I did post for help on configuring the Teensy on their Contact Us link a few days ago but so far no response.
Thanks Paul. I'll keep playing around with it and see if I can stumble on the right set up. I'm only using the Programino IDE because it's got such a great editor but their support isn't very timely.
Verify and upload code please wait... Done!
Last verify at: 07:40:28
quit
teensy_post_compile - inform the Teensy Loader of freshly compiled code
Usage:
teensy_post_compile -file=<file> -path=<path> -tools=<toolspath>
<file> - The code to program (without .hex) to your Teensy board
<path> - The directory where <file.hex> is located
<toolspath> - The directory where the Teensy Loader is located
Programmer *.exe or *.bat not found, please check the path settings!
So then I tried this string: C:\Program Files (x86)\Arduino\hardware\tools\teensy_post_compile.exe -file=<file> -path=%PATH% -tools=%PATH%
C:\Arduino\hardware\tools\teensy_post_compile -file=C:\Users\RFRESH~1\AppData\Local\Temp\arduino_build_122803 -tools=C:\Arduino\hardware\tools
"C:\Arduino\hardware\teensy\tools\teensy_post_compile" "-file=FS1000Main1.0.0.ino" "-path=C:\Users\RFRESH~1\AppData\Local\Temp\arduino_build_122803" "-tools=C:\Arduino\hardware\teensy\tools\" "-board=TEENSY31"
The new configuration string:
Code:C:\Arduino\hardware\tools\teensy_post_compile -file=C:\Users\RFRESH~1\AppData\Local\Temp\arduino_build_122803 -tools=C:\Arduino\hardware\tools
C:\Arduino\hardware\tools\teensy_post_compile -file=FS1000Main1.00.hex -path=C:\Users\RFRESH~1\AppData\Local\Temp\arduino_build_122803 -tools=C:\Arduino\hardware\tools
