Results 1 to 3 of 3
Thread: USB combination with Serial1
    Jun 2018
    3
    New on this forum but already a happy teensy user.
    I'm looking for a solution to use usb and serial1 communication with only the usb cable. This is to switch easily between devices, other teensy with xbee, Android or pc. I've came to a solution to use a usb3 cable and connect tx/rx to the high-speed wiring from the usb3 and use the rest as standard (D+ D-). On the second teensy same connection, so no problem. I'm wondering if connecting to, let say, a pc usb3 port would be harmful for either teensy or pc (for this device the communication goes through D+ D-)? Thanks in advance for the support.
    22,091
    Connecting non-USB signals to those pins is asking for trouble. At the very least, maybe put some resistors in series to limit the current.
    Jun 2018
    3
    Paul, thanks for the reply. Although it had some benefits for me, I guess that it isn't a really good solution. I've decided to go for a UTP cable from my device to the other teensy. Or plug it in a computer with a adapter plug.
Tags for this Thread
