Results 1 to 22 of 22
Thread: Audio Expander for Teensy
    Senior Member Sandro's Avatar
    Nov 2016
    Rimini - Italy
    101
    Hi all,
    thanks to the community Pjrc I've been able to develop this Library for an Expander with ADSR envelope filter integrated, which appears working very fine.
    I started using Teensy 3.2, good for speed <= 2x"original speed"; than I moved to Teensy 3.6 which seems to ensure poliphony=4 (up to 4 keys simultaneously pressed) using up to 7x"original speed". Here's my code; I'm very proud of it but, since I expose it to this community, I apologize for my naive code: I'm a biginner with coding... Anyhow, I hope you guys will appreciate my work .
    This is Audio_expander_serialflash_raw.h:
    /* Audio Library for Teensy 3.X
     * Copyright (c) 2014, Paul Stoffregen, paul@pjrc.com
     * Modified to use SerialFlash instead of SD library by Wyatt Olson <wyatt@digitalcave.ca>
     * Development of this audio library was funded by PJRC.COM, LLC by sales of
     * Teensy and Audio Adaptor boards.  Please support PJRC's efforts to develop
     * open source software by purchasing Teensy or other PJRC products.
     * THE SOFTWARE.
    /* Audio Expander Serialflash raw
     * Functions/commands:
     * - play("filename.raw") plays audio .RAW files from flash ROM memory chip.
     * - set_speed(speed_value, velocity_value) set speed (pitch) and velocity (in the MIDI sense).
     * - set_adsr(attack_time, decay_time, sustain_value, release_time) set ADSR envelope filter.
     * - release_note() is the release command.
     * - time_lapse() allows to check the computation time of each update() cycle.
     * - is_playing() useful to monitor the state of the instance.
     * The computation time of each update() cycle MUST be within 2,9 ms; computation depends on how
     * many samples have to be read from flash memory, and depends to "speed" value (high speeds require
     * many samples to be read each update() cycle. I experimented that up to 4 simultaneously-playing instances
     * can run on Teensy 3.6, overclock 240MHz, if speed is limited to 7.0.
     * Please send play command after set_speed and set_adsr commands.
     * Author: Sandro Grassia (Rimini, IT).
    #ifndef Audio_expander_serialflash_raw_h_
    #define Audio_expander_serialflash_raw_h_
    #include "Arduino.h"
    #include <AudioStream.h>
    class Audio_expander_serialflash_raw : public AudioStream
    public:
        Audio_expander_serialflash_raw(void) : AudioStream(0, NULL)
            begin();
        void begin(void);
        bool play(const char *filename);
        void set_speed(float speed_value, float velocity_value);
        void stop(void);
        bool isPlaying(void)
            return playing;
        uint32_t positionMillis(void);
        uint32_t lengthMillis(void);
        virtual void update(void);
        int time_lapse(void);
        void set_adsr(float attack_time, float decay_time, float sustain_value, float release_time);
        void release_note(void);
        bool is_playing(void);
    private:
        SerialFlashFile rawfile;
        uint32_t file_size;
        volatile uint32_t file_offset;
        volatile bool playing;
        int16_t ride; // update() cycle
        int32_t first_index_to_read, last_index_to_read, J1, J2, J3, J4, DJ3_4; // indexes of samples
        int16_t penultimate_sample, last_sample, last_value;  // values of samples
        float speed; // 0.5=half speed 1=original speed 2=double speed
        float velocity;	// velocity in MIDI sense; 0 <= velocity <= 1.0
        int64_t t, t_0; // t is the computational time, MUST be within 2902 microseconds (period of update() when 128 samples are required)
        float C1, C2, C3, gain, gain_0, sustain;    // coefficients for ADSR
        int8_t start_release;
        const float Alpha=1.0/44100.0;
    This is Audio_expander_serialflash_raw.cpp. I included a linear ADSR envelope filter because I had problems (glitches) with the "envolope" filter available in Audio Library, that I could not remove. This is my code:
     * THE SOFTWARE.
    #include <Arduino.h>
    #include "Audio_expander_serialflash_raw.h"
    #include "spi_interrupt.h"
    void Audio_expander_serialflash_raw::begin(void)
        last_value=0;
        playing = false;
        file_offset = 0;
        file_size = 0;
    void Audio_expander_serialflash_raw::set_speed(float speed_value, float velocity_value)
        speed = ((speed_value>=0.01)? ((speed_value<=7.0)? speed_value : 7.0) : 0.01) ; // set speed value within limits
        velocity = velocity_value;
    bool Audio_expander_serialflash_raw::play(const char *filename)
        stop();
        ride = -1; // set "very first" ride!
