Program stops when it encounters FastLED.show()
harald25
I'm suddenly facing an issue where my program running on a Teensy 3.2 stops when it reaches a FastLED.show();
I know this because I moved a serial print through my code, and my print does not get output to the console as soon as I move it after the first occurrence of FastLED.show();
I have some other programs that run fine on the same Teensy.
I haven't used this particular program since last summer, and I have done absolutely no changes since then. So I'm thinking it might be broken after a library update maybe? The program compiles just fine, so I have no error messages to work with.
See the link further down for my code.
- The program enters setup() (line 666)
- Runs down to and enters Ledstrip.BloomingRainbow(); (line 676)
- Then stops at FastLED.show(); (line 522)
(This line is commented out in my code right now, but it's usually not)
https://pastebin.com/LDQiyqa8
Why not post your code here instead of making others go to another web site to see it. Use code tags.
I can do that of course:
#define USE_OCTOWS2811
#include<OctoWS2811.h>
#include<FastLED.h>
#include <SLIPEncodedSerial.h>
#include <OSCMessage.h>
String readString;
// FastLED provides these pre-conigured incandescent color profiles:
//     Candle, Tungsten40W, Tungsten100W, Halogen, CarbonArc,
//     HighNoonSun, DirectSunlight, OvercastSky, ClearBlueSky,
// FastLED provides these pre-configured gaseous-light color profiles:
//     WarmFluorescent, StandardFluorescent, CoolWhiteFluorescent,
//     FullSpectrumFluorescent, GrowLightFluorescent, BlackLightFluorescent,
//     MercuryVapor, SodiumVapor, MetalHalide, HighPressureSodium,
// FastLED also provides an "Uncorrected temperature" profile
//    UncorrectedTemperature;
#define TEMPERATURE UncorrectedTemperature
DEFINE_GRADIENT_PALETTE( pink_gp ) {
   0,     0,   0,   0,    //Black
   25,  255, 255, 255,    //White
  127,  255,  0,  255,    //Pink
  230,  128,  0,  128,   //Purple
  255,    0,  0,    0};    //Black
DEFINE_GRADIENT_PALETTE( heatmap_gp ) {
  0,     0,  0,  0,   //black
85,   255,  0,  0,   //red
170,   255,255,  0,   //bright yellow
255,     0,  0,  0 };  //black
DEFINE_GRADIENT_PALETTE( blink_purple_gp ) {
  0,     0,  0,  0,     //black
100,   255,  0,  255,   //Purple
DEFINE_GRADIENT_PALETTE( blink_orange_gp ) {
  0,     0,  0,  0,     //black
100,   255,  100,  0,   //orange
255,     0,  0,  0};   //black
DEFINE_GRADIENT_PALETTE( bg_orange_gp ) {
  0,     0,  0,  0,     //black
  50,     0,  0,  0,     //black
205,     0,  0,  0,   //black
DEFINE_GRADIENT_PALETTE( blink_bluetones_gp ) {
  0,     0,  0,  0,     //black
64,   33,  180,  226,   //Dark blue
128,   109,  197,  224, //Light blue
192,   33,  180,  226,  //Dark blue
CRGBPalette16 heatcolorPalette = heatmap_gp;
CRGBPalette16 pinkPalette = pink_gp;
CRGBPalette16 blinkPalettePurple = blink_purple_gp;
CRGBPalette16 blinkPaletteOrange = blink_orange_gp;
CRGBPalette16 blinkPaletteBluetones = blink_bluetones_gp;
CRGBPalette16 bgPaletteOrange = bg_orange_gp;
CRGBPalette16 rainbowPalette = RainbowColors_p;
CRGBPalette16 * paletteArray[] = { &blinkPalettePurple, &blinkPaletteOrange, &blinkPaletteBluetones,&heatcolorPalette,&pinkPalette,&bgPaletteOrange, &rainbowPalette};
#define NUM_LEDS_PER_STRIP 203
