SPI speed on Teensy 3.5 is not correct
BOBILLIER
Hi. Today i take a look on SPI clock signal. Despite i have define 400000 for speed, the clk signal is measured at 312000. It's not really a problem for me but perhaps this can impact other features in Teensy..
Actually I believe it is working correctly.
That is the Speed value you pass in, is a value that says SPI shall not exceed this speed.
You did not specify much here, but if I assume a default build, the T3.5 was built at 120mhz? Which implies that the bus (F_BUS) was defined to be 60mhz.
The SPI clock is setup by using clock dividers. The two nearest values for clock dividers are:
128 so 60000000/128 = 468750 which is too big
and 192 60000000/192 = 312500 which is what you are seeing.
Oops, I have made mistakes. It's a Teensy 3.6 and I compile it at 180Mhz. For me, like I said before, it's not a problem and all works fine.
But it's better to know how it's work and why frequency is different from what's expected.
I am glad it is working. I just thought I would mention how it works and options...
Same difference the T3.6 at 180mhz the F_BUS by default is set to 60mhz...
If instead you run at 192K than F_BUS = 48K
Then: 48000000/128 = 375000 which is closer to your desired SPI speed
Run at 216K -> F_BUS= 54K ... 192 again 281250 worse...
Note: there are some options in kinetish to change what F_BUS value to use for a speed, by editing the file in the sections that look like:
#elif (F_CPU == 180000000)
 #define F_PLL 180000000
 #ifndef F_BUS
 #define F_BUS 60000000
 //#define F_BUS 90000000
 #define F_MEM 25714286
The F_BUS must be even divided into F_CPU, so you see there is a commented out version of 90mhz...
but 90000000/192 = 468.... Too big, so next is 256 -> 351562.5 which gets you closer...
