Results 1 to 2 of 2
Thread: I want to ask a question
    Jun 2018
    2
    I want to wirelessly controll an LED installation I have at home. I'm using a Teensy 3.2 and Octows2811 adapter.
    I've been looking at the pinout for octo and cc3000 and they seem to use some of the same pins.
    At first I though, hey no problem, I can just change what pins the cc3000 is using. But I think, for example, the octo uses both of the SPI DIN pins on the teensy?
    Does anyone have any tips for me?
    19,915
    If you're using the OctoWS2811 VideoDisplay example, it's easy to change the sync pin. Just edit the number in the code. Only that 1 example uses pin 12, so if you're using any of the other examples or writing your code animation code, you should be fine.
    It's been a while since I've used a CC3000, but I believe pin 12 is the only conflict with OctoWS2811. CC300 uses a couple other pins besides SPI (11, 12, 13), but those can be configured to any digital pins.