#define NUM_STRIPS 8
#define BRIGHTNESS 255
CRGB leds[NUM_STRIPS * NUM_LEDS_PER_STRIP];
SLIPEncodedSerial SLIPSerial(Serial1);
enum pattern { NONE, BLOOMING, ENOGEN, TWINKLING, BLOOMING_RAINBOW, RAINBOW_THEATER_CHASE};
enum mode { BLOMST, VU_METER, STREAM };
enum direction { FORWARD, REVERSE };
//LED-strip order
const uint8_t blomst1BunnHullStart = 0;
const uint8_t blomst1ToppHullStart = 1;
const uint8_t blomst1BunnOmrissStart = 2;
const uint8_t blomst1ToppOmrissStart = 3;
const uint8_t blomst2BunnHullStart = 4;
const uint8_t blomst2ToppHullStart = 5;
const uint8_t blomst2BunnOmrissStart = 6;
const uint8_t blomst2ToppOmrissStart = 7;
//Forklaring paa nivaaer i arrayene
//0 = Faktisk index i leds[] arrayen
//1 = Rekkefolge i blooming-animasjonen
//2 = Stilk eller blomst
//3 = Next random blink time
//4 = Index pr LED for hvor den er i random blinkanimasjon
float blomst1Omriss [5][377];
float blomst1Hull [5][290];
float blomst2Omriss [5][377];
float blomst2Hull [5][290];
//Distanse mellom pixler i blomstene
float distanse1 = 1.5;
//startpixel for venstre blomst, bunn
float vb_b = 31.0;
//startpixel for hoyre blomst, bunn
float hb_b = 35.0;
float bunnHullRekkefolge [] = { 0.0,1.0,2.0,3.0,4.0,4.0,5.0,5.0,6.0,6.0,7.0,7.0,8.0,8.0,9.0,9.0,10.0,11.0,10.0,11.0,12.0,13.0,12.5,13.5,14.0,16.0,15.0,17.0,18.0,19.0,20.0,21.0,22.0,23.0,24.0,25.0,26.0,27.0, //Stilk
                    vb_b+(2*distanse1),vb_b+(2*distanse1),vb_b+(3*distanse1),vb_b+(2*distanse1),vb_b+(3*distanse1),vb_b+(2*distanse1),vb_b+(3*distanse1),vb_b+(3*distanse1),vb_b+(1*distanse1),vb_b+(1*distanse1),vb_b+(1*distanse1),vb_b+(3*distanse1), //Blomst venstre
                    28.0,28.0, //Stilk
                    vb_b+(2*distanse1),vb_b+(1*distanse1),vb_b,vb_b+(1*distanse1),vb_b+(1*distanse1),vb_b+(2*distanse1),vb_b+(3*distanse1),vb_b+(2*distanse1),vb_b+(3*distanse1),vb_b+(3*distanse1), //Blomst venstre
                    29.0,29.0,30.0,31.0,32.0,33.0, //Stilk
                    hb_b+(2*distanse1), //Blomst hoyre
                    32.0, //Stilk
                    hb_b+(2*distanse1),hb_b+(2*distanse1),hb_b+(1*distanse1),hb_b+(1*distanse1), //Blomst hoyre
                    33.0, //Stilk
                    hb_b+(2*distanse1),hb_b+(2*distanse1),hb_b+(1*distanse1),hb_b+(1*distanse1),hb_b+(2*distanse1),hb_b+(2*distanse1),hb_b+(1*distanse1),hb_b,hb_b+(1*distanse1),hb_b+(2*distanse1),hb_b+(2*distanse1),hb_b+(2*distanse1) //Blomst hoyre
float distanse2 = 1.5;
//startpixel for blomst1, topp
float b1_t = 37.0;
//startpixel for blomst2, topp
float b2_t = 56.0;
//startpixel for blomst3, topp
float b3_t = 60.5;
//startpixel for blomst4, topp
float b4_t = 61.5;
float toppHullRekkefolge [] = {
  //Stilk
  34,34,
  //Blomst1
  b1_t+(5.5*distanse2),b1_t+(5.5*distanse2),b1_t+(5.5*distanse2),b1_t+(5.0*distanse2),b1_t+(3.0*distanse2),b1_t+(4.0*distanse2),b1_t+(5.0*distanse2),b1_t+(5.5*distanse2),b1_t+(5.5*distanse2),
  b1_t+(5.5*distanse2),b1_t+(5.5*distanse2),b1_t+(5.0*distanse2),b1_t+(4.0*distanse2),b1_t+(5.0*distanse2),b1_t+(5.5*distanse2),b1_t+(5.5*distanse2),b1_t+(5.5*distanse2),b1_t+(5.5*distanse2),
  b1_t+(5.0*distanse2),b1_t+(5.5*distanse2),b1_t+(5.0*distanse2),b1_t+(4.0*distanse2),b1_t+(3.0*distanse2),b1_t+(2.0*distanse2),b1_t+(2.0*distanse2),b1_t+(2.0*distanse2),b1_t+(2.0*distanse2),
