herald007
New member
Teensy 3.6 code
Ubuntu 16.04 (My laptop) - Using Pyserial
Teensy get 9600 byte from Lepton2.5(Flir IR Camera) and send this data my laptop.
but my laptop can't receive data from teensy (Using usb serial)
(Receive nothing, so python program print "Shutter")
all configuration is fine, Teensy was connect correctly "ttyACM0" and other example code (blink, serial "Hello World") is working good.
i don't know why this is not work..
(The odd thing is sometimes all work fine.. i don't know why....)
Need help
#include <i2c_t3.h>
#include <usb_serial.h>
//Pins
#define pin_mosi 11
#define pin_miso 12
#define pin_sck 13
#define pin_alt_sck 14
#define pin_lepton_cs 15
#define pin_sda 18
#define pin_scl 19
//FLIR Lepton sensor version
#define leptonVersion_2_0_shutter 0 //FLIR Lepton2 Shuttered
#define leptonVersion_3_0_shutter 1 //FLIR Lepton3 Shuttered
#define leptonVersion_2_0_noShutter 2 //FLIR Lepton2 Non-Shuttered
#define leptonVersion_2_5_shutter 3 //FLIR Lepton 2.5 Shuttered
#define leptonVersion_3_5_shutter 3 //FLIR Lepton 3.5 Shuttered
//Shutter mode
#define leptonShutter_manual 0
#define leptonShutter_auto 1
#define leptonShutter_none 2
#define leptonShutter_autoRAD 3
//Hardware diagnostic bit codes
#define diag_spot 0
#define diag_display 1
#define diag_camera 2
#define diag_touch 3
#define diag_sd 4
#define diag_bat 5
#define diag_lep_conf 6
#define diag_lep_data 7
#define diag_ok 255
//Calibration
#define cal_warmup 0
#define cal_standard 1
#define cal_stdSlope 0.0300f //Standard slope value
//160x120 buffer
uint16_t smallBuffer[4800];
//Array to store one Lepton frame
static byte leptonFrame[164];
enum LeptonReadError
NONE,
DISCARD,
SEGMENT_ERROR,
ROW_ERROR,
SEGMENT_INVALID
byte diagnostic;
byte leptonVersion;
byte leptonShutter;
bool autoMode;
bool limitsLocked;
//Vertical display rotation
bool rotationVert = false;
bool rotationHorizont = false;
//Calibration offset
float calOffset;
//Calibration slope
float calSlope;
//Calibration status
byte calStatus;
//Calibration compensation
float calComp;
//Calibration warmup timer
long calTimer;
void initSPI()
pinMode(pin_lepton_cs, OUTPUT);
digitalWrite(pin_lepton_cs, HIGH);
SPI.begin();
/* Inits the I2C Bus */
void initI2C()
//Start the Bus
Wire.begin();
//Enable Timeout for Hardware start
Wire.setDefaultTimeout(1000);
//Use external pullups for new HW
Wire.pinConfigure(I2C_PINS_18_19, I2C_PULLUP_EXT);
/* Switch the SPI clockline to pin 14 */
void startAltClockline(boolean sdStart)
CORE_PIN13_CONFIG = PORT_PCR_MUX(1);
CORE_PIN14_CONFIG = PORT_PCR_DSE | PORT_PCR_MUX(2);
/* Switch the SPI clockline back to pin 13 */
void endAltClockline()
CORE_PIN13_CONFIG = PORT_PCR_DSE | PORT_PCR_MUX(2);
CORE_PIN14_CONFIG = PORT_PCR_MUX(1);
/* Checks the specific device from the diagnostic variable */
bool checkDiagnostic(byte device)
//Returns false if the device does not work
return (diagnostic >> device) & 1;
/* Sets the status of a specific device from the diagnostic variable */
void setDiagnostic(byte device)
diagnostic &= ~(1 << device);
void lepton_setReg(byte reg)
Wire.beginTransmission(0x2A);
Wire.write(reg >> 8 & 0xff);
Wire.write(reg & 0xff);
Wire.endTransmission();
/* Read I2C Register on the lepton */
int lepton_readReg(byte reg)
