The pozyx ranging demo (c) Pozyx Labs
please check out https://www.pozyx.io/Documentation/Tutorials/getting_started/Arduino
This demo requires one (or two) pozyx shields and one Arduino. It demonstrates the 3D orientation and the functionality
to remotely read register data from a pozyx device. Place one of the pozyx shields on the Arduino and upload this sketch.
This demo reads the following sensor data:
- pressure
- acceleration
- magnetic field strength
- angular velocity
- the heading, roll and pitch
- the quaternion rotation describing the 3D orientation of the device. This can be used to transform from the body coordinate system to the world coordinate system.
- the linear acceleration (the acceleration excluding gravity)
- the gravitational vector
The data can be viewed in the Processing sketch orientation_3D.pde
Tested successfully with Teensy 3.2 with modified interrupts in Pozyx lib
#include <Pozyx.h>
#include <Pozyx_definitions.h>
////////////////// PARAMETERS //////////////////
boolean remote = true; // boolean to indicate if we want to read sensor data from the attached pozyx shield (value 0) or from a remote pozyx device (value 1)
uint16_t remote_id = 0x6e6a; // the network id of the other pozyx device: fill in the network id of the other device
uint32_t last_millis; // used to compute the measurement interval in milliseconds
Serial.println("Setup started.");
if(Pozyx.begin(false, MODE_INTERRUPT, POZYX_INT_MASK_IMU) == POZYX_FAILURE){
Serial.println("ERROR: Unable to connect to POZYX shield");
Serial.println("Reset required");
abort();
if(!remote)
remote_id = NULL;
last_millis = millis();
delay(10);
Serial.println("Setup finished.");
void loop(){
sensor_raw_t sensor_raw;
uint8_t calibration_status = 0;
int dt;
int status;
if(remote){
status = Pozyx.getRawSensorData(&sensor_raw, remote_id);
status &= Pozyx.getCalibrationStatus(&calibration_status, remote_id);
if(status != POZYX_SUCCESS){
return;
}else{
if (Pozyx.waitForFlag(POZYX_INT_STATUS_IMU, 10) == POZYX_SUCCESS){
Pozyx.getRawSensorData(&sensor_raw);
Pozyx.getCalibrationStatus(&calibration_status);
}else{
uint8_t interrupt_status = 0;
Pozyx.getInterruptStatus(&interrupt_status);
return;
dt = millis() - last_millis;
last_millis += dt;
// print time difference between last measurement in ms, sensor data, and calibration data
Serial.print("dt: ");
Serial.print(dt, DEC);
Serial.print(",");
printRawSensorData(sensor_raw);
//Serial.print(",");
// will be zeros for remote devices as unavailable remotely.
//printCalibrationStatus(calibration_status);
void printRawSensorData(sensor_raw_t sensor_raw){
//Serial.print(sensor_raw.pressure);
//Serial.print(sensor_raw.acceleration[0]);
//Serial.print(sensor_raw.acceleration[1]);
//Serial.print(sensor_raw.acceleration[2]);
//Serial.print(sensor_raw.magnetic[0]);
//Serial.print(sensor_raw.magnetic[1]);
//Serial.print(sensor_raw.magnetic[2]);
//Serial.print(sensor_raw.angular_vel[0]);
//Serial.print(sensor_raw.angular_vel[1]);
//Serial.print(sensor_raw.angular_vel[2]);
//Serial.print(sensor_raw.euler_angles[0]);
//Serial.print(sensor_raw.euler_angles[1]);
//Serial.print(sensor_raw.euler_angles[2]);
Serial.print(", quat_0: ");
Serial.print(sensor_raw.quaternion[0]);
Serial.print(", quat_1: ");
Serial.print(sensor_raw.quaternion[1]);
Serial.print(", quat_2: ");
Serial.print(sensor_raw.quaternion[2]);
Serial.print(", quat_3: ");
Serial.print(sensor_raw.quaternion[3]);
//Serial.print(sensor_raw.linear_acceleration[0]);
//Serial.print(sensor_raw.linear_acceleration[1]);
//Serial.print(sensor_raw.linear_acceleration[2]);
//Serial.print(sensor_raw.gravity_vector[0]);
//Serial.print(sensor_raw.gravity_vector[1]);
//Serial.print(sensor_raw.gravity_vector[2]);
//Serial.print(", temp_c: ");
//Serial.print(sensor_raw.temperature);
void printCalibrationStatus(uint8_t calibration_status){
Serial.print(calibration_status & 0x03);
Serial.print(",");
Serial.print((calibration_status & 0x0C) >> 2);
Serial.print(",");
Serial.print((calibration_status & 0x30) >> 4);
Serial.print(",");
Serial.print((calibration_status & 0xC0) >> 6);
