Hi all, a project I've been working on which goes through a wake-sleep cycle and records audio is working great, no humming noises/clicks, I2C LCD is great, RTC works, etc., but I'm encountering difficulty when trying create WAV files with variable/unique filenames (rather than predefined string literals/constants), based on the RTC's timestamp.
The SD.h and corresponding functions seem to require "const char*", which is interferring with my ability to create a unique filename each time.
I experimented with going through and removing the "const"s in the SD.h and SD.cpp, but that just resulted in no file being created at all (when feeding in "char*"), with silent failures occurring (and a "0") object being returned by the SD.open() command. However, specifying the constant "BOB.WAV" in the file.open() still works, even with the const's having been removed (making think there's something else somewhere causing it to fail with a non-const data type).
Anybody have an solutions to get around this? My main desire is that each WAV file be uniquely named using the timestamp. I'm open to even initially writing a fixed filename like "temp.WAV", then renaming it to something with a timestamp, but I've encountered headwinds doing that (with different SD libraries eating each other) .
Thank you for any help .
SD card is in the audio board, rather than the Teensy 3.6's SD slot.
#include <SD_t3.h>
#include <SerialFlash.h>
// for buttons
#include <Bounce.h>
// for RTC
#include <TimeLib.h>
//write wav
unsigned long ChunkSize = 0L;
unsigned long Subchunk1Size = 16;
unsigned int AudioFormat = 1;
unsigned int numChannels = 1;
unsigned long sampleRate = 44100;
unsigned int bitsPerSample = 16;
unsigned long byteRate = sampleRate * numChannels * (bitsPerSample / 8); // samplerate x channels x (bitspersample / 8)
unsigned int blockAlign = numChannels * bitsPerSample / 8;
unsigned long Subchunk2Size = 0L;
unsigned long recByteSaved = 0L;
unsigned long NumSamples = 0L;
byte byte1, byte2, byte3, byte4;
//const int myInput = AUDIO_INPUT_LINEIN;
const int myInput = AUDIO_INPUT_MIC;
AudioPlaySdWav audioSD;
AudioInputI2S audioInput;
AudioOutputI2S audioOutput;
AudioRecordQueue queue1;
//recod from mic
AudioConnection patchCord1(audioInput, 0, queue1, 0);
AudioConnection patchCord2(audioSD, 0, audioOutput, 0);
AudioConnection patchCord3(audioSD, 0, audioOutput, 1);
AudioControlSGTL5000 audioShield;
// Bounce objects to easily and reliably read the buttons
// example: Bounce <alias> = Bounce(<pin number>, delay-in-ms)
Bounce buttonRecord = Bounce(32, 100);
Bounce buttonStop = Bounce(31, 100); // 100 = 100 ms debounce time
Bounce buttonPlay = Bounce(30, 100);
int mode = 0; // 0=stopped, 1=recording, 2=playing
File frec;
elapsedMillis msecs;
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
// Define LED to indicate when recording
#define LED 13
// declare variables used to hold the sleep-time length, and recording length
// TODO: use these addresses to store updated cycle parameters
unsigned int sleepaddr = 1;
unsigned int recordaddr = 0;
//////////////////// For setting up display //////////////////////////////
// Include NewLiquidCrystal Library for I2C
#include <LiquidCrystal_I2C.h>
// Define LCD pinout
const int en = 2, rw = 1, rs = 0, d4 = 4, d5 = 5, d6 = 6, d7 = 7, bl = 3;
// Define I2C Address - change if reqiuired
const int i2c_addr = 0x3F;
LiquidCrystal_I2C lcd(i2c_addr, en, rw, rs, d4, d5, d6, d7, bl, POSITIVE);
bool screen_is_here = false;
//character array to store changing filename
char fname[16];
//check if screen is plugged in
Wire.begin();
Wire.beginTransmission(i2c_addr);
if (Wire.endTransmission() == 0) {
// Set the screen_is_here flag to 'true'
screen_is_here = true;
// Set display type as 16 char, 2 rows
lcd.begin(16, 2);
// Print on first row
lcd.setCursor(0, 0);
lcd.print("Recording Test");
// Wait 1 second
// Print on second row
lcd.setCursor(0, 1);
lcd.print("Press any button.");
// Wait 8 seconds
delay(8000);
// Clear the display
lcd.clear();
}else{
// execute automated stuff
// set the Time library to use Teensy 3.0's RTC to keep time
// Setup name for new recording
String filename = month();
filename += "-";
filename += day();
filename += "-";
filename += hour();
filename += "-";
filename += minute();
filename += ".WAV ";
unsigned int stringlength = filename.length();
filename.toCharArray(fname, stringlength);
// Configure the pushbutton pins
pinMode(32, INPUT_PULLUP);
pinMode(31, INPUT_PULLUP);
pinMode(30, INPUT_PULLUP);
pinMode(13, OUTPUT);
AudioMemory(60);
audioShield.enable();
audioShield.inputSelect(myInput);
audioShield.micGain(40); //0-63
audioShield.volume(0.5); //0-1
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
TODO: In the main loop, there will be main functions:
1. sleep
2. record
3. save
TODO: In addition, there will be the functions for the menu, which listen to button input for changing
the recording and sleep length.
