Following is the adc_pdb example. modified to save data to a buffer for each ADC, and increment counters in each ISR. The output shows that a count missing from one of the adc_isr(), and the PDB isr counter has not advanced from zero.
After entering the command 's1000', the output is
Note that the adc1 counter is short one count, and the pdb counter is still at zero.
#include <ADC_Module.h>
#include <ADC.h>
#include <RingBuffer.h>
#include <RingBufferDMA.h>
/* Example for triggering the ADC with PDB
* Valid for Teensy 3.0 and 3.1, not LC
#include <ADC.h>
const int readPin = A9; // ADC0
const int readPin2 = A2; // ADC1
ADC *adc = new ADC(); // adc object;
pinMode(LED_BUILTIN, OUTPUT);
pinMode(readPin, INPUT);
pinMode(readPin2, INPUT);
Serial.println("Begin setup");
///// ADC0 ////
adc->setAveraging(1); // set number of averages
adc->setResolution(8); // set bits of resolution
adc->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH_SPEED); // change the conversion speed
adc->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPEED); // change the sampling speed
////// ADC1 /////
#if ADC_NUM_ADCS>1
adc->setAveraging(1, ADC_1); // set number of averages
adc->setResolution(8, ADC_1); // set bits of resolution
adc->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH_SPEED, ADC_1); // change the conversion speed
adc->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPEED, ADC_1); // change the sampling speed
Serial.println("End setup");
#define BUFLEN 1024
int buf[BUFLEN] = { 0 };
int nbuf = 0;
int buf2[BUFLEN] = { 0 };
int nbuf2 = 0;
int pdbknt = 0;
char c=0;
int value;
int value2;
if (Serial.available()) {
c = Serial.read();
if(c=='v') { // value
Serial.print("Value ADC0: ");
value = (uint16_t)adc->readSingle(ADC_0); // the unsigned is necessary for 16 bits, otherwise values larger than 3.3/2 V are negative!
Serial.println(value*3.3/adc->getMaxValue(ADC_0), DEC);
#if ADC_NUM_ADCS>1
Serial.print("Value ADC1: ");
value2 = (uint16_t)adc->readSingle(ADC_1); // the unsigned is necessary for 16 bits, otherwise values larger than 3.3/2 V are negative!
Serial.println(value2*3.3/adc->getMaxValue(ADC_1), DEC);
} else if(c=='s') { // start pdb, before pressing enter write the frequency in Hz
uint32_t freq = Serial.parseInt();
if (freq == 0) {
Serial.println("Stop pdb.");
adc->adc0->stopPDB();
adc->adc1->stopPDB();
else {
Serial.print("Start pdb with frequency ");
Serial.print(freq);
Serial.println(" Hz.");
pdbknt = 0;
adc->adc0->startSingleRead(readPin); // call this to setup everything before the pdb starts, differential is also possible
adc->enableInterrupts(ADC_0);
adc->adc0->startPDB(freq); //frequency in Hz
#if ADC_NUM_ADCS>1
adc->adc1->startSingleRead(readPin2); // call this to setup everything before the pdb starts
adc->enableInterrupts(ADC_1);
adc->adc1->startPDB(freq); //frequency in Hz
} else if(c=='p') { // pbd stats
Serial.print("Frequency: ");
Serial.println(adc->adc0->getPDBFrequency());
Serial.print("knts adc0 " );
Serial.print( nbuf );
Serial.print(" adc1 " );
Serial.print( nbuf2 );
Serial.print(" pdb " );
Serial.println( pdbknt );
// Print errors, if any.
adc->printError();
adc->resetError();
//digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN));
delay(10);
// Make sure to call readSingle() to clear the interrupt.
void adc0_isr() {
buf[nbuf++] = adc->adc0->readSingle();
if (nbuf >= BUFLEN-1) {
//adc->disableInterrupts(ADC_0);
//digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN) );
#if ADC_NUM_ADCS>1
void adc1_isr() {
buf2[nbuf2++] = adc->adc1->readSingle();
if (nbuf2 >= BUFLEN-1) {
//adc->disableInterrupts(ADC_1);
// pdb interrupt is enabled in case you need it.
void pdb_isr(void) {
pdbknt++;
PDB0_SC &=~PDB_SC_PDBIF; // clear interrupt
Frequency: 1000
knts adc0 1024 adc1 1023 pdb 0
