In a Teensy 3.2, I want to run the DAC and ADC to simultaneously output a waveform and read two channels of ADC, at rates up to 160 kHz if possible, or at the fastest rate at which the hardware can do this, with 16 bit resolution in the ADC.
(1) Can this done be done with DMA?
(2) Is there an example code, or API, that has this functionality?
(3) At a high level, what are the steps in software for doing this?
Thank you
Thank you