  b1_t+(2.0*distanse2),b1_t+(2.0*distanse2),b1_t+(2.0*distanse2),b1_t+(2.0*distanse2),b1_t+(3.0*distanse2),b1_t+(5.5*distanse2),b1_t+(5.0*distanse2),b1_t+(4.0*distanse2),b1_t+(5.0*distanse2),
  b1_t+(5.5*distanse2),b1_t+(5.5*distanse2),b1_t+(5.5*distanse2),b1_t+(5.5*distanse2),b1_t+(5.0*distanse2),b1_t+(3.0*distanse2),b1_t+(4.0*distanse2),b1_t+(5.0*distanse2),b1_t+(5.5*distanse2),
  b1_t+(5.5*distanse2),b1_t+(5.5*distanse2),b1_t+(5.0*distanse2),b1_t+(3.0*distanse2),b1_t+(2.0*distanse2),b1_t+(1.0*distanse2),b1_t+(1.0*distanse2),b1_t+(1.0*distanse2),b1_t,
  b1_t+(1.0*distanse2),b1_t+(1.0*distanse2),b1_t+(1.0*distanse2),b1_t+(2.0*distanse2),b1_t+(2.0*distanse2),b1_t+(2.0*distanse2),b1_t+(4.0*distanse2),b1_t+(5.0*distanse2),b1_t+(5.5*distanse2),
  //Stilk
  40,40.5,41.5,42.5,43,44,44.5,45.5,45.5,46.5,46.5,47.5,47.5,48.5,48.5,49.5,49.5,50.5,50.5,51,51.5,52,53,
  //Blomst2
  b2_t+(2.5*distanse1),b2_t+(2.5*distanse1),b2_t+(2.0*distanse1),b2_t+(2.5*distanse1),b2_t+(2.5*distanse1),b2_t+(2.0*distanse1),b2_t+(2.5*distanse1),b2_t+(1.0*distanse1),b2_t+(1.0*distanse1),
  b2_t+(1.0*distanse1),b2_t,b2_t+(1.0*distanse1),b2_t+(1.0*distanse1),b2_t+(2.0*distanse1),b2_t+(2.5*distanse1),b2_t+(2.5*distanse1),b2_t+(2.0*distanse1),b2_t+(1.0*distanse1),
  //Stilk
  54,53,53,52.5,53.5,53.5,54.5,54.5,55.5,55.5,55.5,56.5,57.5,
  //Blomst 3
  b3_t+(2.5*distanse1),b3_t+(2.5*distanse1),b3_t+(2.5*distanse1),b3_t+(2.5*distanse1),b3_t+(2.5*distanse1),b3_t+(2.5*distanse1),b3_t+(2.0*distanse1),b3_t+(2.5*distanse1),b3_t+(1.0*distanse1),
  b3_t+(1.0*distanse1),b3_t+(2.5*distanse1),b3_t+(2.0*distanse1),b3_t+(1.0*distanse1),b3_t,b3_t+(1.0*distanse1),b3_t+(1.0*distanse1),b3_t+(1.0*distanse1),b3_t+(2.5*distanse1),
  b3_t+(2.5*distanse1),b3_t+(2.0*distanse1),b3_t+(2.5*distanse1),b3_t+(2.5*distanse1),b3_t+(2.0*distanse1),b3_t+(2.5*distanse1),b3_t+(2.5*distanse1),b3_t+(2.0*distanse1),
  //Stilk
  58.5,57.5,56.5,56.5,56.5,57.5,58.5,
  //Blomst4
  b4_t,b4_t+(1.0*distanse2),
  //Stilk
  59.5,
  //Blomst4
  b4_t+(2.0*distanse2),b4_t+(1.0*distanse2),b4_t+(3.0*distanse2),b4_t+(2.5*distanse2),b4_t+(4.0*distanse2),b4_t+(5.0*distanse2),b4_t+(3.0*distanse2),b4_t+(3.5*distanse2),b4_t+(5.0*distanse2),
  b4_t+(5.5*distanse2),b4_t+(5.5*distanse2),b4_t+(5.5*distanse2),b4_t+(5.0*distanse2),b4_t+(5.5*distanse2),b4_t+(6.0*distanse2),b4_t+(6.5*distanse2),b4_t+(7.0*distanse2),b4_t+(7.0*distanse2),
  b4_t+(6.5*distanse2),b4_t+(6.0*distanse2),b4_t+(5.5*distanse2),b4_t+(4.5*distanse2),b4_t+(2.5*distanse2),b4_t+(0.5*distanse2),b4_t+(1.5*distanse2),b4_t+(3.5*distanse2),b4_t+(5.5*distanse2),
  b4_t+(5.7*distanse2),b4_t+(6.0*distanse2),b4_t+(6.5*distanse2),b4_t+(6.5*distanse2),b4_t+(6.0*distanse2),b4_t+(5.0*distanse2),b4_t+(4.5*distanse2),b4_t+(4.0*distanse2),b4_t+(3.0*distanse2),
  //Stilk
  60.5,59.5,58.5,58.0,57
class LedsMultitask
  public:
    pattern ActivePattern1;
    mode ActiveMode;
    direction Direction;
    bool EndOfPattern;
    unsigned long Interval1;
    unsigned long Interval2;
    unsigned long lastUpdate1;
    unsigned long lastUpdate2;
    uint8_t Hue1;
    uint8_t Value1;
    uint8_t Saturation1;
    uint8_t Hue2;
    uint8_t Value2;
    uint8_t Saturation2;
    uint8_t IncrementSat;
    uint8_t IncrementVal;
    float Delta;
    float Index1;
    float Increment_by1;
    float Index2;
