Page 1 of 6 1 2 3 ... LastLast
Results 1 to 25 of 128
Thread: Sound for model railroading scale 1/32
    I have the project to built a DCC digital locomotive (see NmraDcc on Github).
    For the command of electric motors and lights, the Arduino is enough without any problems.
    But to sound the locos (electric, diesel or steam), I need more memories.
    So, I have choosen the Teensy 3.2.
    I start with the example :"SamplePlayer" https://github.com/PaulStoffregen/Audio/blob/master/examples/SamplePlayer/SamplePlayer.ino"
    I removed all the instructions regarding the shield : AudioControlSGTL5000 audioShield or SD Shield
    Obviously, I shall later change "AudioSampleSnare" by "Compressor release", "Horn", "Brake", . . . and sounds will be synchronized with speed, acceleration, deceleration or DCC commands for "Horn".
    But, I got the following message on IDE Arduino:
    C:\Documents\Arduino\PlayFromSketchV0\PlayFromSket chV0.ino:13:92: fatal error: AudioSampleSnare.h: No such file or directory
    compilation terminated.
    SamplePlayer.ino
    #include <output_dac.h>
    #include <play_memory.h>
    // WAV files converted to code by wav2sketch
    #include "AudioSampleSnare.h"        // http://www.freesound.org/people/KEVOY/sounds/82583/
    // Create the Audio components.  These should be created in the
    // order data flows, inputs/sources -> processing -> outputs
    AudioPlayMemory    sound0;
    AudioOutputAnalog  dac;     // play to both I2S audio board and on-chip DAC
    // Create Audio connections between the components
    AudioConnection c1(sound0,dac);
      // Audio connections require memory to work.  For more
      AudioMemory(10);
      analogWriteResolution(12);
      // turn on the output
    //  audioShield.enable();
    //  audioShield.volume(50);
      // by default the Teensy 3.1 DAC uses 3.3Vp-p output
      // if your 3.3V power has noise, switching to the
      // internal 1.2V reference can give you a clean signal
      //dac.analogReference(INTERNAL);
       sound0.play(AudioSampleSnare);
    AudioSampleSnare.cpp
    // Audio data converted from WAV file by wav2sketch
    // Converted from AudioSampleSnare.wav, using 22050 Hz, u-law encoding
    const unsigned int AudioSampleSnare [2817] = {
    0x02002BD3,0x65636656,0x6B6A6B67,0x7071706F,0x43637171,0x29ABBA23,0x3137474C,0x3A4A544D,
    0x30C1542C,0xE14F6360,0xEDDCE2E6, ............................................
    AudioSampleSnare.h
    extern const unsigned int AudioSampleSnare[2817];
    is this "AudioSampleSnare.h" in the same folder as your *.ino?
    Best regards, Christof
    7,408
    Does the file name match? #include "AudioSampleSnare.h"
    That is, is your AudioSampleSnare.h file named exactly the same? Including the case of the characters?
    I am assuming windows, as the error message: C:\Documents\Arduino\PlayFromSketchV0\PlayFromSket chV0.ino
    And windows file system is not case sensitive, but I have have seen where some of the Arduino compile and preprocessor tools are case sensitive.
    I don't understand because, when I place :
    int he *.ino --> no problem
    and when I dispatche the "const unsigned int AudioSampleSnare [2817]" in *.h and *.cpp (all are in the same directory than *.ino),
    there is the following message error :
    C:\Users\AppData\Local\Temp\arduino_build_592557\s ketch\PlayFromSketchVZ2.ino.cpp.o: In function `loop':
    C:\Users\Documents\PlayFromSketchVZ2/PlayFromSketchVZ2.ino:381: undefined reference to `Toto'
    Erreur de compilation pour la carte Teensy 3.2 / 3.1
    7,408
    Hard for me to say, without seeing the full sources. Like what is at line 381? Maybe create a zip file of the sketch and upload it as an attachment. I believe you can use the tools->Archive Sketch menu item to create the zip file.
    Thank you, now, it's Ok.
    In fact, I have choosen a Teensy 3.2 due to memory capacity (in comparaison with Arduino)
    But, with Arduino, I can encode *.wav in 8 bits / 11025 Hz
    and with Teensy Wav2sketch 16 bits mono / 44,xxxxx kHz.
    So, I got too big file and I loose real advantages in term of duration (I don't need high quality sound).
    1) Is it possible to encode sound on Teensy with only 8 bits mono / 11025 Hz ?
    2) Is it possible to avoid to get "click" each time I begin the "loop" again ? low-pass filter ? teensy 3.5 with SDcard ? ...........
