zhifangtan
New member
Hi guys, totally newbie here.
I am attempting to create a feedback active noise cancelling system using Teensy 3.6. So the idea is that I have a microphone as the input and a speaker as an output. The signal from the microphone goes through a series of algorithm and output to the speaker. However, I am currently having trouble to make it work. This is my first teensy project and I am still trying to learn as much as I can. I have spent weeks scavenging information about anything that could help. I was wondering if I could achieve this with Teensy, any help would be greatly appreciated.
Problems/Questions:
1) Should I use the audio library for easier implementation?
2) Is there anyway to accelerate the algorithm part?
Again, I am totally newbie in Teensy and micro-controller. I am not entirely sure if I am going to the right direction. Thanks for any input or suggestion
This is the secondary acoustic path estimation for the ANC system.
Problems/Questions:
Feedback Active Noise Cancelling System
Secondary Path Offline Estimation
#include <arm_math.h>
#include <ADC.h>
#include <DMAChannel.h>
ADC *adc = new ADC();
DMAChannel dma;
const int freq = 10;
const int micPin = A0;
const int speakerPin = A22;
const int32_t taps = 200;
uint16_t samples[1];
int32_t r;
int32_t d;
float32_t mu = 0.0000000005;
float32_t x[taps];
float32_t w[taps];
float32_t muEX[taps];
float32_t y;
float32_t e;
float32_t mue;
//pinMode(micPin, INPUT);
dmaInit();
analogWriteResolution(12);
adc->setAveraging(1);
adc->setResolution(12);
adc->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH_SPEED);
adc->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPEED);
//adc->adc0->analogRead(micPin);
adc->adc0->startSingleRead(micPin);
adc->enableDMA(ADC_0);
adc->adc0->stopPDB();
adc->adc0->startPDB(freq);
adc->enableInterrupts(ADC_0);
randomSeed(1);
while (!Serial); // wait for Arduino serial monitor
dmaInit();
void dmaInit() {
dma.source(*(uint16_t*) &ADC0_RA);
dma.destinationBuffer(samples, sizeof(samples));
dma.attachInterrupt(dma_isr);
dma.interruptAtCompletion();
dma.triggerAtHardwareEvent(DMAMUX_SOURCE_ADC0);
dma.enable();
void algorithm() {
int k = taps;
while (k > 1)
x[k - 1] = x[k - 2];
k--;
r = random(0, 4096);
x[0] = r;
analogWrite(speakerPin, r);
arm_dot_prod_f32(x, w, taps, &y);
d = samples[0];
//Serial.println(d - 2048);
e = d - y;
mue = mu * e;
arm_scale_f32(x, mue, muEX, taps);
arm_add_f32(w, muEX, w, taps);
//Serial.println(w[0],7);
void adc0_isr() {
adc->adc0->readSingle();
Serial.println(samples[0]);
//long unsigned current = micros();
algorithm();
//Serial.println(micros() - current);
void dma_isr() {
//Serial.println("dma");;
dma.clearInterrupt();
void pdb_isr(void) {
PDB0_SC &=~PDB_SC_PDBIF; // clear interrupt
//digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN) );