    float Increment_by2;
    uint16_t TotalSteps1;
    uint16_t TotalSteps2;
    uint8_t SegmentColorRed;
    uint8_t SegmentColorGreen;
    uint8_t SegmentColorBlue;
    uint8_t NumberOfStrips;
    uint8_t LedsPerStrip;
    uint16_t Pixels;
    boolean UpdatePattern;
    boolean Flash;
    boolean Dim;
    uint8_t PixelDistance;
    uint8_t PixelWidth;
    uint8_t TailLength;
    uint32_t BlinkRandomTime;
    uint32_t NextBlink_LEDi[NUM_LEDS_PER_STRIP * NUM_STRIPS];
    CRGBPalette16 * ActivePalette1;
    CRGBPalette16 * ActivePalette2;
    LedsMultitask(mode displaymode)
        Pixels = NUM_LEDS_PER_STRIP * NUM_STRIPS;
        ActiveMode = displaymode;
    // Update the pattern (hull)
    void Update1()
      Serial.println("Update1");
      if ((millis() - lastUpdate1) > Interval1) // time to update
        lastUpdate1 = millis();
        switch (ActivePattern1)
          case BLOOMING:
            BloomingUpdate();
          case TWINKLING:
              TwinklingUpdate();
          case BLOOMING_RAINBOW:
              BloomingRainbowUpdate();
          case RAINBOW_THEATER_CHASE:
              RainbowTheaterChaseUpdate();
          default:
    // Update the pattern (omriss)
    void Update2()
      if ((millis() - lastUpdate2) > Interval2) // time to update
        lastUpdate2 = millis();
          case BLOOMING:
          case TWINKLING:
            OmrissUpdate();
          default:
    void ResetHull () {
      for (int i = 0; i < 290; i++) {
        leds[(int)blomst1Hull[0][i]] = CRGB::Black;
        leds[(int)blomst2Hull[0][i]] = CRGB::Black;
    void ResetAllLEDs () {
      for (int i = 0; i < NUM_STRIPS*NUM_LEDS_PER_STRIP; i++) {
        leds[i] = CRGB::Black;
    // Increment the Index and reset at the end
    void Increment(float *index, uint16_t *total_steps, float *increment_by)
      *index = *index + *increment_by;
      if (*index >= *total_steps)
        *index = 0;
    void RainbowTheaterChase(direction dir = FORWARD)
      ActivePattern1 = RAINBOW_THEATER_CHASE;
      TotalSteps1 = 290;
      TotalSteps2 = 100;
      Increment_by1 = 1;
      Increment_by2 = 0.5;
      Interval1 = 25;
      Hue1 = 15;
      Hue2 = 160;
      Saturation1 = 255;
      Saturation2 = 255;
      Value1 = 255;
      Value2 = 0;
      Index1 = 0;
      Index2 = 0;
      PixelDistance = 5;
      PixelWidth = 1;
      Direction = FORWARD;
    void RainbowTheaterChaseUpdate()
    uint8_t tail = 0;
    float dist;
      for(int i=0; i< TotalSteps1; i++)
        dist = abs(((blomst1Hull[1][i]) - Index2));
        if (dist < Delta)
          if ((i + (int)Index1) % PixelDistance == 0)
            leds[(int)blomst1Hull[0][i]] = CHSV((i*10)%255, Saturation1, (Delta-dist)*(255/Delta));
            leds[(int)blomst2Hull[0][i]] = CHSV((i*10)%255, Saturation1, (Delta-dist)*(255/Delta));
            tail = PixelWidth;
          else if (tail != 0)
            leds[(int)blomst1Hull[0][i]] = CHSV((((i*10)-(PixelWidth-(tail*3)+1)))%255, Saturation1, (Delta-dist)*(255/Delta));
            leds[(int)blomst2Hull[0][i]] = CHSV((((i*10)-(PixelWidth-(tail*3)+1)))%255, Saturation1, (Delta-dist)*(255/Delta));
            //Serial.println(tail);
            tail--;
            leds[(int)blomst1Hull[0][i]] = CHSV(Hue2, Saturation2, Value2);
