Hello All,
Using the Teensy 3.2 and Teensyview in addition to an SPI based Mouse Sensor.
My issue is when I only have the code setup to run just the Mouse Sensor via SPI it works fine. When I only have something like the Screen Demo example running it also works perfectly. Both applications are the exact same hardware just different code loaded.
When I combine them the mouse sensor stops working. The mouse sensor uses a different SPI mode and I have tried using the transactions with the SPI (https://www.pjrc.com/teensy/td_libs_SPI.html) and that does not seem to work.
What I am wondering is if there is a compatibility issue between the Teensyview library and the standard SPI library. I am thinking that the Teensview usage of the SPI hardware is overriding the standard SPI library??
Anyone have experience using the Teensyview and sharing the SPI bus with other devices? How did you get them to play nice?
Thanks,
Dave
Thanks,
Dave