        start_release=0; // allows ADRS to start
        AudioStartUsingSPI();
        rawfile = SerialFlash.open(filename);
        if (!rawfile)
            AudioStopUsingSPI();
            return false;
        file_size = rawfile.size();
        file_offset = 0;
        playing = true;
        return true;
    void Audio_expander_serialflash_raw::stop(void)
        __disable_irq();
        if (playing)
            playing = false;
            __enable_irq();
            rawfile.close();
            __enable_irq();
    void Audio_expander_serialflash_raw::update(void)
        unsigned int i, n;
        audio_block_t *block;
        int16_t samples_vector[1280]; 	// current vector of samples read from file
        int32_t h, k, j; 				// indexes of samples
        float virtual_index; 			// likely not integer index
        float index_delta; 				// mantissa of virtual_index
        int16_t h_sample_value, k_sample_value; // samples value
        int f, g, w;
        int16_t samples_to_read;
        int16_t x_index_delta; 			// mantissa of virtual_index
        float Cx;
        // only update if we're playing
        if (!playing)
            return;
        // allocate the audio blocks to transmit
        block = allocate();
        if (block == NULL)
            return;
        if (rawfile.available())
            // this first ride makes a linear ramp which connects the last sample sent to 0, which is (expected to be) the value of the first sample of the .RAW file to be played
            if (ride<0)
                Cx=last_value>>7;
                for (i=0; i < AUDIO_BLOCK_SAMPLES; i++)
                    block->data[i]=last_value-(Cx*(i+1));
                last_value=block->data[127];
            // from this poin samples are taken from the .RAW file
            else if (ride>=0)
                t_0 = micros(); // start counting the computational time
                first_index_to_read = ((ride==0)? 0 :last_index_to_read+1);
                last_index_to_read = ceil(((ride*AUDIO_BLOCK_SAMPLES)+AUDIO_BLOCK_SAMPLES-1)*speed); // last_index_to_read=ceil(((ride*128)+127)*speed);
                samples_to_read = last_index_to_read-first_index_to_read+1;
                // this part of code reads from file up to 128 samples per time; if we read more than 128 samples there are errors!. The result is the samples_vector[samples_to_read]
                f = samples_to_read % AUDIO_BLOCK_SAMPLES;
                g = samples_to_read >> 7;
                // read one group of "f" samples
                n = rawfile.read(block->data, f<<1);
                file_offset += n;
                for (i = n>>1; i < f; i++)
                    block->data[i] = 0;
                for (i = 0; i < f; i++)
                    samples_vector[i]=block->data[i];
                // read "g" groups of 128 samples
                for (w = 0; w<g; w++)
                    n = rawfile.read(block->data, AUDIO_BLOCK_SAMPLES << 1);
                    file_offset += n;
                    for (i = n/2; i < AUDIO_BLOCK_SAMPLES; i++)
                        block->data[i] = 0;
                    for (i = 0; i < AUDIO_BLOCK_SAMPLES; i++)
                        samples_vector[f+(w<<7)+i]=block->data[i];
                // samples_vector[samples_to_read] is ready!
                // calculating block->data[128] to be sent to the output Connection
                for (i = 0; i<AUDIO_BLOCK_SAMPLES; i++)
                    j = i+(AUDIO_BLOCK_SAMPLES*ride);
                    virtual_index=(float)(j)*speed; // index of the needed sample, usually not-integer
                    h = (int32_t)(virtual_index); // index of the lower sample needed for calculation
                    k = ceil(virtual_index); // index of the upper sample needed for calculation
                    index_delta = virtual_index-h; // mantissa
                    x_index_delta = index_delta*1024.0;
                    h = h-first_index_to_read;  // lower (relative) index of the sample needed for calculation
                    k = k-first_index_to_read;  // higher (relative) index of the sample needed for calculation
                    h_sample_value =((h==-2)? penultimate_sample: ((h==-1)? last_sample: samples_vector[h]));  // value of the lower sample needed for calculation
                    k_sample_value =((k==-2)? penultimate_sample: ((k==-1)? last_sample: samples_vector[k]));  // value of the upper sample needed for calculation
                    if(start_release == 0 && j<J1) // attack procedure
                        gain = C1*j;
                    else if (start_release==0 && j<J2) // decay procedure
                        gain = (C2*(j-J1))+1.0;
                    else if (start_release==1 && j<J4) // release procedure
                        gain = (C3*(j-J3))+gain_0;
                    if (start_release==1 && j>=J4) // stop player!