            leds[(int)blomst2Hull[0][i]] = CHSV(Hue2, Saturation2, Value2);
        else {
      FastLED.show();
      Increment(&Index1, &TotalSteps1, &Increment_by1);
      Increment(&Index2, &TotalSteps2, &Increment_by2);
    void Blooming()
      ActiveMode = BLOMST;
      ActivePattern1 = BLOOMING;
      //Hull
      Delta = 4;
      Interval1 = 1;
      Index1 = 0;
      Increment_by1 = 0.08;
      TotalSteps1 = 100;
      Hue1 = 50;
      Hue2 = 100;
      Saturation1 = 255;
      //Omriss
      Interval2 = 50;
      Index2 = 0;
      TotalSteps2 = 255;
      Increment_by2 = 1;
      ActivePalette2 = &bgPaletteOrange;
      //Zero all LEDs
      ResetAllLEDs();
      LEDS.show();
      Serial.println("Blooming");
    void BloomingUpdate()
      Serial.println("BloomingUpdate");
      //Hull
      float dist;
      for (int x = 0; x < 290; x++)
        dist = abs(((blomst1Hull[1][x]) - Index1));
        if (dist < Delta)
          if ((int)blomst1Hull[2][x]==0) {
            leds[(int)blomst1Hull[0][x]] = CHSV(Hue1,Saturation1,(Delta-dist)*(255/Delta));
            leds[(int)blomst2Hull[0][x]] = CHSV(Hue1,Saturation1,(Delta-dist)*(255/Delta));
          else {
            leds[(int)blomst1Hull[0][x]] = CHSV(Hue2,Saturation1,(Delta-dist)*(255/Delta));
            leds[(int)blomst2Hull[0][x]] = CHSV(Hue2,Saturation1,(Delta-dist)*(255/Delta));
        else {
          leds[(int)blomst1Hull[0][x]] = CRGB::Black;
          leds[(int)blomst2Hull[0][x]] = CRGB::Black;
      FastLED.show();
    void OmrissUpdate()
      for (int i = 0; i < 377; i++) {
        uint8_t palette_index = (int)Index2+i;
        //leds[(int)blomst1Omriss[0][i]] = CHSV(hue,255,255);
        leds[(int)blomst1Omriss[0][i]] = ColorFromPalette(*ActivePalette2,palette_index);
        leds[(int)blomst2Omriss[0][i]] = ColorFromPalette(*ActivePalette2,palette_index);
      FastLED.show();
    void Twinkling()
      ActivePattern1 = TWINKLING;
      //Hull
      Interval1 = 1;
      Index1 = 0;
      Increment_by1 = 1;
      TotalSteps1 = 255;
      Hue2 = 100;
      BlinkRandomTime = 10000;
      Value1 = 100;
      Saturation2 = 255;
      ActivePalette1 = &blinkPaletteOrange;
      //Omriss
      Interval2 = 50;
      Index2 = 0;
      TotalSteps2 = 255;
      Increment_by2 = 1;
        //Nullstiller index for alle LEDs
        blomst1Hull[4][i] = 0;
        blomst2Hull[4][i] = 0;
        //Gir random startverdier til pixels i blomsterhodene
        NextBlink_LEDi[(int)blomst1Hull[0][i]] = millis()+(random16()%BlinkRandomTime);
        NextBlink_LEDi[(int)blomst2Hull[0][i]] = millis()+(random16()%BlinkRandomTime);
      //Zero all LEDs
      ResetAllLEDs();
      FastLED.show();
      Serial.println("Twinkling");
    void TwinklingUpdate()
        if (blomst1Hull[2][i] == 0 ) //Hvis blomst
          if (millis() >= NextBlink_LEDi[(int)blomst1Hull[0][i]])
            leds[(int)blomst1Hull[0][i]] = ColorFromPalette( *ActivePalette1, (int)blomst1Hull[4][i]);
            leds[(int)blomst2Hull[0][i]] = ColorFromPalette( *ActivePalette1, (int)blomst1Hull[4][i]); //Sets color of LED according to position in ActivePalette
            blomst1Hull[4][i]++; //Increases Index by 1
            blomst2Hull[4][i]++;
            //Checks if we have run through the entire color palette
            if (blomst1Hull[4][i] >= TotalSteps1)