asm volatile(" WFI"); //Tell cpu to wait for interrupt... saves battery.
if (screen_is_here) {
// First, read the buttons
buttonRecord.update();
buttonStop.update();
buttonPlay.update();
// Respond to button presses
if (buttonRecord.fallingEdge()) {
Serial.println("Record Button Press");
digitalWrite(LED, HIGH);
//LCD section
lcd.clear();
lcd.print("Recording...");
if (mode == 2) stopPlaying();
if (mode == 0) {
startRecording();
if ( buttonStop.fallingEdge()) {//incomingByte == '2' ||
Serial.println("Stop Button Press");
digitalWrite(LED, LOW);
//LCD section
lcd.clear();
lcd.print("Stopped...");
if (mode == 1) stopRecording();
if ( buttonPlay.fallingEdge()) {// incomingByte == '3' ||
Serial.println("Play Button Press");
//LCD section
lcd.clear();
lcd.print("Playing...");
if (mode == 0) startPlaying();
if (mode == 1) {
continueRecording();
{ /* What to do when the screen isn't here */
Serial.println("Screen detection failed");
String startRecording() { // TODO: Modify to take a time parameter?
//frec = SD.open("BOB.WAV", FILE_WRITE);
frec = SD.open(fname, FILE_WRITE);
Serial.print(frec);
Serial.println(fname);
// if the dated initial file on SD is successfully created, then start recording.
if (frec) {
queue1.begin();
Serial.println("Supposedly started recording to SD..."); //Execution never enters this block :-(...
mode = 1;
recByteSaved = 0L;
return fname;
void continueRecording() {
if (queue1.available() >= 2) {
byte buffer[512];
memcpy(buffer, queue1.readBuffer(), 256);
queue1.freeBuffer();
memcpy(buffer + 256, queue1.readBuffer(), 256);
// write all 512 bytes to the SD card
frec.write(buffer, 512);
recByteSaved += 512;
elapsedMicros usec = 0;
Serial.print("SD write, us=");
Serial.println(usec);
void stopRecording() {
Serial.println("stopRecording");
queue1.end();
if (mode == 1) {
frec.write((byte*)queue1.readBuffer(), 256);
recByteSaved += 256;
writeOutHeader();
frec.close();
Serial.println("Setting mode to 0");
mode = 0;
Serial.println(mode);
void startPlaying() { //Not certain that we need this later.
Serial.println("startPlaying");
//audioSD.play("BOB.WAV");
audioSD.play(fname);
mode = 2;
void stopPlaying() { //Not certain that we need this later.
Serial.println("stopPlaying");
if (mode == 2) audioSD.stop();
mode = 0;
// This function is what turns the RAW audio into a WAV, by adding a header to the file.
