Might help to know what you are interested in?
There is lots of generic information up on the web if you do a google query: How do bootloaders work
Now if you are wanting more specific information, on how it works on some specific board example one of the Teensy 3.x boards or LC or Teensy 2, it would help to know what board.
The basic ideas is, there is something that triggers the board to reboot. Often with boards who hook up using a Serial port, it is one of the other RS232 signals like DTR that changes.
Then once the board resets, the host will do some form of handshake, like send out some specific set of characters, within so long after the board resets. If the board detects this, it goes into a special mode, where the host downloads the program to the board, and the bootloader will store the new program in the appropriate place and once this is done, will reset the processor to run the new program...
But how each of these boards do it, depends on the board and... Many of the AVR based boards use a standard protocol and use a program: avrdude to do the uploading, often with these chips, the bootloader is stored on the processor itself, at a special part of memory, which the bootloader itself will not overwrite, however if you use an ICSP, it often will overwrite this portion of memory and you no longer have a bootloader. This is why in the Arduino IDE for many of these boards you have the command Burn Booloader which typically requires an ICSP to download the specific bootloader for that chip.
As for Teensy 3.x - There is a special chip on these boards that takes care of downloading new programs, which is not part of the actual processor....