    Nota :
    The teensy receives every time a NMRADCC packets which give speed command, acceleration and décéleration.
    The NMRADCC process needs to be integrated in the "loop" part of the programm.
    22,458
    Quote Originally Posted by Benoit92 View Post
    Yes.
    Just convert the WAV file to 11025 Hz, using Audacity or any other sound editing software. I highly recommend re-opening the WAV file and listening to it from your PC. Not all sound editing software is created equal. Some programs don't do the conversion properly unless extra options are used.
    When you run wav2sketch, it preserves the 16 bit resolution if you give it "-16" on the command line. Otherwise it converts to 8 bit u-law encoded.
    The memory-based sample playing code on Teensy supports 6 formats, 11025, 21050 and 44110 Hz sample rate, at either 16 bit or 8 bit u-law. If you're not familiar with u-law, in a nutshell it uses non-linear scaling (similar to human hearing sensitivity) for the 8 bits, so you get the dynamic range and noise floor of ~12 bits. But the trade-off is some distortion added, especially intermodulation distortion if your clip is composed of multiple sounds mixed together. Generally u-law works well for single voices and single sound effects, but performs poorly for musical compositions.
    The memory sound clips are always mono. The wav2sketch automatically converts stereo to mono. The only way to get stereo is with 2 players and 2 clips.
    Nobody can say, without knowing the details of what you're really doing.
    But if I had to guess, I'd go with yes, clicks are almost always avoidable. Without actually fixing whatever is wrong with the data, a common way to solve click involves using the envelope or fade objects.
    Thank you for your explanation.
    From Audacity, I export in some formats and I got the following results :
    1) 16 bits : initial wav 198 Ko after wav2sketch.exe -> 278 Ko (Ok, but why such inflation ?)
    2) 8 bits unsigned : initial wav 99Ko after wav2sketch.exe-> error
    converting: Steam_8_unsign.wav --> AudioSampleSteam_8_unsign
    wav2sketch: file Steam_8_unsign.wav has 8 bit format, but only 16 is supported
    3) u_law : initial wav 99Ko after wav2sketch.exe-> error
    converting: Steam_starting_u_law.wav --> AudioSampleSteam_starting_u_law
    wav2sketch: error in format of file Steam_starting_u_law.wav
    22,458
    Maybe you're comparing the .WAV file size to the .CPP file size? WAV is efficiently packed binary data. CPP is ascii text. You can view the file in Arduino (just click on its tab) and clearly see the data for each 4 bytes of memory is stored as 9 characters of ASCII text, plus newlines chars after each line.
    The number which matters on Teensy is the change in "Sketch uses 54812 bytes (20%) of program storage space."
    Ok, Thanks, that 's clear now.
    Does it existe, on Teensy, a programm wich can use soundfile converted with "EncoderAudio" (8 bits/8kHz - It's enough for my application) and which uses PWM pin ?
    I think that 2 timers would be changed through the library : #include <PCM.h>.
    From Arduino forum :
    * Plays 8-bit PCM audio on pin 11 using pulse-width modulation (PWM).
    * For Arduino with Atmega168 at 16 MHz.
    * Uses two timers. The first changes the sample value 8000 times a second.
    * The second holds pin 11 high for 0-255 ticks out of a 256-tick cycle,
    * depending on sample value. The second timer repeats 62500 times per second
    * (16000000 / 256), much faster than the playback rate (8000 Hz), so
    * it almost sounds halfway decent, just really quiet on a PC speaker.
    * Takes over Timer 1 (16-bit) for the 8000 Hz timer. This breaks PWM
    * (analogWrite()) for Arduino pins 9 and 10. Takes Timer 2 (8-bit)
    * for the pulse width modulation, breaking PWM for pins 11 & 3.
    22,458
    You could pretty easily make such a program, since 8 kHz is so very slow. Just use IntervalTimer to run a function that reads the next byte and do analogWrite. Also use analogWriteFrequency in setup() so the frequency is higher. Details here:
    IntervalTimer:
    https://www.pjrc.com/teensy/td_timin...rvalTimer.html
    analogWriteFrequency:
    https://www.pjrc.com/teensy/td_pulse.html
    You could also get much better help here with the click problem and other issues if you post complete code. When you hold back on code and details, everyone is really limited in how much we can help.
    Thank you for these advices.
    Nota :I am a very young beginner in software (I am 60 years old but not in retirement) !
    It's Ok to generate sound.
    I have now to integrate sound generation in the NmraDcc code which was developed for Arduino.
    In this case, Arduino uses Pin 2 (Int0) as external Interruption to receive packets signal from rails.
