alexandros
I'm building a project where I use a Teensy 3.2 and an Odroid-XU4 where there is data exchange between the two. I'm reading quite a lot of potentiometers (could sum up to more than 30 at times) plus using input and output shift registers and I'm sending data from the Teensy concerning digital and analog input, but the Teensy also receives data to light up LEDs. When an LED is supposed to blink quite fast (about 100 ms, not exactly sure, maybe longer than that), the result is not as stable as it should be.
I'm thinking of using a hardware serial interface to send data from the Odroid to the Teensy. Will that make any difference? If so, using Serial1 will have the same effect as using Serial2? I think Serial1 is the same port as Serial, or am I wrong?
I'm not posting the code because it's pretty big (over 600 lines). If anyone wants to take a look, it's here https://github.com/alexdrymonitis/3...e/modular_synthesizer/modular_synthesizer.ino