uint16_t reading;
lepton_setReg(reg);
Wire.requestFrom(0x2A, 2);
reading = Wire.read();
reading = reading << 8;
reading |= Wire.read();
return reading;
/* Checks the Lepton hardware revision */
void lepton_version()
//Get AGC Command
Wire.write(0x00);
Wire.write(0x04);
Wire.write(0x48);
Wire.write(0x1C);
byte error = Wire.endTransmission();
//Lepton I2C error, set diagnostic
if (error != 0)
setDiagnostic(diag_lep_conf);
leptonVersion = leptonVersion_2_0_noShutter;
return;
//Transfer the new package
while (lepton_readReg(0x2) & 0x01)
Wire.requestFrom(0x2A, lepton_readReg(0x6));
char leptonhw[33];
Wire.readBytes(leptonhw, 32);
//Detected Lepton2 Non-Shuttered
if (strstr(leptonhw, "05-060340") != NULL)
leptonShutter = leptonShutter_none;
//Detected Lepton2 Shuttered
else if (strstr(leptonhw, "05-060950") != NULL)
leptonVersion = leptonVersion_2_0_shutter;
leptonShutter = leptonShutter_auto;
//Detected Lepton2.5 Shuttered (Radiometric)
else if (strstr(leptonhw, "05-070360") != NULL)
leptonVersion = leptonVersion_2_5_shutter;
leptonShutter = leptonShutter_autoRAD;
//Detected Lepton3 Shuttered
else if (strstr(leptonhw, "05-070620") != NULL)
leptonVersion = leptonVersion_3_0_shutter;
//Detected Lepton3.5 Shuttered (Radiometric)
else if (strstr(leptonhw, "05-070170") != NULL)
leptonVersion = leptonVersion_3_5_shutter;
//Detected unknown Lepton2 No-Shutter
/* Start Lepton SPI Transmission */
void lepton_begin()
//Start alternative clock line, except for old HW
//if (mlx90614Version == mlx90614Version_new)
startAltClockline(true);
//For Teensy 3.1 / 3.2 and Lepton3 use this one
//if ((teensyVersion == teensyVersion_old) && ((leptonVersion == leptonVersion_3_0_shutter) || (leptonVersion == leptonVersion_3_5_shutter)))
//SPI.beginTransaction(SPISettings(30000000, MSBFIRST, SPI_MODE0));
//Otherwise use 20 Mhz maximum and SPI mode 1
//else
SPI.beginTransaction(SPISettings(20000000, MSBFIRST, SPI_MODE1));
//Start transfer - CS LOW
digitalWrite(pin_lepton_cs, LOW);
/* End Lepton SPI Transmission */
void lepton_end()
//End transfer - CS HIGH
digitalWriteFast(pin_lepton_cs, HIGH);
//End SPI Transaction
SPI.endTransaction();
//End alternative clock line, except for old HW
endAltClockline();
/* Init the FLIR Lepton LWIR sensor */
void lepton_init()
//Check the Lepton HW Revision
lepton_version();
//For radiometric Lepton, set calibration to done
if ((leptonVersion == leptonVersion_2_5_shutter) || (leptonVersion == leptonVersion_3_5_shutter))
calStatus = cal_standard;
//Otherwise init warmup timer
//Set the calibration timer
calTimer = millis();
//Set calibration status to warmup if not coming from mass storage
calStatus = cal_warmup;
//Set the compensation value to zero
calComp = 0;
//Activate auto mode
autoMode = true;
//Deactivate limits Locked
limitsLocked = false;
//Check if SPI works
lepton_begin();
do
SPI.transfer(leptonFrame, 164);
//Repeat as long as the frame is not valid, equals sync
while (((leptonFrame[0] & 0x0F) == 0x0F) && ((millis() - calTimer) < 1000));
lepton_end();
//If sync not received after a second, set diagnostic
if ((leptonFrame[0] & 0x0F) == 0x0F)
setDiagnostic(diag_lep_data);
void lepton_reset()
lepton_end();
delay(186);
lepton_begin();
/* Get one line package from the Lepton */