                        stop();
                    block->data[i]=gain*velocity*(h_sample_value + ((x_index_delta*(k_sample_value-h_sample_value))>>10));
                last_value = block->data[127];
                penultimate_sample = samples_vector[k-1]; // value of the penultimate sample read from file will be used in the next ride
                last_sample = samples_vector[k]; // value of the last sample read from file will be used in the next ride
            ride ++;
            t = micros()-t_0; // calculating the computational time "t"
            transmit(block);
            rawfile.close();
            playing = false;
        release(block);
    #define B2M (uint32_t)((double)4294967296000.0 / AUDIO_SAMPLE_RATE_EXACT / 2.0) // 97352592
    uint32_t Audio_expander_serialflash_raw::positionMillis(void)
        return ((uint64_t)file_offset * B2M) >> 32;
    uint32_t Audio_expander_serialflash_raw::lengthMillis(void)
        return ((uint64_t)file_size * B2M) >> 32;
    int Audio_expander_serialflash_raw::time_lapse(void) // reporting the computational time "t"
        return t;
    void Audio_expander_serialflash_raw::set_adsr(float attack_time, float decay_time, float sustain_value, float release_time) // ***** set ADSR parameters. Times are in seconds. 0 <= sustain_value <= 1.0
        attack_time=((attack_time>0.05)? attack_time : 0);
        C1 = ((attack_time >0.05)? Alpha/attack_time : 0);
        decay_time=((decay_time>0.05)? decay_time : 0.05);
        C2 = (sustain_value-1.0) * Alpha/decay_time;
        J1 = ((attack_time>0.05)? 1.0/C1: 0);
        J2 = (attack_time + decay_time)/Alpha;
        release_time = ((release_time>0.05)? release_time : 0.05);
        DJ3_4 = release_time/Alpha;
    void Audio_expander_serialflash_raw::release_note(void)
        gain_0 = gain;
        J3 = ride*AUDIO_BLOCK_SAMPLES;
        J4 = J3+DJ3_4;
        C3 = -gain_0/DJ3_4;
        start_release = 1;
    bool Audio_expander_serialflash_raw::is_playing(void) // checking if the object is playing
        return playing;
    An example of code for a MIDI Expander with poliphony 4, which is running (fine!) on my Teensy 3.6 with Audio Adaptor and W25Q128FV flash memory chip.
    In my application I use few external potentiometers to set ADSR:
       MIDI Expander
       Teensy 3.6 + Audio Adaptor Board + W25Q128FV flash memory chip
    #include <MIDI.h> // https://www.pjrc.com/teensy/td_libs_MIDI.html
    #include <Audio_expander_serialflash_raw.h>
    #define voices 4
    Audio_expander_serialflash_raw  voice[voices];
    AudioMixer4              mixer1;
    AudioOutputI2S           audio_out;
    AudioConnection          patchCord1(voice[0], 0, mixer1, 0);
    AudioConnection          patchCord2(voice[1], 0, mixer1, 1);
    AudioConnection          patchCord3(voice[2], 0, mixer1, 2);
    AudioConnection          patchCord4(voice[3], 0, mixer1, 3);
    AudioConnection          patchCord5(mixer1, 0, audio_out, 1);
    AudioConnection          patchCord6(mixer1, 0, audio_out, 0);
    AudioControlSGTL5000     board;
    int note_number;
    float velocity;
    float note_number_to_pitch[128];
    int i;
    int pot_value[10][2];
    unsigned long voice_timer[voices];
    int key_played_by[voices];
    float gain_0 = 1.0 / voices;
    int w;
    float attack_time, decay_time, sustain_value, release_time;
    MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
    const int channel = 1; // canale MIDI
      MIDI.begin(MIDI_CHANNEL_OMNI);
      Serial.begin (9600);
      AudioMemory(30);
      /* AudioMemory: allocate the memory for all audio connections. The numberBlocks input specifies how much memory to reserve for audio data.
        Each block holds 128 audio samples, or approx 2.9 ms of sound. Usually an initial guess is made for numberBlocks and the actual
        usage is checked with AudioMemoryUsageMax().
      // inizializzazione Audio Adaptor
      board.enable();
      board.volume(1.0);
      // inizializzazione mixer
      mixer1.gain(0, gain_0);
      mixer1.gain(1, gain_0);
      mixer1.gain(2, gain_0);
      mixer1.gain(3, gain_0);
      // set up SPI Teensy to SPI Flash....if you are using different pins set them here
      SPI.setMOSI(7);
      SPI.setMISO(12);
      SPI.setSCK(14);
      SerialFlash.begin(6);
      for (i = 0; i < voices; i++) {
        voice[i].set_adsr(0, 2, 1, 0.2);
        voice_timer[i] = 0;
      // note number to speed, conversion constants
      for (i = 0; i < 128; i++) {
        note_number_to_pitch[i] = pow(2.0, (i - 60.0) / 12.0); // vettore per la conversione da note number a pitch
      if (MIDI.read()) {
        switch (MIDI.getType()) {
          case midi::NoteOn:
            note_number = MIDI.getData1();
            velocity = MIDI.getData2() / 127.0;
            // Serial.println (note_number);
            // Serial.println (note_number_to_pitch[note_number]);
            play_note(note_number, velocity);
          case midi::NoteOff:
            release_voice(note_number);
          default:
      w++;
      if (w == 100000) {
        int i;
        int u = 0;
          u += voice[i].time_lapse();
        Serial.println (u);
        w = 0;
        attack_time = 5 * analogRead(34) / 1023.0;
        decay_time = 2 * analogRead(35) / 1023.0;
        sustain_value = analogRead(36) / 1023.0;
        release_time = 10 * analogRead(37) / 1023.0;
    // play note
    void play_note(int note_number, float velocity) {
      unsigned long minimum_time = voice_timer[0];
      int i;
      int ii = 0;
      for (i = 0; i < voices; i++) { // first test: if the same key is played we use the same voice
        if (key_played_by[i] == note_number) {
          ii = i;
        if (voice[i].is_playing() == false) { // second test choice: look for a voice not busy
          ii = i;
        if (voice_timer[i] < minimum_time ) { // final test choice: look for the voice playing for the longest time
          minimum_time = voice_timer[i];
          ii = i;
      key_played_by[ii] = note_number;
      voice[ii].set_speed(note_number_to_pitch[note_number], velocity);
      voice[ii].set_adsr(attack_time, decay_time, sustain_value, release_time);
      voice[ii].play("FILENAME.RAW");
      voice_timer[ii] = millis();
    // stop note
    void release_voice(int note_number) {
      int i;
      for (i = 0; i < 4; i++) {
          voice[i].release_note();
    Nov 2016
    Rimini - Italy
    101
    Hi all,
    of course my code needs improvements. This part will be rewrited in a single reading (instead of f+g as now):
                file_offset += n;
                    block->data[i] = 0;
                    file_offset += n;
                        block->data[i] = 0;
    As soon as a new important function, set_pitch_bend, will work fine, I'll publish an updated version of my object.
