Results 1 to 4 of 4
Thread: Pin to port mapping reference for Teensy 3.6?
    Hi, I'm looking for a pin to port mapping reference for the Teensy 3.6. Like, say I use this code:
    PORTA = 0x80;
    Which pins on the Teensy correlate to which bits on what the CPU considers to be port A?
    I need to wire up a 512 KB parallel SRAM chip to gain access to more memory, and access must be very fast. Ideal code would be something like:
    void writeSRAM(uint32_t address, uint8_t value) {
        PORTA = (uint8_t)address;
        PORTB = (uint8_t)(address >> 8);
        PORTC = (uint8_t)(address >> 16);
        PORTD = value;
    Where ports A, B, C connect to the address lines of the SRAM and port D connects to the data lines.
    Thanks!
    21,323
    This thread has the info you seek.
    https://forum.pjrc.com/threads/17532...PIO_PDIR-_PDOR
    Thank you! So, unless I'm reading wrong, none of the GPIO ports have all of their pins broken out on the board?
    21,323
    Quote Originally Posted by Mike Chambers View Post
    That's correct.
    And even if you look at the chip's pinouts, I do not recall any of the 5 ports having all 32 signals.
