Results 1 to 3 of 3
Thread: Memory Spikes and Playback Stutters
    Hey All,
    I've been trying to diagnose an issue whereby the Max Processor Usage (see code) suddenly spikes and a loop I have playing from SD will stutter for a second. This cycle continues at a seemingly random interval (spike, stutter, drop to normal, spike, stutter....)
    I am playing a 1 minute loop .WAV file and restarting it after it ends. I have tried different SD cards, different AudioMemory values...nothing seems to affect it. I noticed this in a different sketch, so I put together the basic one below to start from a base to diagnose, and it's happening even with this very simple sketch.
    The output below is written every 1 second. This spike does not happen often...it could be anywhere from 3 to around 10 minutes between occurrences.
Name:	Screen Shot 2018-07-11 at 8.24.38 AM.jpg
    Here is the code I am testing with:
    #include <SerialFlash.h>
    AudioPlaySdWav           loopPlayer;     //xy=383,257
    AudioOutputI2S           i2s2;           //xy=559,260
    AudioConnection          patchCord1(loopPlayer, 0, i2s2, 0);
    AudioControlSGTL5000     audioShield;    //xy=113,275
    elapsedMillis loopMillis;
    unsigned long len = 0;
      Serial.begin(57600);
      delay(250);
      // Always allocate memory for the audio shield!
      AudioMemory(4);
      // turn on audio shield
      audioShield.enable();
      // turn on post processing
      audioShield.audioPostProcessorEnable();
      // Check SD card
      SPI.setMOSI(7);  // Set to 7 for Teensy
      SPI.setSCK(14);  // Set to 14 for Teensy
      // CS Pin is 10..do not change for Teensy!
      if (!(SD.begin(10))) {
      delay(250);
      loopPlayer.play("/loops/breath.wav");
      delay(10);
      len = loopPlayer.lengthMillis();
      loopMillis = 0;
    elapsedMillis timer;
      if (timer >= 1000) {
        timer = 0;
        showMemory();
      if (loopMillis >= len) {
        loopMillis = 0;
        delay(10);
    void showMemory() {
        Serial.println("");
        Serial.print("Proc = ");
        Serial.print(AudioProcessorUsage());
        Serial.print(" (");
        Serial.print(AudioProcessorUsageMax());
        Serial.print("),  Mem = ");
        Serial.print(AudioMemoryUsage());
        Serial.print(" (");
        Serial.print(AudioMemoryUsageMax());
        Serial.print(") ");
        Serial.print("Free Mem: ");
        Serial.println(freeMemory());
        Serial.println("");
    #ifdef __arm__
    // should use uinstd.h to define sbrk but Due causes a conflict
    extern "C" char* sbrk(int incr);
    #else  // __ARM__
    extern char *__brkval;
    #endif  // __arm__
    int freeMemory() {
      char top;
    #ifdef __arm__
      return &top - reinterpret_cast<char*>(sbrk(0));
    #elif defined(CORE_TEENSY) || (ARDUINO > 103 && ARDUINO != 151)
      return &top - __brkval;
    #else  // __arm__
      return __brkval ? &top - __brkval : &top - __malloc_heap_start;
    #endif  // __arm__
    // END
    Also I am using Teensyduino 1.42 with Arduino 1.8.5, Teensy 3.2 and Mac OSX Sierra 10.12.6.
    Any ideas?
    Thank you!
    **** moving to technical support forum ****
