C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\dmanthei\Documents\Arduino\libraries -fqbn=teensy:avr:teensy35:usb=serial,speed=120,opt=o2std,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10805 -build-path C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461 -warnings=none -build-cache C:\Users\dmanthei\AppData\Local\Temp\arduino_cache_843527 -verbose N:\Engineering\Measurement Equipment Program Files\Arduino\Arduino_Hardware_tests_examples\Teensy_3.5_with_I2C_Logic_Shifter\Teensy_3.5_with_I2C_Logic_Shifter.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\dmanthei\Documents\Arduino\libraries -fqbn=teensy:avr:teensy35:usb=serial,speed=120,opt=o2std,keys=en-us -vid-pid=0X16C0_0X0483 -ide-version=10805 -build-path C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461 -warnings=none -build-cache C:\Users\dmanthei\AppData\Local\Temp\arduino_cache_843527 -verbose N:\Engineering\Measurement Equipment Program Files\Arduino\Arduino_Hardware_tests_examples\Teensy_3.5_with_I2C_Logic_Shifter\Teensy_3.5_with_I2C_Logic_Shifter.ino
Using board 'teensy35' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\sketch\Teensy_3.5_with_I2C_Logic_Shifter.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\sketch\Teensy_3.5_with_I2C_Logic_Shifter.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\LiquidCrystal\src" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\sketch\Teensy_3.5_with_I2C_Logic_Shifter.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\LiquidCrystal\src" "-IC:\Users\dmanthei\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\sketch\Teensy_3.5_with_I2C_Logic_Shifter.ino.cpp" -o "nul"
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\Wire.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\WireKinetis.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility\twi.c
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\LiquidCrystal\src\LiquidCrystal.cpp
Using cached library dependencies for file: C:\Users\dmanthei\Documents\Arduino\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\LiquidCrystal\src" "-IC:\Users\dmanthei\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\sketch\Teensy_3.5_with_I2C_Logic_Shifter.ino.cpp" -o "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++14 -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK64FX512__ -DTEENSYDUINO=141 -DARDUINO=10805 -DF_CPU=120000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\LiquidCrystal\src" "-IC:\Users\dmanthei\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\sketch\Teensy_3.5_with_I2C_Logic_Shifter.ino.cpp" -o "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\sketch\Teensy_3.5_with_I2C_Logic_Shifter.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
Using previously compiled file: C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\libraries\Wire\WireKinetis.cpp.o
Using previously compiled file: C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\libraries\Wire\utility\twi.c.o
Compiling library "LiquidCrystal"
Using previously compiled file: C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\libraries\LiquidCrystal\LiquidCrystal.cpp.o
Compiling library "LiquidCrystal_I2C"
Using previously compiled file: C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp.o
Compiling core...
Using precompiled core
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1530269339 "-TC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/mk64fx512.ld" -lstdc++ -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461/Teensy_3.5_with_I2C_Logic_Shifter.ino.elf" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\sketch\Teensy_3.5_with_I2C_Logic_Shifter.ino.cpp.o" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\libraries\Wire\Wire.cpp.o" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\libraries\Wire\WireKinetis.cpp.o" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\libraries\Wire\utility\twi.c.o" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\libraries\LiquidCrystal\LiquidCrystal.cpp.o" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp.o" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461/..\arduino_cache_843527\core\core_teensy_avr_teensy35_usb_serial,speed_120,opt_o2std,keys_en-us_4939f5412a75a8560acb0f9e98268f02.a" "-LC:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461" -larm_cortexM4lf_math -lm
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461/Teensy_3.5_with_I2C_Logic_Shifter.ino.elf" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461/Teensy_3.5_with_I2C_Logic_Shifter.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461/Teensy_3.5_with_I2C_Logic_Shifter.ino.elf" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461/Teensy_3.5_with_I2C_Logic_Shifter.ino.hex"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/stdout_redirect" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461/Teensy_3.5_with_I2C_Logic_Shifter.ino.lst" "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461/Teensy_3.5_with_I2C_Logic_Shifter.ino.elf"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/stdout_redirect" "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461/Teensy_3.5_with_I2C_Logic_Shifter.ino.sym" "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461/Teensy_3.5_with_I2C_Logic_Shifter.ino.elf"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/teensy_post_compile" "-file=Teensy_3.5_with_I2C_Logic_Shifter.ino" "-path=C:\Users\dmanthei\AppData\Local\Temp\arduino_build_856461" "-tools=C:\Program Files (x86)\Arduino\hardware\teensy/../tools/" "-board=TEENSY35"
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
Using library LiquidCrystal at version 1.0.7 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\LiquidCrystal
Using library LiquidCrystal_I2C at version 1.1.2 in folder: C:\Users\dmanthei\Documents\Arduino\libraries\LiquidCrystal_I2C
Sketch uses 15500 bytes (2%) of program storage space. Maximum is 524288 bytes.
Global variables use 5220 bytes (2%) of dynamic memory, leaving 191388 bytes for local variables. Maximum is 196608 bytes.
