Wireless Communication between Teensy3.6 ad wireless sensor
slade54
New member
Hey I am trying to connect one of Mesh sensor with Teensy3.6. As per mentioned documentation of digimesh, I was able to install firmware and make xbee device act as router as well as coordinator but while connecting and checking the readings of sensor output sometimes it take huge delay to show the readings (around 5 to 7 mins) and if distance is much far without any line of sight block then also around 15 to 20 minutes it will not send readings.
Still not able to find the cause, Your suggestions on this will be much appreciated