LeptonReadError lepton_getPackage(byte line, byte seg)
//Receive one frame over SPI
//Serial.print("Discard error\n");
return DISCARD;
//Check if the line number matches the expected line
if (leptonFrame[1] != line)
//Serial.print("ROW_Error \n");
return ROW_ERROR;
//Everything worked
return NONE;
/* Store one package of 80 columns into RAM */
bool savePackage(byte line, byte segment)
//Go through the video pixels for one video line
for (int column = 0; column < 80; column++)
//Apply horizontal mirroring
if (rotationHorizont)
column = 79 - column;
//Make a 16-bit rawvalue from the lepton frame
uint16_t result = (uint16_t)(leptonFrame[2 * column + 4] << 8 | leptonFrame[2 * column + 5]);
//Discard horizontal mirroring
//Invalid value, return
if (result == 0)
return 0;
//Lepton2
//Non-rotated
//Rotated or old hardware version
smallBuffer[(line * 80) + column] = result;
//Serial.print("data save done\n");
//Everything worked
//Serial.print("savePackage End\n");
return 1;
/* Get one frame of raw values from the lepton */
void lepton_getRawValues()
//Serial.print("Start getRawValues");
byte line, error, segmentNumbers;
segmentNumbers = 1;
//Begin SPI Transmission
lepton_begin();
//Go through the segments
for (byte segment = 1; segment <= segmentNumbers; segment++)
//Reset error counter for each segment
error = 0;
//Go through one segment, equals 60 lines of 80 values
do
for (line = 0; line < 60; line++)
//Maximum error count
if (error == 255)
//Reset segment
segment = 1;
//Reset error
error = 0;
//Reset Lepton SPI
lepton_reset();
//Restart at line 0
//Get a package from the lepton
LeptonReadError retVal = lepton_getPackage(line, segment);
//If everythin worked, continue
if (retVal == NONE)
if (savePackage(line, segment))
continue;
//Raise lepton error
error++;
//Serial.printf("Error %d\n", error);
//Stabilize framerate
uint32_t time = micros();
while ((micros() - time) < 800)
__asm__ volatile("nop");
//Restart at line 0
} while (line != 60);
//End SPI Transmission
//Serial.print("End getRawValue\n");
lepton_end();
// Variables
char sync = 0;
int idx_x = 0;
int idx_y = 0;
// Init Hardware
//Serial.begin(2000000);
initSPI();
initI2C();
Wire.setDefaultTimeout(0);
//initBuffer();
lepton_init();
delay(200);
usb_serial_flush_input();
sync = Serial.read();
usb_serial_flush_output();
if (sync == 'A')
lepton_getRawValues();
usb_serial_write(smallBuffer, 9600);
import numpy as np
import serial
import cv2
cv2.useOptimized()
cv2.useOpenVX()
np.set_printoptions(threshold=np.nan)
ser = serial.Serial('/dev/ttyACM0', 115200, timeout=1)
char_data = 'A'
sync_data = str.encode(char_data)
exit_flag = 0
ser.write(sync_data)
ser.reset_input_buffer()
while 1:
# Get data from MCU
buffer = ser.read(9600)
# Save data numpy format and reshape the data
lepton = np.frombuffer(buffer, dtype=np.uint16)
if lepton.size == 0:
print("Shutter")
continue
lepton = lepton.reshape(60, 80)
ser.reset_output_buffer()
lepton_img = cv2.normalize(lepton, lepton,
alpha=0, beta=255,
norm_type=cv2.NORM_MINMAX,
dtype=cv2.CV_8UC1)
lepton_img = cv2.resize(lepton_img, None, None, fx=4, fy=4,
interpolation=cv2.INTER_CUBIC)
cv2.imshow("Test", lepton_img)
if cv2.waitKey(1) & 0xFF == ord('q'):
exit_flag = 1
break
print("End")
Need help
