razataz327
Hi all I am planning to build a pixel mega tree with 20, 8 ft pixel strips ws2812b. They are 30 led per meter. I live in Alberta and we can get lots of snow 4 to 6 ft on the lawn. I want to put the tree on the roof, out of the snow and better visibility from the road. My questions are; what is the cold temp rating of the teensy 3.2, and how far can the output lines be from the teensy to the pixel strips?
Do I need to put it in an enclosed box with some heat as the temps can get to minus 40c here..
It appears I will need two teensy to run the tree. I wanted to add a mico sd card on the one teensy instead of connected to the pc. Will it work with multiple ones connected?
Thanks very much for your help.
Garnet
Garnet