    Can I use pin 2 (or others ??) on Teensy 3.2 to receive Dcc signal ?
    22,458
    The recommended way to use pin interrupts is:
    attachInterrupt(digitalPinToInterrupt(pin), function, mode);
    You didn't post the link to the code in question (eg, the "Forum Rule") so we can't see whether it already has digitalPinToInterrupt, or if it has the number 0 or 1 which mean pins 2 or 3 on Arduino Uno. In fact, it's not really even clear if you mean Uno when you write "which was developed for Arduino", but that seems likely.
    So, without details, the best I can suggest is use the recommended form with digitalPinToInterrupt. That works on all Arduino and all Teensy boards, as long as you use a pin which supports interrupts.
    You should probably also be aware interrupts tend to be very sensitive if you use signals that have noise from the mechanical chatter of switches or other mechanical contacts. The faster the processor, the more sensitive it can be. Teensy 3.2 is much, much faster than most Arduino boards.
    In the library NmraDcc on Github, there is the following function in NmraDcc.cpp :
    NmraDcc::NmraDcc()
    void NmraDcc::pin( uint8_t ExtIntNum, uint8_t ExtIntPinNum, uint8_t EnablePullup)
    #if defined ( __STM32F1__ )
      // with STM32F1 the interuptnumber is equal the pin number
      DccProcState.ExtIntNum = ExtIntPinNum;
    #else
      DccProcState.ExtIntNum = ExtIntNum;
      DccProcState.ExtIntPinNum = ExtIntPinNum;
      pinMode( ExtIntPinNum, INPUT );
      if( EnablePullup )
        digitalWrite(ExtIntPinNum, HIGH);
    In the application.ino, there is the following line to choose the pin (usually pin 2 - int0)?
       // Setup which External Interrupt, the Pin it's associated with that we're using and enable the Pull-Up
    Dcc.pin(0, 2, 0);
    Does this method go with Teensy 3.2 ?
    I am a beginner and I hope that I have describe my problem with enough clearness
    22,458
    Teensy 3.2 uses the same numbers for interrupts and pins. So pin 2 is interrupt 2 on Teensy 3.2.
    Arduino Uno, the most popular Arduino board, has only 2 pins which support interrupts. It uses interrupt #0 for pin 2 and #1 for pin 3. Maybe you're seeing advice that was specific to Uno?
    From only the code fragments shown, my guess (admittedly a bit of guesswork) is you would use Dcc.pin(2, 2, 0) or Dcc.pin(2, 2, 1), depending on whether your hradware has a real pullup resistor.
    A link to the complete source for this library would have been much better.
    Ok, Thanks.
    Attached, the complete library's source NmraDcc from Github :
    https://github.com/mrrwa/NmraDcc
    I try to use only one teensy 3.2 with SPI Flash 64 M to deal with all the functions (motor, lights and sound).
    1) But, I wonder what is the signification of "0xF8A00" in "const unsigned int AudioSampleStandby = 0xF8A00;"
    #include <NmraDcc.h>
    #include <Servo.h>
    //#include <SD.h>
    //#include <Bounce.h>
    #include <play_serialflash.h>
    //16 Bit RAW - Converted with wav2trw -16
    const unsigned int AudioSampleStandby = 0xF8A00;          //TBD Length - AudioSampleStandby.raw
    const unsigned int AudioSampleSteam = 0;                  //TBD Length - AudioSampleSteam.raw
    const unsigned int AudioSampleCompressor = 0xD0B00;       //TBD Length - AudioSampleCompressor.raw
    const unsigned int AudioSampleAirRelease =  0xDCD00;      //TBD Length - AudioSampleAirRelease.raw
    const unsigned int AudioSampleBell = 0x9500;              //TBD Length - AudioSampleBell.raw
    const unsigned int AudioSampleWhistle = 0xE2100;          //TBD Length - AudioSampleWhistle.raw
    const unsigned int AudioSampleShoveling = 0xE2100;        //TBD Length - AudioSampleShoveling.raw
    2) In order to write Soundfiles on SPI Flash, I shall use "rawfile-uploader.py" ??? but where I have to place the Soundfiles in my PC.
    Thanks.
    22,458
    Maybe it has something to do with "wav2trw"? Is it this program from Frank?
    https://github.com/FrankBoesing/Teen...master/utility
    I believe this maybe be old left over stuff from the early days before we has raw file playing integrated to the audio library.
    Hi, I am trying to load rawsoundfile (AABR99.trw) from PC (ASUS 550C - Windows10) to Spi Flash Memory (25Q64BVSIG) with a teensy 3.2.