              blomst2Hull[4][i] = 0;                                            //Resets the index to 0
              NextBlink_LEDi[(int)blomst1Hull[0][i]] = (millis()+(random16()%BlinkRandomTime));      //Generates a new time for the next blink
              NextBlink_LEDi[(int)blomst2Hull[0][i]] = (millis()+(random16()%BlinkRandomTime));
        {  //Hvis stilk
          leds[(int)blomst1Hull[0][i]] = CHSV(Hue2,Saturation2,Value1);
          leds[(int)blomst2Hull[0][i]] = CHSV(Hue2,Saturation2,Value1);
      FastLED.show();
    void BloomingRainbow()
      //Hull
      Interval1 = 30;
      ActivePattern1 = BLOOMING_RAINBOW;
      Value1 = 255;
      Saturation1 = 255;
      Saturation2 = 0;
      TotalSteps1 = 100;
      Index1 = 0;
      Increment_by1 = 1;
      Delta = 4;
      //Omriss
      ActivePalette2 = &rainbowPalette;
      //Zero all LEDs
      ResetAllLEDs();
      FastLED.show();
      Serial.println("BloomingRainbow");
    void BloomingRainbowUpdate()
      //Hull
      float dist;
        if (dist < Delta) {
            leds[(int)blomst1Hull[0][x]] = CHSV((int)(Index1+x)%255,Saturation1,(Delta-dist)*(255/Delta));
            leds[(int)blomst2Hull[0][x]] = CHSV((int)(Index1+x)%255,Saturation1,(Delta-dist)*(255/Delta));
          else {
        else {
      FastLED.show();
      Serial.println("BloomingRainbowUpdate");
    void updateInterval(unsigned long interval)
      Interval1 = interval;
    void updateValue1(uint8_t value)
      Value1 = value;
    void updateValue2(uint8_t value)
      Value2 = value;
    void updateHue1(uint8_t hue)
      Hue1 = hue;
    void updateHue2(uint8_t hue)
      Hue2 = hue;
    void updateSaturation1(uint8_t sat)
      Saturation1 = sat;
    void updateSaturation2(uint8_t sat)
      Saturation2 = sat;
    void updatePatternFunction()
      UpdatePattern = 1;
    void updateColor1(uint8_t x, uint8_t y)
      Saturation1 = x;
      Hue1 = y;
    void updateColor2(uint8_t x, uint8_t y)
      Saturation2 = x;
      Hue2 = y;
    void changeActiveMode(int x)
      switch (x)
        case 1:
        case 2:
          ActiveMode = VU_METER;
        case 3:
          ActiveMode = STREAM;
        default:
    void changeDirection(uint8_t x)
      switch (x)
        case 1:
        case 2:
          Direction = REVERSE;
        default:
    void updatePixelDistance(uint8_t x)
      PixelDistance = x;
    void updatePixelWidth(uint8_t x)
      PixelWidth = x;
    void updateTailLength(uint8_t x)
      TailLength = x;
    void updateBlinkRandomTime(uint32_t x)
      BlinkRandomTime = x;
    void SetActivePalette1(int x) {
      ActivePalette1 = paletteArray[x];
      ResetHull();
    void SetActivePalette2(int x) {
      ActivePalette2 = paletteArray[x];
LedsMultitask Ledstrip(BLOMST);
  Serial.begin(9600);         //Teensy <=> Computer
  SLIPSerial.begin(115200);   //Teensy <=> ESP
  Serial.println("Started");
  FastLED.addLeds<OCTOWS2811>(leds, NUM_LEDS_PER_STRIP).setCorrection( TypicalSMD5050 );
  FastLED.setTemperature( TEMPERATURE );
  LEDS.setBrightness(BRIGHTNESS);
  LedArrayMaker();
  //Reset all LEDs
  for (int i = 0; i < NUM_LEDS_PER_STRIP*NUM_STRIPS;i++) {
  FastLED.show();
  Serial.println("loop");
  //OSCMsgReceive();
  //Ledstrip.Update1();
  //Ledstrip.Update2();
