Lightbluehue
Hi all,
I am having an audio output issue concerning clicks/pops/glitchiness in the audio.
The audio below is just the right channel (using each DAC as a mono channel), but it is doing the same with the left channel.
Occurs both through headphones on the audio shield and through USB audio (haven't tested the DACs yet, but last time I checked with an oscilloscope I could not see anything strange like this in the waveforms).
The problem seemed to start after I added 2 extra buttons & 4 extra pots, which I am pretty sure is more than in the examples.
#include <Bounce.h>
int i = 0;
int current_waveform = 0;
extern const int16_t myWaveform[256]; // defined in myWaveform.ino
float knob2;
float knob3;
float knob4;
float knob5;
float knob6;
float knob7;
float knob8;
float knob9;
float knob10;
float knob11;
float knob12;
float knob13;
float knob14;
float knob15;
float knob16;
float knob17;
float knob18;
float knob19;
float knob20;
float knob21;
float knob22;
float knob23;
float knob24;
float knob25;
float knob26;
float knob27;
float knob28;
float knob29;
Bounce button0 = Bounce(0, 15);
Bounce button1 = Bounce(1, 15); // 15 = 15 ms debounce time
Bounce button2 = Bounce(2, 15);
Bounce button3 = Bounce(3, 15);
Bounce button4 = Bounce(4, 15); // 15 = 15 ms debounce time
Bounce button5 = Bounce(5, 15);
Bounce button6 = Bounce(24, 15);
Bounce button7 = Bounce(25, 15);
AudioSynthWaveform waveform1; //xy=140,129
AudioSynthWaveform waveform2; //xy=170,392
AudioSynthWaveformSineModulated sine_fm2; //xy=214,452
AudioSynthWaveformSineModulated sine_fm1; //xy=219,187
AudioSynthWaveform waveform3; //xy=226,234
AudioSynthWaveformModulated waveformMod1; //xy=232,280
AudioSynthWaveform waveform4; //xy=235,498
AudioSynthWaveformModulated waveformMod2; //xy=260,544
AudioEffectEnvelope envelope1; //xy=414,294
AudioMixer4 mixer1; //xy=425,183
AudioEffectEnvelope envelope2; //xy=437,542
AudioMixer4 mixer3; //xy=444,464
AudioMixer4 mixer2; //xy=561,264
AudioMixer4 mixer4; //xy=564,524
//AudioOutputUSB usb; //xy=715,483
AudioOutputAnalogStereo dacs; //xy=721,387
AudioOutputI2S i2s1; //xy=721,431
AudioConnection patchCord1(waveform1, sine_fm1);
AudioConnection patchCord2(waveform1, 0, mixer1, 0);
AudioConnection patchCord3(waveform1, 0, waveformMod1, 0);
AudioConnection patchCord4(waveform2, sine_fm2);
AudioConnection patchCord5(waveform2, 0, mixer3, 0);
AudioConnection patchCord6(waveform2, 0, waveformMod2, 1);
AudioConnection patchCord7(sine_fm2, 0, mixer3, 2);
AudioConnection patchCord8(sine_fm1, 0, mixer1, 2);
AudioConnection patchCord9(waveform3, 0, mixer1, 1);
AudioConnection patchCord10(waveform3, 0, waveformMod1, 1);
AudioConnection patchCord11(waveformMod1, 0, mixer1, 3);
AudioConnection patchCord12(waveform4, 0, mixer3, 1);
AudioConnection patchCord13(waveform4, 0, waveformMod2, 0);
AudioConnection patchCord14(waveformMod2, 0, mixer3, 3);
AudioConnection patchCord15(envelope1, 0, mixer2, 1);
AudioConnection patchCord16(mixer1, 0, mixer2, 0);
AudioConnection patchCord17(mixer1, envelope1);
AudioConnection patchCord18(envelope2, 0, mixer4, 1);
AudioConnection patchCord19(mixer3, 0, mixer4, 0);
AudioConnection patchCord20(mixer3, envelope2);
AudioConnection patchCord21(mixer2, 0, dacs, 0);
AudioConnection patchCord22(mixer2, 0, i2s1, 0);
//AudioConnection patchCord23(mixer2, 0, usb, 0);
AudioConnection patchCord24(mixer4, 0, dacs, 1);
AudioConnection patchCord25(mixer4, 0, i2s1, 1);
//AudioConnection patchCord26(mixer4, 0, usb, 1);
//AudioControlSGTL5000 sgtl5000_1; //xy=424,110
// Configure both to use "myWaveform" for WAVEFORM_ARBITRARY
waveformMod1.arbitraryWaveform(myWaveform, 172.0);
current_waveform = WAVEFORM_TRIANGLE_VARIABLE;
waveformMod1.begin(current_waveform);
waveformMod2.arbitraryWaveform(myWaveform, 172.0);
waveformMod2.begin(current_waveform);
AudioMemory(20);
//sgtl5000_1.enable();
//sgtl5000_1.volume(0.32);
audioShield.enable();
audioShield.volume(0.25); //0.1?
dacs.analogReference(EXTERNAL); // = 3.3v / (INTERNAL) = 1.2v
pinMode(0, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(24, INPUT_PULLUP);
pinMode(25, INPUT_PULLUP);
//delay(300);
mixer1.gain(0, 0.75);
mixer1.gain(1, 0.0);
mixer1.gain(2, 0.0);
mixer1.gain(3, 0.0);
mixer2.gain(0, 0.15);
mixer2.gain(1, 0.0);
mixer2.gain(2, 0.0);
mixer2.gain(3, 0.0);
mixer3.gain(0, 0.75);
mixer3.gain(1, 0.0);
mixer3.gain(2, 0.0);
mixer3.gain(3, 0.0);
mixer4.gain(0, 0.15);
mixer4.gain(1, 0.0);
mixer4.gain(2, 0.0);
mixer4.gain(3, 0.0);
waveform1.begin(WAVEFORM_SAWTOOTH);
waveform1.amplitude(0.75);
waveform1.frequency(50);
waveform1.pulseWidth(0.15);
sine_fm1.frequency(440);
sine_fm1.amplitude(0.75);
waveform3.begin(WAVEFORM_SAWTOOTH);
waveform3.frequency(200);
waveform3.amplitude(0.75);
waveform3.pulseWidth(0.15);
envelope1.attack(10);
envelope1.hold(10);
envelope1.decay(25);
envelope1.sustain(0.4);
envelope1.release(70);
waveform2.begin(WAVEFORM_SAWTOOTH);
waveform2.amplitude(0.75);
waveform2.frequency(50);
waveform2.pulseWidth(0.15);
sine_fm2.frequency(440);
sine_fm2.amplitude(0.75);
waveform4.begin(WAVEFORM_SAWTOOTH);
waveform4.frequency(200);
waveform4.amplitude(0.75);
waveform4.pulseWidth(0.15);
envelope2.attack(10);
envelope2.hold(10);
envelope2.decay(25);
envelope2.sustain(0.4);
envelope2.release(70);
int waveform_type = WAVEFORM_SAWTOOTH;
int mixer1_setting = 0;
int mixer2_setting = 0;
int mixer3_setting = 0;
int mixer4_setting = 0;
elapsedMillis timeout = 0;
bool mixer2_envelope = false;
bool mixer4_envelope = false;
float mapf(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Serial.print(digitalRead(photoTransistor));
Serial.print (" - Time taken = ");
Serial.print (elapsedTime/1000000, 4); //for S
Serial.print ("s - ");
Serial.print(motorhz); //print revolutions per second or Hz. And print new line or enter.
Serial.print(" Hz - "); //print the word "Hz". */
knob2 = (float)analogRead(A2) / 1023.0;
knob3 = (float)analogRead(A3) / 1023.0;
knob4 = (float)analogRead(A6) / 1023.0;
knob5 = (float)analogRead(A2) / 1023.0;
knob6 = (float)analogRead(A3) / 1023.0;
knob7 = (float)analogRead(A6) / 1023.0;
knob8 = (float)analogRead(A2) / 1023.0;
knob9 = (float)analogRead(A3) / 1023.0;
knob10 = (float)analogRead(A6) / 1023.0;
knob11 = (float)analogRead(A7) / 1023.0;
knob12 = (float)analogRead(A2) / 1023.0;
knob13 = (float)analogRead(A3) / 1023.0;
knob14 = (float)analogRead(A6) / 1023.0;
knob15 = (float)analogRead(A7) / 1023.0;
knob16 = (float)analogRead(A16) / 1023.0;
knob17 = (float)analogRead(A17) / 1023.0;
knob18 = (float)analogRead(A18) / 1023.0;
knob19 = (float)analogRead(A16) / 1023.0;
knob20 = (float)analogRead(A17) / 1023.0;
knob21 = (float)analogRead(A18) / 1023.0;
knob22 = (float)analogRead(A16) / 1023.0;
knob23 = (float)analogRead(A17) / 1023.0;
knob24 = (float)analogRead(A18) / 1023.0;
knob25 = (float)analogRead(A20) / 1023.0;
knob26 = (float)analogRead(A16) / 1023.0;
knob27 = (float)analogRead(A17) / 1023.0;
knob28 = (float)analogRead(A18) / 1023.0;
knob29 = (float)analogRead(A20) / 1023.0;
button0.update();
button1.update();
button2.update();
button3.update();
button4.update();
button5.update();
button6.update();
button7.update();
// Button 0 or 2 changes the waveform type
if (button6.fallingEdge()) { // change from button 2
switch (current_waveform) {
case WAVEFORM_SINE:
current_waveform = WAVEFORM_SAWTOOTH;
Serial.println("Sawtooth");
case WAVEFORM_SAWTOOTH:
current_waveform = WAVEFORM_SAWTOOTH_REVERSE;
Serial.println("Reverse Sawtooth");
case WAVEFORM_SAWTOOTH_REVERSE:
current_waveform = WAVEFORM_SQUARE;
Serial.println("Square");
case WAVEFORM_SQUARE:
current_waveform = WAVEFORM_TRIANGLE;
Serial.println("Triangle");
case WAVEFORM_TRIANGLE:
Serial.println("Variable Triangle");
case WAVEFORM_TRIANGLE_VARIABLE:
current_waveform = WAVEFORM_ARBITRARY;
Serial.println("Arbitary Waveform");
case WAVEFORM_ARBITRARY:
current_waveform = WAVEFORM_PULSE;
Serial.println("Pulse");
case WAVEFORM_PULSE:
current_waveform = WAVEFORM_SAMPLE_HOLD;
Serial.println("Sample & Hold");
case WAVEFORM_SAMPLE_HOLD:
current_waveform = WAVEFORM_SINE;
Serial.println("Sine");
if (button7.fallingEdge()) { // change from button 2
case WAVEFORM_SINE:
// Left changes the type of control waveform
if (button0.fallingEdge()) {
Serial.print("Control waveform 1: ");
if (waveform_type == WAVEFORM_SAWTOOTH) {
waveform_type = WAVEFORM_SINE;
} else if (waveform_type == WAVEFORM_SINE) {
waveform_type = WAVEFORM_SQUARE;
} else if (waveform_type == WAVEFORM_SQUARE) {
waveform_type = WAVEFORM_TRIANGLE;
} else if (waveform_type == WAVEFORM_TRIANGLE) {
waveform_type = WAVEFORM_PULSE;
} else if (waveform_type == WAVEFORM_PULSE) {
waveform1.begin(waveform_type);
waveform3.begin(waveform_type);
if (button3.fallingEdge()) {
Serial.print("Control waveform 2: ");
waveform2.begin(waveform_type);
waveform4.begin(waveform_type);
// middle button switch which source we hear from mixer1
if (button1.fallingEdge()) {
if (mixer1_setting == 0) {
Serial.println("Mixer1: VCO");
knob2 = mapf(knob2, 0.0, 1.0, 0.0, 0.001);
knob2 = constrain(knob2, 0.0, 0.001);
mixer1_setting = 1;
} else if (mixer1_setting == 1) {
mixer1.gain(0, 0.0);
mixer1.gain(1, 0.75);
Serial.println("Mixer1: LFO");
knob5 = mapf(knob5, 0.0, 1.0, 0.001, 1.0);
knob5 = constrain(knob5, 0.001, 1.0);
mixer1_setting = 2;
} else if (mixer1_setting == 2) {
mixer1.gain(2, 0.75);
Serial.println("Mixer1: FM");
mixer1_setting = 3;
} else if (mixer1_setting == 3) {
mixer1.gain(3, 0.75);
Serial.println("Mixer1: Modulation Mode");
mixer1_setting = 0;
if (button4.fallingEdge()) {
if (mixer3_setting == 0) {
Serial.println("Mixer3: VCO");
knob16 = mapf(knob16, 0.0, 1.0, 0.0, 0.001);
knob16 = constrain(knob16, 0.0, 0.001);
mixer3_setting = 1;
} else if (mixer3_setting == 1) {
mixer3.gain(0, 0.0);
mixer3.gain(1, 0.75);
Serial.println("Mixer3: LFO");
knob19 = mapf(knob19, 0.0, 1.0, 0.001, 1.0);
knob19 = constrain(knob19, 0.001, 1.0);
mixer3_setting = 2;
} else if (mixer3_setting == 2) {
mixer3.gain(2, 0.75);
Serial.println("Mixer3: FM");
mixer3_setting = 3;
} else if (mixer3_setting == 3) {
mixer3.gain(3, 0.75);
Serial.println("Mixer3: Modulation Mode");
mixer3_setting = 0;
// Right button activates the envelope
if (button2.fallingEdge()) {
mixer2.gain(0, 0.0);
mixer2.gain(1, 1.0);
mixer2_envelope = true;
timeout = 0;
envelope1.noteOn();
if (button2.risingEdge()) {
envelope1.noteOff();
timeout = 0;
if (button5.fallingEdge()) {
mixer4.gain(0, 0.0);
mixer4.gain(1, 1.0);
mixer4_envelope = true;
timeout = 0;
envelope2.noteOn();
if (button5.risingEdge()) {
envelope2.noteOff();
timeout = 0;
// after 4 seconds of inactivity, go back to
// steady listening instead of the envelope
if (mixer2_envelope == true && timeout > 4000) {
if (mixer4_envelope == true && timeout > 4000) { //yo
// DAC0>>>>
waveform1.frequency(360 * knob2 + 0.25);
waveform1.amplitude(knob3);
waveform1.phase(360 * knob4);
waveform3.frequency(360 * knob5 + 0.25);
waveform1.amplitude(knob6);
waveform1.phase(360 * knob7);
waveform1.frequency(360 * knob8 + 0.25);
sine_fm1.frequency(knob9 * 1500 + 50);
waveform1.amplitude(knob10);
waveform1.phase(360 * knob11);
waveform1.frequency(360 * knob12 + 0.25);
waveformMod1.frequency(360 * knob13 + 0.25);
waveformMod1.frequencyModulation(2.0 * knob14 - 1);
waveform1.phase(360 * knob15);
//> constants
waveform1.amplitude(1.0);
waveform3.amplitude(1.0);
waveformMod1.amplitude(1.0);
waveform3.frequency(1.2);
//DAC1>>>>
waveform2.frequency(360 * knob16 + 0.25);
waveform2.amplitude(knob17);
waveform2.phase(360 * knob18);
waveform4.frequency(360 * knob19 + 0.25);
waveform2.amplitude(knob20);
waveform2.phase(360 * knob21);
waveform2.frequency(360 * knob22 + 0.25);
sine_fm2.frequency(knob23 * 1500 + 50); //
waveform2.amplitude(knob24);
waveform2.phase(360 * knob25);
waveform2.frequency(360 * knob26 + 0.25);
waveformMod2.frequency(360 * knob27 + 0.25);
waveformMod2.frequencyModulation(2.0 * knob28 - 1);
waveform2.phase(360 * knob29);
//> constants
waveform2.amplitude(1.0);
waveform4.amplitude(1.0);
waveformMod2.amplitude(1.0);
waveform4.frequency(1.2);
