Using "amp" from Audio.h
C0d3man
[SOLVED] Using "amp" from Audio.h
Hi forum,
I have a little problem using the simple "amp" after a queue:
When trying to set amp1.gain(0.5); inside setup() the Teensy freezes. Without setting initial values I get crackling noise. Without amps it works... Can I use the amps directly after a queue?
I tried to create a pan feature with the amps. The same problems happens when using a mixer-object.
I am using Teensy 1.42 on Arduino-IDE-1.8.5.
Regards, Holger
Solved by myself... simple solution: I had too few AudioMemory allocated (only 2) - works when using
  AudioMemory(4);
Regards, Holger
Do the problems happen if you use an ordinary (non queue) source like a SD wav player or waveforms synth?
Edit: oh, I see it's solved. Good. :)
