Results 1 to 3 of 3
Thread: T3.6 MIDI USB Host - querying "midi1.product"
    Apologies for what is probably a rudimentary question. I'm using a Teensy 3.6 as a USB host with a MIDI device, I'm attempting to query "midi1.product" but am getting an error when compiling. I'm using the "USBHost_t36/MIDI/InputFunctions" example, and referencing the USBHost_t36.h file.
    Adding the following code to the "myNoteOn" section compiles and works fine:
      Serial.println(midi1.idVendor());
      Serial.println(midi1.idProduct());
    The following code gives an error:
      Serial.println(midi1.product());
    The error is "no matching function for call to 'println(const uint8_t*)'"
    The relevant code from the header is:
    // All USB device drivers inherit from this base class.
    class USBDriver : public USBHost {
    public:
    	operator bool() {
    		Device_t *dev = *(Device_t * volatile *)&device;
    		return dev != nullptr;
    	uint16_t idVendor() {
    		return (dev != nullptr) ? dev->idVendor : 0;
    	uint16_t idProduct() {
    		return (dev != nullptr) ? dev->idProduct : 0;
    	const uint8_t *manufacturer() {
    		if (dev == nullptr || dev->strbuf == nullptr) return nullptr;
    		return &dev->strbuf->buffer[dev->strbuf->iStrings[strbuf_t::STR_ID_MAN]];
    	const uint8_t *product() {
    		return &dev->strbuf->buffer[dev->strbuf->iStrings[strbuf_t::STR_ID_PROD]];
    	const uint8_t *serialNumber() {
    		return &dev->strbuf->buffer[dev->strbuf->iStrings[strbuf_t::STR_ID_SERIAL]];
    I suspect this is because the "*product()" variable is being defined as a constant, and I'm not calling it correctly. Could someone point me in the right direction here?
    22,673
    Try this:
    Serial.println((const char *)midi1.product());
    Try this:
    Works like a charm, thank you!