    Bye!
    Nov 2016
    Rimini - Italy
    101
    hi all,
    I've introduced a pitch_bend function.
    Wishing that someone will help to improve the behave of the Expander object... there is a very light "click" each time pitch is changed, maybe due an approssimation at the beginning of the oversampling cycle. This is the code and an example:
    Header
     * THE SOFTWARE.
     * - set_note(speed_value, velocity_value) set speed (pitch) and velocity (in the MIDI sense).
     * - set_pitch_bend (pitch_bend_value) set the pitch bend value
    public:
    	Audio_expander_serialflash_raw(void) : AudioStream(0, NULL) { begin(); }
    	void begin(void);
    	void set_note(float speed_value, float velocity_value);
    	void stop(void);
    	bool isPlaying(void) { return playing; }
        void set_pitch_bend (float pitch_bend_value);
    private:
    	uint32_t file_size;
    	int16_t ride;
    	float velocity;	// 0 <= velocity <= 1.0
    	int64_t t, t_0; // *t is the computational time, must be within 2902 microseconds (period of update() when 128 samples are required)
    	float pitch_bend=1.0;
    	float bias_virtual_index=0;
    	float bias_virtual_index_0;
    	int32_t j_adsr;
    CPP file
     * THE SOFTWARE.
        last_value=0;
        playing = false;
        file_offset = 0;
        file_size = 0;
    void Audio_expander_serialflash_raw::set_note(float speed_value, float velocity_value)
        stop();
        j_adsr=0;
        if (!rawfile)
            return false;
        file_offset = 0;
        playing = true;
        return true;
        __disable_irq();
        if (playing)
            playing = false;
            __enable_irq();
            rawfile.close();
            __enable_irq();
        unsigned int i, n;
        int f, g, w;
        float Cx;
        if (!playing)
            return;
        block = allocate();
        if (block == NULL)
            return;
            // this first ride generate a linear ramp which connects the last sample sent to 0, which is (MUST be) the value of the first sample of the .RAW file to be played
            if (ride<0)
                Cx=last_value>>7;
            // from this point samples are taken from the .RAW file
            else if (ride>=0)
                last_index_to_read = ceil(((((ride+1)*AUDIO_BLOCK_SAMPLES)-1)*speed*pitch_bend) - bias_virtual_index) ;
                n = rawfile.read(samples_vector, samples_to_read<<1);
                file_offset += n;
                for (i = n>>1; i < samples_to_read; i++)
                    samples_vector[i] = 0;
                    virtual_index=(j*speed*pitch_bend)-bias_virtual_index; // index of the needed sample, usually not-integer
                    h = floor (virtual_index);// // index of the lower sample needed for calculation
                    if(start_release == 0 && j_adsr<J1) // attack procedure
                        gain = C1*j_adsr;
                    else if (start_release==0 && j_adsr<J2) // decay procedure
                        gain = (C2*(j_adsr-J1))+1.0;
                    else if (start_release==1 && j_adsr<J4) // release procedure
                        gain = (C3*(j_adsr-J3))+gain_0;
                    else if (start_release==1 && j_adsr>=J4) // stop player!
                        stop();
                    j_adsr ++;
                bias_virtual_index_0=last_index_to_read+1-virtual_index; //
            ride ++;
            transmit(block);
            rawfile.close();
            playing = false;
        release(block);
        return t;
        gain_0 = gain;
        J3 = (j_adsr/AUDIO_BLOCK_SAMPLES)*AUDIO_BLOCK_SAMPLES; // J3 = ride*AUDIO_BLOCK_SAMPLES;
        J4 = J3+DJ3_4;
        C3 = -gain_0/DJ3_4;
        start_release = 1;
        return playing;
    void Audio_expander_serialflash_raw::set_pitch_bend (float pitch_bend_value) // 0.5= half speed, 1.0= no change 2.0=double speed
        pitch_bend = ((pitch_bend_value>=0.1)? ((pitch_bend_value<=2.0)? pitch_bend_value : 2.0) : 0.1) ; // set pitch value within limits
        if (ride>0)
            bias_virtual_index=bias_virtual_index_0; // when pitch bend is set, ride is set to 0, but we re-start from the last virtual_index
        ride = 0;
    Arduino example
       MIDI Expander
       scheda: Teensy 3.6 + Audio Adaptor Board + W25Q128FV flash memory chip
    #define voices 4
    AudioMixer4              mixer1;
    int note_number;
    float velocity;
    int i;
    int u, w;
    float attack_time, decay_time, sustain_value, release_time, pitch_bend_value, pitch_bend_value_0;
    int pot_value[50][2];
        AudioMemory(40); // valore critico
        board.enable();
        board.volume(1.0);
        SPI.setMOSI(7);
        SPI.setMISO(12);
        SPI.setSCK(14);
            voice[i].set_adsr(0, 2, 1, 1);
            voice_timer[i] = 0;
        // conversion constants
        if (MIDI.read())
            case midi::NoteOn:
            case midi::NoteOff:
            case midi::PitchBend:
                // pitch_bend_value = ((MIDI.getData2() - 64) / 63.0) + 1.0;
                pitch_bend_value = (MIDI.getData2() / 127.0) + 0.496063;
                AudioNoInterrupts();
                    voice[i].set_pitch_bend(pitch_bend_value);
                AudioInterrupts();
            default:
        w++;
        if (w == 10000)
            Serial.println (u);
            u = 0;
            w = 0;
        attack_time = 2 * analogRead(34) / 1023.0;
    // play note
        int i;
        int ii = -1;
        for (i = 0; i < voices; i++)   // first test: if the same key is played we use the same voice
                ii = i;
        if (ii == -1) // second test choice: look for a voice not busy
                    ii = i;
        if (ii == -1) // last test: choose the voice playing for the longest time
            ii = 0;
                if (voice_timer[i] < minimum_time )   // final test choice: look for the voice playing for the longest time
                    ii = i;
        voice[ii].set_note(note_number_to_pitch[note_number], velocity);
    // stop note
        int i;
    Nov 2016
    Rimini - Italy
    101
    Hi all,
    I found the bug, as I supposed was in the setup of the oversampling cycle. Now set_pitch_bend seems working very good!
    The mistake is this:
    The new line is this:
            bias_virtual_index=bias_virtual_index_0 - (speed*pitch_bend); // when pitch bend is set, ride is set to 0, but we re-start from the last virtual_index
    Finally, this is the new file:
    CPP file
     * Please: send set_speed and set_adsr commands BEFORE sending play
        last_value=0;
        playing = false;
        file_offset = 0;
        file_size = 0;
        stop();
        j_adsr=0;
        if (!rawfile)
            return false;
        file_offset = 0;
        playing = true;
        return true;
        __disable_irq();
        if (playing)
            playing = false;
            __enable_irq();
            rawfile.close();
            __enable_irq();
        unsigned int i, n;
        int f, g, w;
        float Cx;
        if (!playing)
            return;
        block = allocate();
        if (block == NULL)
            return;
            if (ride<0)
                Cx=last_value>>7;
            else if (ride>=0)
                file_offset += n;
                        gain = C1*j_adsr;
                        stop();
                    j_adsr ++;
            ride ++;
            transmit(block);
            rawfile.close();
            playing = false;
        release(block);
        return t;
        gain_0 = gain;
        J4 = J3+DJ3_4;
        C3 = -gain_0/DJ3_4;
        start_release = 1;
        return playing;
        if (ride>0)
            bias_virtual_index=bias_virtual_index_0-speed*pitch_bend; // when pitch bend is set, ride is set to 0, and we re-start from the next virtual_index
        ride = 0;
    Next stage cominig (hopefully) is the normal/reverse reading with set_direction function... Let's see
    Nov 2016
    Rimini - Italy
    101
    new code (ready for next features)
    Hi all!
    this is the new version of my code, with few improvements, but more linear and thus ready for new features. Of course, it's always naive, redundant and so on... But works fine! I learned to use seek function; a bit late, one could say. Ok, I was a little bit shy before..
    Header:
     * THE SOFTWARE.
     * - play("filename.raw", speed_value, velocity_value) plays audio .RAW files from flash ROM memory chip with the required speed (pitch) and velocity (in the MIDI sense).
     * - set_ADSR(attack_time, decay_time, sustain_value, release_time) set ADSR envelope filter.
     * many samples have to be read from flash memory: it depends from "speed" value (high speeds require
    public:
    	void begin(void);
    	bool play(const char *filename, float speed_value, float velocity_value);
    	void stop(void);
            void set_ADSR(float attack_time, float decay_time, float sustain_value, float release_time);
    private:
        uint32_t file_size;
    	int32_t main_index=0;
        volatile uint32_t file_offset; // point the BYTE
        float file_sample_offset; // point the SAMPLE
        float base_file_sample_offset;
        int32_t j_adsr;
        int32_t samples_available;
        int8_t send_joint;
        int32_t J1, J2, J3, J4, DJ3_4; 	// indexes of samples
        int16_t last_value;  // values of samples
        const int8_t min_speed=0.01;
        const int8_t max_speed=7.0;
    CPP:
     * THE SOFTWARE.
        last_value=0;
        playing = false;
        file_offset = 0;
        file_size = 0;
    bool Audio_expander_serialflash_raw::play(const char *filename, float speed_value, float velocity_value)
        stop();
        if (!rawfile)
            return false;
        // file_size = rawfile.size();
        speed = ((speed_value>=min_speed)? ((speed_value<=max_speed)? speed_value : max_speed) : min_speed); // set speed value within strong limits
        file_size = rawfile.size() - (rawfile.size()%256);
        send_joint=1; //
        main_index=0;
        file_offset=0; // points to BYTE in .RAW file
        file_sample_offset=0.0; // points to SAMPLE in .RAW file
        samples_available= file_size*2;
        base_file_sample_offset=0;
        rawfile.seek(file_offset);
        j_adsr=0;
        playing = true;
        return true;
        __disable_irq();
        if (playing)
            playing = false;
            __enable_irq();
            rawfile.close();
            __enable_irq();
        int i;
        int n;
        int16_t samples_basket[AUDIO_BLOCK_SAMPLES*11]; // current vector of samples read from file
        int32_t LOW_sample, HIGH_sample;  // indexes of samples in RAW file
        int32_t L_sample, H_sample;  // indexes of samples in sample_basket
        float index_delta;
        int16_t x_index_delta; 	// mantissa of virtual_file_offset
        float Cx;
        float speed_bend;
        float basket_offset;
        if (!playing)
            return;
        block = allocate();
        if (block == NULL)
            return;
            if (send_joint==1)
                Cx = last_value/128.0;
                last_value=0;// last_value=block->data[127];
                send_joint=0;
            else if (file_offset<file_size)
                speed_bend=((pitch_bend<1)? speed*pitch_bend : ((speed<(0.5*max_speed))? speed*pitch_bend : speed));
                LOW_sample = floor((speed_bend*main_index)+base_file_sample_offset);
                HIGH_sample = ceil((speed_bend*(main_index+AUDIO_BLOCK_SAMPLES-1))+base_file_sample_offset);
                if (HIGH_sample>=samples_available)
                    stop();
                samples_to_read = HIGH_sample-LOW_sample+1;
                file_offset=LOW_sample<<1;
                n=rawfile.read(samples_basket, samples_to_read<<1);
                for (i=n/2; i < samples_to_read; i++)
                    samples_basket[i] = 0;
                    file_sample_offset=(speed_bend*main_index)+base_file_sample_offset; // index of the needed sample, usually not-integer
                    basket_offset=file_sample_offset-LOW_sample;
                    L_sample = floor(basket_offset);// // index of the lower sample needed for calculation
                    H_sample = ceil(basket_offset); // index of the upper sample needed for calculation
                    index_delta = basket_offset-L_sample;
                    //ADSR envelope filter uses the specific index j_adsr to be independent from main_index
                        gain = C1*j_adsr;
                        gain = (C2*(j_adsr-J1))+ 1.0;
                        gain = (C3*(j_adsr-J3)) + gain_0;
                        stop();
                    block->data[i]=gain*velocity*(samples_basket[L_sample] + ((x_index_delta*(samples_basket[H_sample]-samples_basket[L_sample]))>>10));
                    main_index ++;
                    j_adsr ++;
                transmit(block);
                main_index=0;
                file_offset=0;
                stop();
            rawfile.close();
            playing = false;
        release(block);
        return t;
    void Audio_expander_serialflash_raw::set_ADSR(float attack_time, float decay_time, float sustain_value, float release_time) // ***** set ADSR parameters. Times are in seconds. 0 <= sustain_value <= 1.0
        gain_0 = gain;
        J4 = J3+DJ3_4;
        C3 = -gain_0/DJ3_4;
        start_release = 1;
        return playing;
        if (playing)
            base_file_sample_offset=file_sample_offset + (speed*pitch_bend); // when pitch bend is set, re-start from the next virtual_file_sample_offset
            main_index=0;
    This is my Arduino code:
      Teensy MIDI Expander
      Board: Teensy 3.6 + Audio Adaptor Board + W25Q128FV flash memory chip
    #define voices 4
    AudioMixer4              mixer1;
    int note_number;
    float velocity;
    int i;
    int u, w;
    int file=0;
      board.enable();
      board.volume(1.0);
      SPI.setMOSI(7);
      SPI.setMISO(12);
      SPI.setSCK(14);
        voice[i].set_ADSR(0, 2, 1, 0.2);
        voice_timer[i] = 0;
      if (MIDI.read()) {
          case midi::NoteOn:
          case midi::NoteOff:
            AudioInterrupts();
          default:
      w++;
      if (w == 2000)
        Serial.println (u);
        u = 0;
        w = 0;
      if (read_pot(33, 1) == 1) {
        if (pot_value[33][1] <= 6)
          file = 0;
        else if (pot_value[33][1] <= 80)
          file = 1;
        else if (pot_value[33][1] <= 222)
          file = 2;
        else if (pot_value[33][1] <= 375)
          file = 3;
        else if (pot_value[33][1] <= 466)
          file = 4;
        else if (pot_value[33][1] <= 540)
          file = 5;
        else if (pot_value[33][1] <= 663)
          file = 6;
        else if (pot_value[33][1] <= 765)
          file = 7;
        else if (pot_value[33][1] <= 900)
          file = 8;
        else if (pot_value[33][1] <= 1016)
          file = 9;
          file = 10;
    // play note
      int i;
      int ii = -1;
          ii = i;
            ii = i;
        ii = 0;
            ii = i;
      voice[ii].set_ADSR(attack_time, decay_time, sustain_value, release_time);
      switch (file)
      case 0:
      voice[ii].play("CAMPANA.RAW", note_number_to_pitch[note_number], velocity);
      case 1:
      voice[ii].play("SNAREV3.RAW", note_number_to_pitch[note_number], velocity);
      case 2:
      voice[ii].play("WAVE.RAW", note_number_to_pitch[note_number], velocity);
      default:
      voice[ii].play("METALS~1.RAW", note_number_to_pitch[note_number], velocity);
    // stop note
      int i;
    // reading pots
    byte read_pot(byte pot, byte isteresi) {
      pot_value[pot][1] = analogRead(pot);
      if (abs(pot_value[pot][1] - pot_value[pot][0]) > isteresi) {
        pot_value[pot][0] = pot_value[pot][1];
        return 1;
      else {
        return 0;
    Thank you for your attention!
    Sandro
    Nov 2016
    Rimini - Italy
    101
    new code (semplification for update: function; bug fixed)
    Hi all:
    Header:
     * THE SOFTWARE.
    public:
    	void begin(void);
    	void stop(void);
    private:
        uint32_t file_size;
        int32_t j_adsr;
        int8_t send_joint;
    	const float Alpha = 1.0/44100.0;
    	float pitch_bend = 1.0;
    	const int8_t min_speed = 0.01;
    	const int8_t max_speed = 7.0;
    CPP file:
     * THE SOFTWARE.
        last_value = 0;
        playing = false;
        file_offset = 0;
        file_size = 0;
        stop();
        if (!rawfile)
            return false;
        speed = ((speed_value>=min_speed)? ((speed_value<=max_speed)? speed_value : max_speed) : min_speed); // set speed value within limits
        send_joint = 1; //
        file_offset = 0; // punta il BYTE
        file_sample_offset = 0.0; // punta in SAMPLE
        samples_available = file_size/2;
        base_file_sample_offset = 0;
        start_release = 0; // allows ADRS to start
        j_adsr=0;
        playing = true;
        return true;
        __disable_irq();
        if (playing)
            playing = false;
            __enable_irq();
            rawfile.close();
            __enable_irq();
        int i;
        int n;
        float index_delta;
        float Cx;
        float speed_bend;
        if (!playing)
            return;
        block = allocate();
        if (block == NULL)
            return;
            if (send_joint == 1)
                Cx = last_value/129.0;
                for (i=0; i<AUDIO_BLOCK_SAMPLES; i++)
                    block->data[i] = last_value-(Cx*(i+1));
                transmit(block);
                send_joint = 0;
                speed_bend = ((pitch_bend<1)? speed*pitch_bend : ((speed<(0.5*max_speed))? speed*pitch_bend : speed));
                LOW_sample = floor(base_file_sample_offset);
                HIGH_sample = ceil((speed_bend*(AUDIO_BLOCK_SAMPLES-1))+base_file_sample_offset);
                    stop();
                    file_sample_offset=base_file_sample_offset+(i*speed_bend); // index of the needed sample, usually not-integer
                    if(start_release==0 && j_adsr<J1) // attack procedure
                        gain = C1*j_adsr;
                        stop();
                    block->data[i] = gain*velocity*(samples_basket[L_sample] + ((x_index_delta*(samples_basket[H_sample]-samples_basket[L_sample]))>>10));
                    j_adsr ++;
                base_file_sample_offset = file_sample_offset+speed_bend;
                transmit(block);
                file_offset = 0;
                stop();
            rawfile.close();
            playing = false;
        release(block);
        return ((uint64_t)file_offset * B2M)>>32;
        return ((uint64_t)file_size * B2M)>>32;
        return t;
        attack_time = ((attack_time>0.05)? attack_time : 0);
        decay_time = ((decay_time>0.05)? decay_time : 0.05);
        gain_0 = gain;
        J4 = J3+DJ3_4;
        C3 = -gain_0/DJ3_4;
        start_release = 1;
        return playing;
    Arduino patch:
    SAME AS LAST POST
    Bye
    Sandro
    So I've been trying to get this working and have been unsuccessful. Is there a way to make this work from internal memory? I have my files encoded as .h files and they work fine when playing via AudioPlayMemory.
    Thanks!
    Nov 2016
    Rimini - Italy
    101
    Quote Originally Posted by SpeakingInTones View Post
    Thanks!
