jordiguerrero
New member
I'm trying to use rosserial with Teensy 3.5 through bluetooth.
My first step: change the serial port from Serial to Serial1.
I follow the thread:
https://answers.ros.org/question/19...he-arduino-side/?answer=295159#post-id-295159
It compiles with Arduino Mega board but no with Teensy 3.5 (or other Teensy boards)
I use:
Ubuntu 16.04, Kinetic ros, Arduino 1.8.5
The Hello World example code:
http://wiki.ros.org/rosserial_arduino/Tutorials/Hello World
I tried to ways:
1. Modify the line 73 in the code arduino.1.8.5/libraries/ros_lib/ArduinoHardware.h
2. Replace:
with:
The error when I try to compile is:
ArduinoHardware.h:
http://docs.ros.org/jade/api/rosserial_arduino/html/ArduinoHardware_8h_source.html
Can anyone help me? Thank you in advance
I use:
I tried to ways:
iostream = &Serial1;
2. Replace:
ros::NodeHandle nh;
class NewHardware : public ArduinoHardware
public:
NewHardware():ArduinoHardware(&Serial1, 57600){};
ros::NodeHandle_<NewHardware> nh;
.../arduino-1.8.5/libraries/ros_lib/ArduinoHardware.h:67:5: note: no known conversion for argument 1 from 'HardwareSerial*' to 'usb_serial_class*'
no matching function for call to 'ArduinoHardware::ArduinoHardware(HardwareSerial*, int)'
ArduinoHardware.h:
