Results 1 to 12 of 12
Thread: Teensy 3.5 Rover with Mavlink and APM Planner 2.0
    7,032
    Hi all,
    One of the things that I always wanted to give a try to is using Mavlink messaging to communicate to a base station as opposed to just dumping data to the serial monitor and later processing. I finally finished a demo project using Teensy 3.5 with Mavlink v1 messaging sending data to the APM Planner Ground Station. Took a while to get done but it works.
    Here is a brief description of the setup:
    The basic rover setup is a Axel Scropion RC Rock Crawler, with a Ublox M8N and a Adafruit BNO055 attitude sensor. A Teensy 3.5 is used as the controller to process Mavlink messages to and from APM Planner. A joystick is using to control the steering servo and ESC. Two batteries are used, one for the motor and one for the electronics. A set of 3dr Radios are used for communication between the base station and the rover.
ID:	14296Click image for larger version.
    A couple of things to note. The best way to get connected is to first connect APM Planner to the radio attached to the com port and then power up the Rover. You will see the connection established almost immediately. The next thing is to enable the joystick from the APM Planner menu. Then you will need to arm the system for the joystick messages to be sent.
    Source Code: https://github.com/mjs513/Mavlink-Rover-Teensy3.x
    You Tube Demo: https://www.youtube.com/watch?v=9sa0XhpODVo
    Hope this helps someone else interested in using mavlink. There are a couple of good references that I will post here once I get them together.
    Mike
    7,032
    @klimbo13. Based on your question it sounds like you have a APM or Pixhawk flight controller in you aircraft? It also sounds like you are using Ardupilot. If this is the case you might be better off posting on the ardupilot forum. You really didn't provide any info on what your hw or sw you are using.
    Oct 2020
    7
    Hi mjs513!
    I was wondering if you had any resources you could share that helped you get started with packets and Mavlink in general. In the past, I would send the raw sensor data from my drone to my ground station. However, I would like to send formal data packets like Mavlink that can be validated once received and tossed out if corrupt.
    I've watched videos and I've read a lot of articles, but I'm not really sure how to create telemetry data packets.
    Any help would be appreciated.
    Thanks.
    Mar 2016
    Portland, OR
    663
    It's a very small piece of code, but I wonder if this would help:
    https://gitlab.com/bolderflight/software/mavlink
    I wrapped a class around a few of the mavlink packets I use for our flight software to make it easier to use. I haven't documented it, but the code is commented. It should be an okay example of how to use mavlink.
    Little sidetrack: I'm kind of frustrated with how inefficient mavlink is - I don't use half the fields in the packets and everything is sent at full resolution when I could send compressed data just for a display (i.e. why send a full 4 bytes for pitch angle when I probably only need 0.1 degree resolution for driving the display? I could fit that in two bytes). So the display lags a little from when the vehicle is moved. Long term I want to understand how to define my own packets so I can make some that are a lot more efficient.
    Oct 2020
    7
    We meet again Brian!
    Thank you for the example. At what frequency are you able to transmit down to your ground station? How fast do you think you could transmit with your own data packet structure?
    I found out about Mavlink through the drone community but really I'm trying to develop a sound telemetry for model rockets. Either way, I haven't found any super helpful documentation for dummies yet.
    I know there are some libraries for arduino like Serial Transfer but I haven't experimented with it yet.
    7,032
    First nice job Brian on the Mavlink wrapper - have to look at it more if I get back to mavlink
    @mar to your question - not really sure what happened to the references I used but I do remember it was quite a bit of searching and following a basic example that some one else put together. But did go back to see if I could find some for you:
    Mavlink for Absolute Dummies
    Discussion DIYDrones
    Micro Air Vehicle Link (MAVLink) in a Nutshell: A Survey
    MAVLink Erle Robotics Gitbook
    Arduino Controlled Wifi Rover using MavLink Protocol
    - check the link to the code by clicking on show more.
    And of course alot of reading from the Mavlink site.
    Mar 2016
    Portland, OR
    663
    I send the heartbeat at 1 Hz, the GNSS data as I get new data from the receiver at 5 Hz, and the attitude, speed and heading, and battery voltage at 25 Hz.
    The packet sizes are:
    * Heartbeat: 9 bytes, includes information about the vehicle and autopilot
    * GPS: 52 bytes, includes position, fix type, number of satellites, and uncertainties (why?)
    * Attitude: 28 bytes, includes the 3 euler angles and 3 angular rates (Why? Who is looking at angular rate?)
    * HUD (airspeed and heading): 20 bytes, includes airspeed, ground speed, altitude, climb rate, heading, and throttle
    * Battery: 49 bytes, includes charge state and voltage
    So, I’m sending 21,552 bits/second and I’m using a baudrate of 57,600 on those cheap SiK 900 MHz radios.
    My approach was to look through the MAVLink message set (http://mavlink.io/en/messages/common.html) and find the messages that I was interested in sending. The MAVLink c library (https://github.com/mavlink/c_library_v2) will have a corresponding header file for each message. For example, mavlink_msg_attitude.h (https://github.com/mavlink/c_library...msg_attitude.h). Then I use the pack function provided in the header to pack the info into a mavlink_message_t and get the message length. I then use mavlink_msg_to_send_buffer to convert mavlink_message_t to a uint8_t buffer and send that over the serial port. An example of that process with the mavlink_msg_attitude is here: https://gitlab.com/bolderflight/soft...mavlink.cc#L32
    I’m interested in getting attitude (euler angles), speed, battery voltage, GPS position, GPS fix, and number of satellites. If I’m compressing data optimally, I can store pitch and roll in 11 bits (+/- 90 deg with 0.1 deg resolution) yaw in 12 bits (+/- 180 deg, 0.1 deg resolution), speed and battery voltage in 9 bits (0 – 45 m/s or volt range, 0.1 resolution), GPS latitude and longitude in 32 bits each, GPS altitude in 16 bits (altitude up to 6,000 m), GPS fix in 2 bits, and number of satellites in 6 bits (up to 64 satellites tracked). So, something around 18 bytes total to send all of the data.
    Packing data into bits can be annoying, so if I use a less optimal approach and pack each to the next higher byte boundary, then I’m storing attitude, speed, and battery voltage as uint16. GPS position as uint32, and a uint8 for fix and number of satellites. That’s easier to write code for and brings the message size up to 22 or 24 bytes depending on whether I encode altitude as a uint16 or uint32.
    I have some code to frame messages (https://github.com/bolderflight/framing). It uses 4 bytes of overhead to mark the start and end of the message and provide a checksum. My biggest hurdle is figuring out how to modify Q Ground Control or Mission Planner to use new packets.
    Mar 2016
    Portland, OR
    663
    I just thought I would add that looking at the bits/second isn't the best measure because they aren't spread evenly over the time interval. I'm running this on a control system running at 50 Hz. If we consider that all messages are sent on the first frame, then I'm sending 158 bytes (1264 bits), which will take .02194 seconds to send. My frame is 0.02 seconds long, so I'm trying to send my second set of telemetry data (this time it's 97 bytes, 776 bits, .0134 seconds) while the first frame is still being sent. So I could be a few frames delayed because of the way the packets stack, and that's before accounting for how the buffering is working on the ground station side and whether any re-sending is going on with the radios.
    7,032
    For comparison in the sketch I was using I have slightly different timing for messages: heartbeat = 1Hz (think this interval is fixed), AHRS (roll, pitch, yaw, rotation rates) every 100ms, GPS (lat, long, vel, alt, other data) every second.
    Pretty much did the same thing when I determing what messages to send back. I also looked at the source code QGroundControl and Mission Planner as well as search on DIYDrones - good resource.
    Good luck on that one. When I was rumaging around both there are alot of moving parts that you have to look at. Although I think there is only one function on receiving packets - way too long ago to remember at this point.
    Mar 2016
    Portland, OR
    663
    Thanks! It seems pretty daunting and I'm not sure if it'll be successful. Probably faster to just make another GCS from scratch.
    Mar 2016
    Portland, OR
    663
    FYI, I did a pretty major update to the MAVLink library:
    https://github.com/bolderflight/mavlink
    It now supports:
    1. The heartbeat protocol
    2. Sending status messages to the ground station
    3. Sending system, battery, IMU, GNSS, navigation filter, actuator, and inceptor telemetry to the ground station
    4. The parameter microservice
    5. Mission / flight plan, fence, and rally points
    It's written around our CMake build tooling. Hope to get an Arduino compatible version released, but in the mean time I hope this helps anyone implementing a MAVLink protocol.
    7,032
    Quote Originally Posted by brtaylor View Post
    It now supports:
    Very cool Brian. Eventually may get back to this one when other distractions settle down. Think you know how that goes