    Hi, I don't know AudioPlayMemory deeply, but I belive it's possible to do what you need. First you need a function which can fill samples_basket[] giving a "memory_offset" and "samples_to_read". If we refer to the case 16 bit PCM, 44100 Hz, the reading funcion in AudioPlayMemory is:
    case 0x81: // 16 bit PCM, 44100 Hz
    		for (i=0; i < AUDIO_BLOCK_SAMPLES; i += 2) {
    			tmp32 = *in++;
    			*out++ = (int16_t)(tmp32 & 65535);
    			*out++ = (int16_t)(tmp32 >> 16);
    		consumed = AUDIO_BLOCK_SAMPLES;
    So, I think that you could begin writing something like this in the update() of your new AudioPlayMemory_NEW function,
    	out = samples_basket;  // instead of "out = block->data;"
    		for (i=0; i < samples_to_read; i += 2) {   // instead of     for (i=0; i < AUDIO_BLOCK_SAMPLES; i += 2) {
    			tmp32 = *memory_offset ++; // instead of   tmp32 = *in++  Notice "memory_offset" is a pointer to the start point, declared in AudioPlayMemory_NEW.h (because it's needed by other functions in the object).
    		consumed = samples_to_read;  //  instead of     consumed = AUDIO_BLOCK_SAMPLES;
    Bye
    Feb 2014
    Colmar, France
    2,551
    Wouldn‘t it be more efficient to share your code on github and posting just one single link to the repository instead of copying/pasting multiple variants of your code here? With that, people would always get the most recent release.
    Nov 2016
    Rimini - Italy
    101
    Theremingenieur I agree! Few moths ago I tried using github, but I felt frustrated that I was not able to use README.md in a decent way. I should read some tutorial first.
    Feb 2014
    Colmar, France
    2,551
    Ok.. so what I think you're saying is to:
    1: create a NEW play_memory.cpp file. (for example: play_memory_pitched.cpp)
    2: Keep everything the same except the changes you have above and change the function's name itself within play_memory_pitched.cpp .
    3: create a play_memory_pitched.h file as well and change it to reference play_memory_pitched.cpp.
    4: also change the name of the function in play_memory_pitched.h as well.
    5: call this new function in my .ino file.
    is that right?
    Thanks!
    Nov 2016
    Rimini - Italy
    101
    is that right?
    Thanks!
    Yes . Also notice that my object works with .RAW audio files: I belive that some mods are required if you use other audio formats.
    Bye
    Nov 2016
    Rimini - Italy
    101
    Perfect italian! grazie :
    Feb 2014
    Colmar, France
    2,551
    Sono lieto di aiutarti, se possibile!
    So I have my new .cpp file where I've changed update as follows:
    void AudioPlayMemoryPitched::update(void)
    	const unsigned int *in;
    	int16_t *out;
    	uint32_t tmp32, consumed;
    	int16_t s0, s1, s2, s3, s4;
    	int i;
    	if (!playing) return;
    	block = allocate();
    	if (block == NULL) return;
    	//Serial.write('.');
    	//out = block->data;
    	in = next;
    	s0 = prior;
    	switch (playing) {
    	 /* everything other then 16bit 44100 hz commented out...*/
    	  default:
    		release(block);
    		playing = 0;
    		return;
    	prior = s0;
    	next = in;
    	if (length > consumed) {
    		length -= consumed;
    		playing = 0;
    	transmit(block);
    	release(block);
    and I have my new .h file:
    #ifndef play_memory_pitched_h_
    #define play_memory_pitched_h_
    #include "AudioStream.h"
    class AudioPlayMemoryPitched : public AudioStream {
    public:
    	AudioPlayMemoryPitched(void) : AudioStream(0, NULL), playing(0) { }
    	void play(const unsigned int *data);
    	void stop(void);
    private:
    	const unsigned int *next;
    	const unsigned int *beginning;
    	uint32_t length;
    	int16_t prior;
    	volatile uint8_t playing;
    But I don't see how you get the pitch change input over to the play/update function. I feel like I missed a step somewhere?
    Thanks so much for your help on this, btw.
    Nov 2016
    Rimini - Italy
    101
    Hi SpeakingInTones,
    looking at your .h file, I understand that your .cpp file (even if not fully published) is still missing many lines; modifying update() is the FIRST step, than you should merge/add my code (or part of it) in AudioPlayMemoryPitched in order to get what you need.
    Bye
    Sandro
    Quote Originally Posted by Sandro View Post
    Hi SpeakingInTones,
    Bye
    Sandro
    That makes a lot more sense. I'll take another whack at it later this week and update if I find anything.
    Nov 2015
    189
    Ciao, someone has ported this code for playSDWav?
    Nov 2016
    9
    Sounds really cool! Do you have a video available to show what it sounds like? I’ll need to order some parts soon
    Nov 2016
    Rimini - Italy
    101
    Quote Originally Posted by ybr View Post
    Hi, sorry I didn't do any video
    Jan 2017
    18
    -Ciao, someone has ported this code for playSDWav? -
    Hi, I think that Moo has done that? https://forum.pjrc.com/threads/44377...playback-speed
    https://www.youtube.com/watch?v=rEEJf7q9tRY
    Maybe you can check that out?
