#line 2 "unit_tests_core.ino"
#include <ArduinoUnit.h>
#include <Pozyx.h>
#include <Pozyx_definitions.h>
// can we read a single byte
test(regRead_singlebyte)
uint8_t whoami = 0;
int status = Pozyx.regRead(POZYX_WHO_AM_I, &whoami, 1);
assertEqual(status, POZYX_SUCCESS);
assertEqual(whoami, 0x43);
// can we write a single byte
test(regWrite_singlebyte)
uint8_t writebyte = 19;
// write the value 1 to this register
int status = Pozyx.regWrite(POZYX_POS_X, &writebyte, 1);
// this delay is necessary because pozyx is still processing the write operation first.
delay(1);
uint8_t testbyte = 0;
Pozyx.regRead(POZYX_POS_X, &testbyte, 1);
assertEqual(testbyte, writebyte);
// can we write multiple bytes at once
test(regWrite_multibyte)
uint32_t pos[3] = {1, 2, 3};
int status = Pozyx.regWrite(POZYX_POS_X, (uint8_t*)&pos, 3*sizeof(uint32_t));
delay(1);
pos[0] = 0;
pos[1] = 0;
pos[2] = 0;
Pozyx.regRead(POZYX_POS_X, (uint8_t*)&pos, 3*sizeof(uint32_t));
assertEqual(pos[0], 1);
assertEqual(pos[1], 2);
assertEqual(pos[2], 3);
// can we write a single byte quickly after one-another.
test(regWrite_quick)
int num_cycles = 10;
uint8_t i = 0;
for(i=1; i <= num_cycles; i++){
int status = Pozyx.regWrite(POZYX_POS_X, (uint8_t*)&i, 1);
delay(1);
uint8_t result = 0;
Pozyx.regRead(POZYX_POS_X, (uint8_t*)&result, 1);
assertEqual(result, num_cycles);
test(regFunction_simple)
uint8_t input = 0x88;
// call function to write to some buffer
int status = Pozyx.regFunction( POZYX_LED_CTRL, (uint8_t*)&input, 1, 0, 0);
// can we call a register function?
test(regFunction)
uint16_t input[3] = {1, 2, 3};
int status = Pozyx.regFunction( POZYX_POS_SET_ANCHOR_IDS, (uint8_t*)&input, 3*sizeof(uint16_t), 0, 0);
// call function to read from some buffer
uint16_t result[3] = {0,0,0};
status = Pozyx.regFunction( POZYX_POS_GET_ANCHOR_IDS, 0, 0, (uint8_t*)&result, 3*sizeof(uint16_t));
assertEqual(result[0], 1);
assertEqual(result[1], 2);
assertEqual(result[2], 3);
assertEqual(status, 3);
test(waitForFlag)
Pozyx.begin(false, MODE_INTERRUPT, POZYX_INT_STATUS_ERR);
//Pozyx.begin(false, MODE_POLLING, POZYX_INT_STATUS_ERR);
// read out the interrupt status register to reset it.
uint8_t dummy;
Pozyx.regRead(POZYX_INT_STATUS, &dummy, 1);
// cause an error interrupt by writing to a read-only register
uint8_t causes_error = 0x01;
Pozyx.regWrite(POZYX_WHO_AM_I, &causes_error, 1);
// if the interrupt was caught, the result is true
boolean result = Pozyx.waitForFlag(POZYX_INT_STATUS_ERR, 100);
assertTrue(result);
while(!Serial); // for the Arduino Leonardo/Micro only
Wire.begin();
Test::run();
