Results 1 to 3 of 3
Thread: Writing and reading large struct to and from SD card
    Jan 2017
    Maastricht
    118
    I've come with some code for storing a struct to SD card and reading it again, it al seems to work but I can't believe that it's really this simple.
    The context is a midi step & pattern sequencer I'm working on. Here's a picture of the test setup:
    The complete code for the master Teensy: SPS-8_Master_180712.zip
    The motor fader panel is controlled by a separate Teensy.
    The data for the channels, patterns and steps are stored in structs:
    #define MIN_TEMPO 10                        // Minimum allowed tempo
    #define MAX_TEMPO 250                       // Maximum tempo setting
    #define MAX_STEPS 8                         // number of steps in pattern
    #define MAX_PATTERNS 8                      // number of patterns in program
    #define NUM_OF_PARAMETERS 6                 // number of step paramaters
    #define NUM_OF_CHANNELS 4                   // number of sequencer channels
    // type enumerations
    enum            stepParameters{NOTE,VELOCITY,LENGTH,POSITION,CTRLA,CTRLB};   // enumeration of all step parameters
    enum            controlTypes {NONE,CTRL,NRPN,MWISYSEX,TEMPODIV};             // control types
    // struct for sequencer step
    struct zeusStep{
      int   value[NUM_OF_PARAMETERS];           // array for parameter values, order as in enum stepParameters. Type is int to handle NRPN control values
      bool  active;                             // boolean indicating if step is active i.e. the note should be played
    typedef struct zeusStep ZeusStep;
    struct zeusControllerEvent{
      int           value;
      bool          smoothing;        // indicates if smoothing is active for this controller
      unsigned int  smoothInterval;   // smoothing interval in milliseconds for controller smoothing
      unsigned int  smoothCount;      // number of smoothing events
      int           smoothStep;       // step value, one if possible, larger there is not enough time to the next step
      elapsedMillis smoothingTimer;   // timer for controller smoothing events
    typedef struct zeusControllerEvent ZeusControllerEvent;
    // controller definition
    struct zeusController{
      char      name[16]={' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' '};     // name of definition e.g. Prophet LP Cutoff, OB-6 filter mode etc.
      byte      type;         // controller type, can be CTRL, NRPN, MWISYSEX etc.
      int       number;       // controller number, int type for NRPN handling
      int       minValue;     // minimum allowed value
      int       maxValue;     // maximum allowed value
      byte      midiChannel;  // midi channel for controller
      bool      smoothing;    // smoothing of controller values by interpolation between steps, default is false
    typedef struct zeusController ZeusController;
    // struct for sequencer pattern
    struct  zeusPattern{
      ZeusStep        step[MAX_STEPS];                // array containing steps
      byte            repeat;                         // number of times pattern will be repeated
      byte            next;                           // next pattern to be played after last repeat
      int             length;                         // number of steps in pattern
      float           tempoDevide;                    // tempo devision, for half, quarter, π etc. and also 0.5 for double
      byte            noteMidiChannel;                // midi channel for note events
      ZeusController  control[2];                     // controller definitions for pattern
    typedef struct zeusPattern ZeusPattern;
    // struct for holding data for next step event
    struct zeusStepEvent{
      int                 pitch;                      // pitch is required for sending correct note off if step data is transposed in the meantime
      int                 velocity;                   // velocity value
      int                 length;                     // length in percent, used for legato play
      int                 position;                   // position
      ZeusControllerEvent controlEvent[2];            // control events
      int                 pattern;                    // pattern to handle pattern switching
      bool                playing;                    // note is playing and waiting for note off
      bool                pending;                    // note is pending timed note on event, independent of playing to support legato play
      unsigned long       noteOnTime;                 // planned time in milliseconds for note off event,used for active event if event is between clock ticks
      unsigned long       noteOffTime;                // planned time in milliseconds for note off event,used for active event
    typedef struct zeusStepEvent ZeusStepEvent;
    // struct for sequencer channel
    struct zeusChannel{
      ZeusPattern   pattern[MAX_PATTERNS];      // array of patterns
      byte          currentPattern;             // current (playing) pattern
      byte          currentRepeat;              // current repeat of pattern
      byte          nextPattern;                // next pattern, can override setting stored in pattern, also used for 'hold mode'
      byte          currentStep;                // current step current pattern
      float         nextStepTime;               // time in clock ticks when next step is to occur
      float         nextStepShift;              // time in clock ticks the next step has been shifted, used for calculating the subsequent step
      ZeusStepEvent currentEvent;               // current event, used for checking if note off needs to be sent
      bool          active;                     // indicates if channel is active or muted
    typedef struct zeusChannel ZeusChannel;
    int             selectedParameter=NOTE;
    int             selectedChannel=0;
    int             selectedPattern=0;
    ZeusChannel     sequencerChannel[NUM_OF_CHANNELS];
    float           sequencerTempo=120;                                                 // tempo as float
    float           externalTempo;                                                      // tempo of incoming midisync
    unsigned long   sixteenthNote;                                                      //  length of a sixteenth note in milliseconds
    int             meterNumerator;
    int             meterDenominator;
    bool            sequencerRunning=false;                                             // status of sequencer
    elapsedMillis   midiTimer;                                                          // timer for midi clock, used to calculate tempo
    bool            externalSync;                                                       // true is there is a midi clock signal
    int             externalSyncCounter;                                                // needed because midi beat clock stabilises after the first two ticks
    bool            waitForClock=false;                                                 // used to start sequencer at first incoming clock event
    elapsedMicros   internalTimer;                                                      // internal clock tick timer
    unsigned int    tickInterval;                                                       // tick interval in microseconds. Set by internal tempo or external clock, used for shift and length calculations
    unsigned int    clockTick=0;                                                        // clock tick counter, 96 ticks per note
    The toplevel is a channel. The number of channels , patterns and step does not change. The SDFat library is used:
    #include "SdFat.h"
    SdFatSdioEX SD;
    File dataFile;
    For saving and loading I came up with this:
    void saveProgram(){
      int structSize=0;
      int result;
      // open file for writing
      dataFile = SD.open("TEST.DAT", FILE_WRITE);
      for (int i=0;i<NUM_OF_CHANNELS;i++){
        structSize=sizeof(sequencerChannel[i]);
        Serial.print("Size\t");
        Serial.print(structSize);
        result=dataFile.write(&sequencerChannel[i],structSize);
        Serial.print("\tWrite\t");
        Serial.println(result);
      dataFile.close();
    void loadProgram(){
      int structSize=0;
      int result;
      dataFile = SD.open("TEST.DAT");
        result=dataFile.read(&sequencerChannel[i],structSize);
        Serial.print("\tRead\t");
      dataFile.close();
    The output on the serial monitor:
    Size	2592	Write	2592
    Size	2592	Read	2592
    Size	2592	Read	2592
    Size	2592	Read	2592
    Size	2592	Read	2592
    Am I missing something? Is it really this simple?
    Jan 2017
    Maastricht
    118
    Turned out that my test was to simple, I forgot to seek to the correct position.
    void saveProgram(){
      int structSize=0;
      int result;
        dataFile.seek(i*structSize);
      dataFile.close();
    void loadProgram(){
      int structSize=0;
      int result;
      dataFile.close();
    Now I can restore the data after the power has been off.