  while (Serial.available())
    Serial.println("Reading serial");
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0)
    Serial.println(readString);  //so you can see the captured string
    int n = readString.toInt();  //convert readString into a number
    Serial.print("Lyser opp LED nr: ");
    Serial.println(n);
      if (i == n) {
        leds[(int)blomst1Hull[0][i]] = CRGB::White;
      else {
    FastLED.show();
  readString=""; //empty for next input
void OSCMsgReceive()
  OSCMessage msgIN;
  int size;
  static unsigned long microsTime = 0;
  while (!SLIPSerial.endofPacket())
    if ((size = SLIPSerial.available()) > 0)
      microsTime = micros();
      while (size--)  //this needs a byte limit
        msgIN.fill(SLIPSerial.read());
    if ((micros() - microsTime) > 10000) break; //Timeout for no eoP()
  if(!msgIN.hasError())
    //Serial.println("Routing OSC message");
    msgIN.route("/Mode",changeLEDMode);
    msgIN.route("/Fader",funcValue);
void changeLEDMode(OSCMessage &msg, int addrOffset ){
  //Serial.println("Changing LED mode");
  //PROGRAMS
  if(msg.fullMatch("/Mode/blooming"))
    Ledstrip.Blooming();
    FastLED.delay(20);
  if(msg.fullMatch("/Mode/twinkling"))
    Ledstrip.Twinkling();
    FastLED.delay(20);
  if(msg.fullMatch("/Mode/blooming_rainbow"))
    FastLED.delay(20);
  if(msg.fullMatch("/Mode/rainbow_theater"))
    Ledstrip.RainbowTheaterChase();
    FastLED.delay(20);
  //PARAMETERS
  if(msg.fullMatch("/Mode/direction"))
    float value = msg.getFloat(0);
    Ledstrip.changeDirection((int)value);
  //DISPLAY MODES
  if(msg.fullMatch("/Mode/displaymode/blomst"))
    Ledstrip.changeActiveMode(1);
  if(msg.fullMatch("/Mode/displaymode/vu_meter"))
    Ledstrip.changeActiveMode(2);
  if(msg.fullMatch("/Mode/displaymode/stream"))
    Ledstrip.changeActiveMode(3);
void funcValue(OSCMessage &msg, int addrOffset ){
  //OSCMessage msgOUT("/Fader");
  Ledstrip.updatePatternFunction();
  // INTERVAL
  if (msg.fullMatch("/Fader/interval"))
    Ledstrip.updateInterval((int)value);
  // Value (brightness)
  if (msg.fullMatch("/Fader/value1"))
    Ledstrip.updateValue1((int)value);
  if (msg.fullMatch("/Fader/value2"))
    Ledstrip.updateValue2((int)value);
  // HUE
  if (msg.fullMatch("/Fader/hue1"))
    Ledstrip.updateHue1((int)value);
  if (msg.fullMatch("/Fader/hue2"))
    Ledstrip.updateHue2((int)value);
  // SATURATION
  if (msg.fullMatch("/Fader/saturation1"))
    Ledstrip.updateSaturation1((int)value);
  if (msg.fullMatch("/Fader/saturation2"))
    Ledstrip.updateSaturation2((int)value);
  // COLOR (will replace hue and saturation)
  if (msg.fullMatch("/Fader/color1"))
    float x = msg.getFloat(0);
    float y = msg.getFloat(1);
    Ledstrip.updateColor1((uint8_t)x, (uint8_t)y);
  if (msg.fullMatch("/Fader/color2"))
    Ledstrip.updateColor2((uint8_t)x, (uint8_t)y);
  if (msg.fullMatch("/Fader/palette1"))
    int x = (int)msg.getFloat(0);
    if (x != -1) {
      Ledstrip.SetActivePalette1(x);
  if (msg.fullMatch("/Fader/palette2"))
    if (x != -1) {
      Ledstrip.SetActivePalette2(x);
void LedArrayMaker()
  //Hull bunn, begge blomster
  for (int i = 0; i < 87; i++) {
    blomst1Hull[0][i] = (blomst1BunnHullStart*NUM_LEDS_PER_STRIP)+i;
    blomst2Hull[0][i] = (blomst2BunnHullStart*NUM_LEDS_PER_STRIP)+i;
