    void setSelectorPins(int j) {
      byte s0 = (j & B0001) ? HIGH : LOW;
      byte s1 = (j & B0010) ? HIGH : LOW;
      byte s2 = (j & B0100) ? HIGH : LOW;
      byte s3 = (j & B1000) ? HIGH : LOW;
      digitalWrite(SELECTOR_PINS[0], s0);
      digitalWrite(SELECTOR_PINS[1], s1);
      digitalWrite(SELECTOR_PINS[2], s2);
      digitalWrite(SELECTOR_PINS[3], s3);
      // allow 50 us for signals to stablize
      delayMicroseconds(50);
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,069
    Wow.... so that's how to initialize bounce and RAR arrays.
    Still studying but looks good from what I can see. Did you seriously write this without the hardware already in place?
    Yup. Of course I'm not going to load this thing first thing, gonna build it up slowly and testing as I go. I'm just worried doing all the microcontroller stuff very wrong.
    I had a little Arduino Stackexchange help for the bounce and RAR arrays: https://arduino.stackexchange.com/qu...jects-in-setup
    Thanks for checking my stuff!
    Feb 2013
    1,069
    Just make sure you are not reading any floating pins. Pullups are on the digital lines but you might need to source or sink any unused pins on the analog mux... especially if they are polled in the code. And they need to be stable voltages during testing if you don't have all your pots set up.
    https://www.pjrc.com/teensy/external_power.html ...there is no short answer to power supply.
    yes...although the "like this" part remains to be seen.
    Apr 2017
    126
    Quote Originally Posted by RedPixel View Post
    Here is my code:
    // analog smoothing
    #include <Bounce.h>
    // pins to read
      setupAnalog();
      setupDigital();
        setSelectorPins(j);
        readAnalogs(j);
        readDigitals(j);
    • As far as on the Teensy you donít have to connect the unused pins to ground, for the multiplexers I canít say otherwise.
    • I donít believe you should need external power for potentiometers and should be able to power it over usb.
    • You can you use multiplexers to power leds, but you have to make sure your code runs fast enough to have no delays for the leds to look like they are all lit. The leds may also be dim because of how fast they have to switch on and off so you may have to play with resistor/voltage of the leds to get it to look how you want.
    • Wire colors are totally up to you, if you understand it thatís all that really matters.
    • You can mix digital and analog signal as long as you can filter out any interference in code, ResponsiveAnalogRead does a good job of this though.
    • I try to stick to control change messages that are undefined in the midi standard and youíve already done this. I also donít use note messages for buttons as most DAWs wonít be able to assign that to a parameter and I wouldnít recommend to use the internal pull-up resistors in the long run, resistors are cheap and itís easy enough to put one for each button.
    Hereís what the back of a 16 slider and 32 button with led panel looks like using 10 8 channel multiplexers.
    Attachment 13836
