Results 1 to 2 of 2
Thread: Would I be able to use these with poi
    Jul 2018
    2
    Would any these parts be compatible with any of the existing poi code or with modification
    Build List:
    Teensy 3.6
    Apa102(sk9822) 144M
    128x32 I2C OLED graphic display
    Rotary Encoder - Illuminated (RGB)
    •Functions and operations•
    1. First click turns on device and Display
    2. Scoll thru the menu
    3. Pick animation With Click turning the display off turning the LEDs on
    24,020
    Quote Originally Posted by Slyac3 View Post
    What existing poi code?
    We can't see your screen and we can't read your mind through the internet to discover which code you're asking about.
    I can say those parts generally do work with Teensy, or at least similar ones have been used successfully many times. Again, exactly which parts you mean (like the rotary encoder) aren't clear from the question, so the best I can say is people have used similarly described parts.
    If you'd like help with this project, we're generally pretty good here with helping... but only when your question has details needed to answer. I'm afraid when questions lack essential info, usually they get not much response, or replies like this asking for explanation.
Tags for this Thread
