Results 1 to 19 of 19
Thread: Programino IDE -- Teensy configuration
    Oct 2015
    227
    I recently found the Programino IDE and really like it's editor. However, I'm not clear on how to add and configure a Teensy board. Is anyone else using this IDE with their Teensy?
    Thanks...
    Oct 2015
    227
    One of the things I need to tell Programino is what the sketch uploader is and where it is located.
    Where is the Teensydunio uploader located?
    18,502
    It is hardware/tools/teensy_post_compile.
    To see the command syntax, in Arduino's File > Preferences, turn on verbose output during upload.
    Oct 2015
    227
    I see this in the Ardunio IDE when I upload:
    C:\Program Files (x86)\Arduino\hardware\teensy/../tools/teensy_post_compile -file=FS1000Main1.0.0.ino -path=C:\Users\RFRESH~1\AppData\Local\Temp\arduino_ build_125497 -tools=C:\Prog ram Files (x86)\Arduino\hardware\teensy/../tools -board=TEENSY31 -reboot -port=usb:0/1D0000/0/1/3/1 -portlabel=hid#vid_16c0&pid_0478#8... (Teensy 3.2) Bootloader -portprotocol=Teensy
    Attached is the dialog I have to fill in.
    I added "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/teensy_post_compile" but that gave this message: Programmer *.exe or *.bat not found, please check the path settings!
    18,502
    PJRC only officially supports use by the Arduino IDE. While I can point you to the command line utils, that's the most I can do to help.
    Maybe ask the Programino folks for help from here?
    Oct 2015
    227
    I did post for help on configuring the Teensy on their Contact Us link a few days ago but so far no response.
    Thanks Paul. I'll keep playing around with it and see if I can stumble on the right set up. I'm only using the Programino IDE because it's got such a great editor but their support isn't very timely.
    2,797
    Quote Originally Posted by rfresh737 View Post
    Note, you can configure the Arduino IDE to use an external editor. So if you can get to the Programino IDE editor outside of the IDE, it might be a solution.
    Oct 2015
    227
    Hi Michael,
    I just configured it that way. It's a work around, but it is usable that way. Thank you.
    18,502
    Maybe try all backslashes '\' as Windows normally uses, rather than a combination of '\' and '/'. Arduino is using Java and most of the native stuff is built it mingw (lots of unix stuff emulated), so both types of slashes tend to work. But maybe Programino is built with Windows-only stuff that only allows '\'?
    6,969
    My windows path to that is :: "T:\arduino_1.8.5_142\hardware\tools\teensy_post_c ompile.exe"
    That is an UnZip install to 'T:\arduino_1.8.5_142' versus "C:\Program Files (x86)"
    Maybe one of two things:
    >> paths with spaces - at least at the command line - need the double quotes. Would expect code string should resolve that though as that not Teensy unique if others use such a bootloader path.
    >> As Paul noted Windows uses backslash for disk path separator
    Making a fresh UnZip copy install of the IDE like above ( then TeensyInstaller on that path ) - perhaps to the root of a drive into a folder with no spaces in the name - and point Programino to that?
    Oct 2015
    227
    Hmmm...some success (I think).
    I used this string: C:\Program Files (x86)\Arduino\hardware\tools\teensy_post_compile.e xe
    Verify and upload code please wait... Done!
    Last verify at: 07:40:28
    quit
    teensy_post_compile - inform the Teensy Loader of freshly compiled code
    Usage:
       teensy_post_compile -file=<file> -path=<path> -tools=<toolspath>
           <file> - The code to program (without .hex) to your Teensy board
           <path> - The directory where <file.hex> is located
           <toolspath> - The directory where the Teensy Loader is located
    So then I tried this string: C:\Program Files (x86)\Arduino\hardware\tools\teensy_post_compile.e xe -file=<file> -path=%PATH% -tools=%PATH%
    but that produced this message:
    I guess I'll just have to use Programino as an external editor (sigh).
    Thank you all for trying to help!
    6,969
    An unzip install and starting over to a non-spaced path might fix that. Adding the params with spaces in the path must be confusing the second example.
    Perhaps make the path "C:\Program Files (x86)" into a drive letter? { …. below … }
    <Edit> SUBST … https://www.wikihow.com/Map-a-Folder...ter-in-Windows
    Oct 2015
    227
    I installed Ardunio and Teensydunio into C:\Ardunio but that didn't seem to help any.
    Unless and until I get a reply from the Programino developer, I will just use Programino as an external editor.
    6,969
    That rules out some obvious stuff from Windows end and Teensy - hopefully those guys can repro and fix.
    18,502
    That definitely does not look right.
    -path needs to be the directory where the .hex file is located.
    -toolspath needs to be the directory where teensy.exe is located.
    These are almost certainly not the same.
    Oct 2015
    227
    Thanks for that help Paul.
    Below is the new string based on your above comment, but I am still getting the same error:
    The new configuration string:
    C:\Arduino\hardware\tools\teensy_post_compile -file=C:\Users\RFRESH~1\AppData\Local\Temp\arduino_build_122803 -tools=C:\Arduino\hardware\tools
    Below is the Ardunio IDE upload verbose string which I tried but still no go. I guess I'll have to hope that the developer responds to my request for help.
    "C:\Arduino\hardware\teensy\tools\teensy_post_compile" "-file=FS1000Main1.0.0.ino" "-path=C:\Users\RFRESH~1\AppData\Local\Temp\arduino_build_122803" "-tools=C:\Arduino\hardware\teensy\tools\" "-board=TEENSY31"
    18,502
    In this case, you've put both the file and path under "-file=", rather than putting on the file on "-file-" and the path on "-path-".
    It will not recognize you've used a full pathname under "-file=" and split it for you. This is a command line utility which isn't meant to be run by humans. It expects very specific inputs which normally come from other software.
    Oct 2015
    227
    C:\Arduino\hardware\tools\teensy_post_compile -file=FS1000Main1.00.hex -path=C:\Users\RFRESH~1\AppData\Local\Temp\arduino_build_122803 -tools=C:\Arduino\hardware\tools
    I think this is correct now.
    -path=C:\Users\RFRESH~1\AppData\Local\Temp\arduino_ build_122803 [where the hex file is located]
    -tools=C:\Arduino\hardware\tools [where teensy.exe is located]
    But still getting the same error. I think I'll just wait for the developer to respond and then post the correct line back here in case anyone else wants to know how to do it.
    Thank you Paul.
    18,502
    As a quick sanity check, you can try typing or copy-paste that line to a command prompt window. If it works when entered at a command prompt, that'll give you something more substantial to say when/if the Programino developers respond...
    Don't forget the -reboot if you want to do more than just cause Teensy Loader to open the file and be ready for a manual button press (as happen at the end of Verify from Arduino).
    You might also use Teensy Loader's Verbose Info window (hidden in the Help menu) to see if it's hearing the result of these commands. Compare what happens when Ardiuno does it. At the very least, you should see Teensy Loader receive the info and open your HEX file.