void writeOutHeader() { // update WAV header with final filesize/datasize
// NumSamples = (recByteSaved*8)/bitsPerSample/numChannels;
// Subchunk2Size = NumSamples*numChannels*bitsPerSample/8; // number of samples x number of channels x number of bytes per sample
Subchunk2Size = recByteSaved;
ChunkSize = Subchunk2Size + 36;
frec.seek(0);
frec.write("RIFF");
byte1 = ChunkSize & 0xff;
byte2 = (ChunkSize >> 8) & 0xff;
byte3 = (ChunkSize >> 16) & 0xff;
byte4 = (ChunkSize >> 24) & 0xff;
frec.write(byte1); frec.write(byte2); frec.write(byte3); frec.write(byte4);
frec.write("WAVE");
frec.write("fmt ");
byte1 = Subchunk1Size & 0xff;
byte2 = (Subchunk1Size >> 8) & 0xff;
byte3 = (Subchunk1Size >> 16) & 0xff;
byte4 = (Subchunk1Size >> 24) & 0xff;
byte1 = AudioFormat & 0xff;
byte2 = (AudioFormat >> 8) & 0xff;
byte1 = numChannels & 0xff;
byte2 = (numChannels >> 8) & 0xff;
byte1 = sampleRate & 0xff;
byte2 = (sampleRate >> 8) & 0xff;
byte3 = (sampleRate >> 16) & 0xff;
byte4 = (sampleRate >> 24) & 0xff;
byte1 = byteRate & 0xff;
byte2 = (byteRate >> 8) & 0xff;
byte3 = (byteRate >> 16) & 0xff;
byte4 = (byteRate >> 24) & 0xff;
byte1 = blockAlign & 0xff;
byte2 = (blockAlign >> 8) & 0xff;
byte1 = bitsPerSample & 0xff;
byte2 = (bitsPerSample >> 8) & 0xff;
frec.write("data");
byte1 = Subchunk2Size & 0xff;
byte2 = (Subchunk2Size >> 8) & 0xff;
byte3 = (Subchunk2Size >> 16) & 0xff;
byte4 = (Subchunk2Size >> 24) & 0xff;
frec.close();
Serial.println("header written");
Serial.print("Subchunk2: ");
Serial.println(Subchunk2Size);
//////////// Below code the controls the overall system sleep ////////////////
// https://forum.pjrc.com/threads/33243-RTC-alarm-to-wake-up-from-deep-sleep //
/******************* Seting Alarm **************************/
#define RTC_IER_TAIE_MASK 0x4u
#define RTC_SR_TAF_MASK 0x4u
void rtcSetup(void)
SIM_SCGC6 |= SIM_SCGC6_RTC;// enable RTC clock
RTC_CR |= RTC_CR_OSCE;// enable RTC
void rtcSetAlarm(uint32_t nsec)
RTC_TAR = RTC_TSR + nsec;
RTC_IER |= RTC_IER_TAIE_MASK;
/********************LLWU**********************************/
#define WMUF5_MASK 0x20u
static void llwuISR(void)
#if defined(HAS_KINETIS_LLWU_32CH)
LLWU_MF5 |= WMUF5_MASK;
#elif defined(HAS_KINETIS_LLWU_16CH)
LLWU_F3 |= WMUF5_MASK; // clear source in LLWU Flag register
RTC_IER = 0;// clear RTC interrupts
void llwuSetup(void)
attachInterruptVector( IRQ_LLWU, llwuISR );
NVIC_SET_PRIORITY( IRQ_LLWU, 2 * 16 );
NVIC_CLEAR_PENDING( IRQ_LLWU );
NVIC_ENABLE_IRQ( IRQ_LLWU );
LLWU_PE1 = 0;
LLWU_PE2 = 0;
LLWU_PE3 = 0;
LLWU_PE4 = 0;
LLWU_ME = LLWU_ME_WUME5; //rtc alarm
/********************* go to deep sleep *********************/
// These are defined in the core now
#define SMC_PMPROT_AVLLS_MASK 0x2u
#define SMC_PMCTRL_STOPM_MASK 0x7u
#define SCB_SCR_SLEEPDEEP_MASK 0x4u
void goSleep(void) {
//volatile unsigned int dummyread;
/* Make sure clock monitor is off so we don't get spurious reset */
// currently not set by anything I know, so the clock monitor is not set from reset
MCG_C6 &= ~MCG_C6_CME0;
/* Write to PMPROT to allow all possible power modes */
SMC_PMPROT = SMC_PMPROT_AVLLS_MASK;// Not needed already taken care of in here.
/* Set the STOPM field to 0b100 for VLLSx mode */
SMC_PMCTRL &= ~SMC_PMCTRL_STOPM_MASK;
SMC_PMCTRL |= SMC_PMCTRL_STOPM(0x4); // VLLSx
SMC_VLLSCTRL = SMC_VLLSCTRL_VLLSM(0x3); // VLLS3
/*wait for write to complete to SMC before stopping core */
(void) SMC_PMCTRL;
SYST_CSR &= ~SYST_CSR_TICKINT; // disable systick timer interrupt
SCB_SCR |= SCB_SCR_SLEEPDEEP_MASK; // Set SLEEPDEEP bit to enable deep sleep mode (STOP)
asm volatile( "wfi" ); // WFI instruction will start entry into STOP mode
// will never return, but generates system reset
/* From previously used example for how to activate the sleep/alarm
flashLed(100);
rtcSetup();
llwuSetup();
rtcSetAlarm(5); // This value is seconds
goSleep();
//This is used by setup loop to specify where to get time from, pointing to RTC
time_t getTeensy3Time()
return Teensy3Clock.get();