    Memory <-> Teensy connection
    WP/IO2......................none
    DO/IO1 (MISO).......... pin 12
    HOLD/IO3...................3,3 V
    DI/IO0 (MOSI).............pin7
    CS............................pin6
    CLK...........................pin14
    VCC..........................3,3 V
    CopyFromSerial
    I just changed (no Audio board):
    //SPI Pins (these are the values on the Audio board; change them if you have different ones)
    //#define MOSI               7
    //#define MISO              12
    //#define SCK               14
    #define CSPIN              6
    //#define CSPIN           21  // Arduino 101 built-in SPI Flash
    void setup(){
      Serial.begin(9600);  //Teensy serial is always at full USB speed and buffered... the baud rate here is required but ignored
      pinMode(13, OUTPUT);
    //  Set up SPI Teensy without audio Card
      SPI.setMOSI(7);  // uncomment these if using the alternate pins
      SPI.setMISO(12);
      SPI.setSCK(14);
    Raw-uploader.py (Python 2.7)
    No change.
    Results on windows command prompt :
    C:\Python27>python "rawfile-uploader.py" "com4" "AABR99.trw"
    Uploading 1 files...
    1: AABR99.trwTraceback (most recent call last):
    File "rawfile-uploader.py", line 80, in <module>
    ser.write("".join(encoded))
    File "C:\Python27\lib\site-packages\serial\serialwin32.py", line 295, in write
    raise writeTimeoutError
    serial.serialutil.SerialTimeoutException: Write timeout
    On Teensy, Led 13 toggles at 1Hz rate.
    I wonder if the problem comes from Windows or from another causes.
    Thanks.
    Do you know if "Raw-uploader.py" goes with Python 2 ou Python 3?
    My configuration is
    Teensy 3.2 + SPI Flash Winbond 25Q64BVSIG (without audioshield)
    Pins used are 11(DOUT),12(DIN),14(SCK),10(CS).
    One File.trw has been loaded in the SPI Flash.
    In order to read the File and send it to DAC, do I need the following data (blacken number)?
    EG:
    const unsigned int AudioSampleSnare = 0xF8A00; //82583__kevoy__snare-drum-4.raw
    const unsigned int AudioSampleTomtom = 0; //86334__zgump__tom-0104.raw
    const unsigned int AudioSampleHihat = 0xD0B00; //102790__mhc__acoustic-open-hihat2.raw
    const unsigned int AudioSampleKick = 0xDCD00; //171104__dwsd__kick-gettinglaid.raw
    const unsigned int AudioSampleGong = 0x9500
    If yes, how can I get these data ?
    Thanks.
  24. #24
    My configuration is
    AR2BR99.TRW has been loaded in the SPI Flash.
    I would like to send this file to the DAC (A14).
    But, there is no sound.
    Do I forget something ?
    #include <SerialFlash.h>
    #define FLASH_CHIP_SELECT 10
    AudioPlaySerialflashRaw  playFlashRaw1;  //xy=114,184
    AudioOutputAnalog        dac1;           //xy=751,337
    AudioConnection          patchCord1(playFlashRaw1, dac1);
      AudioMemory(10);
      analogReference(EXTERNAL);
      SPI.setMOSI(11);
      SPI.setMISO(12);
      SPI.setSCK(14);
        while (!Serial) ;
        if (!SerialFlash.begin(FLASH_CHIP_SELECT)) {
            while (1){
          Serial.println ("Cannot access SPI Flash chip");
          delay (1000);
       playFile("AR2BR99.TRW");
       delay(20000);
          void playFile(const char *filename){
            Serial.print("Playing file: ");
            Serial.println(filename);
            // Start playing the file. This sketch continues to
            // run while the file plays.
            playFlashRaw1.play("AR2BR99.TRW");
            delay(20000);
    I have the impression that it should not be possible (without audio card) to output the sound from the SPI Flash directly to the Teensy DAC (pin A14) by using "playFlashRaw1.play(filename).
    On the PRJC website: https://www.pjrc.com/store/teensy3_audio.html, the Teensy is coupled to an audio card which has an SD player and a slot for soldering a Flash SPI.
    This card has in particular a DAC which must be implemented thanks to the Audio.h library (PlayFlashRaw).
    The Teensy drives the audio card via an I2C bus (SDA - SCL) and the serial bus (Tx - Rx).
    It seems that the PlayRawFlash library can only implement the DAC of the audio card (but not the Teensy DAC).
    Is there a possibility to output the sound of the SPI Flash to the Teensy DAC (A14 output)?