    blomst1Hull[1][i] = bunnHullRekkefolge[i];
    blomst2Hull[1][i] = bunnHullRekkefolge[i];
    //Definerer hva som er blomster
    if ( ((i > 37) && (i < 50)) || ((i > 51) && (i < 62)) ) {
      blomst1Hull[2][i] = 0;
      blomst2Hull[2][i] = 0;
    else if ( (i==68) || ((i>69) && (i<74)) || ((i>74)&&(i<87)) ) {
    //Definerer hva som er stilk
    else {
      blomst1Hull[2][i] = 1;
      blomst2Hull[2][i] = 1;
  //Hull topp, begge blomster
  for (int i = 0; i < 203; i++) {
    int x = 87 + i;
    blomst1Hull[0][x] = (blomst1ToppHullStart*NUM_LEDS_PER_STRIP)+i;
    blomst2Hull[0][x] = (blomst2ToppHullStart*NUM_LEDS_PER_STRIP)+i;
    blomst1Hull[1][x] = toppHullRekkefolge[i];
    blomst2Hull[1][x] = toppHullRekkefolge[i];
    if ( ((x>88) && (x<154)) || ((x>176) && (x<200)) || ((x>212) && (x<239)) || ((x>245) && (x<248)) || ((x>248) && (x<285)) ) {
      blomst1Hull[2][x] = 0;
      blomst2Hull[2][x] = 0;
    else {
      blomst1Hull[2][x] = 1;
      blomst2Hull[2][x] = 1;
  //Omriss blomst1 bunn
  for (int i = 0; i < 187; i++) {
    blomst1Omriss[0][i] = (blomst1BunnOmrissStart*NUM_LEDS_PER_STRIP)+i;
  //Omriss blomst1 topp
  for (int i = 0; i < 189; i++) {
    blomst1Omriss[0][i+188] = (blomst1ToppOmrissStart*NUM_LEDS_PER_STRIP)+i;
  //Omriss blomst2 bunn
    blomst2Omriss[0][i] = (blomst2BunnOmrissStart*NUM_LEDS_PER_STRIP)+i;
  //Omriss blomst2 topp
    blomst2Omriss[0][i+188] = (blomst2ToppOmrissStart*NUM_LEDS_PER_STRIP)+i;
Wow, that's a lot of code and it uses a lot of memory. I'd be surprised if someone unfamiliar with it will be able to spot what's happening. If it were my project, I'd start from scratch and slowly add in sections from the existing code building it up in stages. Compile and test along the way. Maybe you'll be able to spot where things go bad.
My suggestion would be to back out the changes to the FastLED library one by one until it works again. Edit: It may also be in any other library used that changed over that time period.
I ran into an issue with FestLED.show() failing when it was in the main loop() with threads running. It is intermittent. https://forum.pjrc.com/threads/53008-Lockups-with-FastLED-amp-TeensyThreads I haven't had time to debug it yet, just make a workaround where I stuck it into a thread with a time slice long enough for it to complete.
I've figured it out with help from the creator of FastLED. He replied on FastLEDs google+ group.
His guess was that my gigantic arrays with LED data ended up overlapping some of the memory allocated by the OctoWS2811 thus causing wierd problems.
And this seems to be correct, because when I deleted some arrays that I didn't really need the program started running again.
Good to hear you got it running.
I did not have chance to look at it on pc and compile it, but was wondering what the compiler summary said about data usage.
I could not tell in my quick look if any maybe many of these arrays were constant and or could be defined to be, which would move them out of the data space and into code space...
This is something I haven't thought about, but there's definitely some of the arrays that could be defined as constants.
The good news is all you have to do is put "const" in the array definition and the linker will place it only in the flash memory, saving precious RAM.
