Results 1 to 7 of 7
Thread: Teensy loader not recognizing Teensy 3.2
    Sep 2016
    3
    I plug in the Teensy 3.2 to the PC and the orange light blinks. I open Teensy Loader and press the button, the orange light disappears and Teensy Loader doesn't recognize the Teensy. I've tried reseting the PC, pluging the Teensy while pressing the button, changing USB cable, port... everything I read that could affect.
    What can I do so Teensy Loader recognizes y Teensy 3.2?
    11,764
    Make sure you are not using a 'charge only' USB cable.
    On Teensy.exe Loader Menu is 'Help' - under Help is 'Verbose Info'. Open that and it will indicate when a Teensy is detected by the computer. If it doesn't indicate a device, especially when pushing the 'Program' button - it won't be able to program it.
    Sep 2016
    3
    I've used this cable to transfer data, I'm not sure if that's what you mean by not a 'charge only'.
    This is the 'Verbose Info'
    04:34:59: Teensy Loader 1.21, begin program
    04:34:59: Listening for remote control on port 3149
    04:34:59: initialized, showing main window
    04:34:59: HID/win32: vid:04D9 pid:A0F9 ver:0108
    04:34:59: HID/win32: vid:0951 pid:16A4 ver:0003
    04:35:00: Verbose Info event
    04:35:10: Verbose Info event
    I opened the Teensy Loader before plugin in the Teensy and I pressed the button. No lines were added since I pluged the Teensy.
    6,889
    What type of setup? Windows? 32 or 64 bit? What OS? Also which version of Arduino and Teensyduino?
    For example if you are running Linux, then the next question would be, did you install the udev rule file as shown in the instructions?
    http://www.pjrc.com/teensy/td_download.html
    But I am guessing Windows from the win32... mentioned in verbose...
    22,077
    Wow, ancient 1.21 version!
    Try 1.30 or 1.31-beta1.
    Sep 2016
    3
    I made it work. Thanks for the help!
    how to get Teensy loader none recognition work
    Hi! how did you make it work? I'm having the same issue.
