What do I do with the Die attach pad?
Hi guys,
Nooby question here, should be pretty straightforward.
I'm building a teensy powered device of my own and am currently creating an eagle component for the MKL02Z32VFG4 bootloader chip.
What on earth do I do with the Die attach pad on the bottom?
I'm guessing I want to connect it to to the board to disperse heat but should it be connected to ground or am I wrong entirely?
Many thanks,
Giga.
You should have a look at the data sheet. But normally, these "die pads" should be soldered to a ground plane, or in case of a multilayer board to a copper area which is linked to a ground plane with 3 or 4 vias.
Connect it to GND.
Heat isn't an issue with that chip. It uses very little power.
The center pad is needed only for mechanical stability on this part.
