Results 1 to 12 of 12
Thread: Audio USB Out "hello world" program
    I'm trying to use the audio features of my Teensy 3.6 and to begin, I am trying to make the most basic program to output sound using the computer's speakers, because I haven't bought the teensy sound card.
    I used the design tool to connect one sine wave generator to both inputs of the USB output and pasted the code into Arduino editor. I have added some lines to make the onboard led blink and the code is here:
    AudioSynthWaveformSine   sine1;          //xy=350.1999969482422,248.1999969482422
    AudioOutputUSB           usb1;           //xy=541.2000122070312,254.20001220703125
    AudioConnection          patchCord1(sine1, 0, usb1, 0);
    AudioConnection          patchCord2(sine1, 0, usb1, 1);
    //used to blink the led to show that something is happening
    int led=13;
      sine1.frequency(140);
      sine1.amplitude(0.6);
      pinMode(led, OUTPUT);
      digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
       digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
      sine1.amplitude(0.0);
    And the led blinks, but no sound is output. What am I doing wrong?
    Before you ask I'm running windows 10, I have just updated my arduino program (1.8.5) and my Teenyduino (1.42). I have selected "Teensy 3.6", "Audio", "180MHz", "US english","Faster" in the Tools menu.
    Attached Files Attached Files
    Feb 2014
    Colmar, France
    2,183
    What about declaring some AudioMemory() ?
    "Without eating hay, the best horse can't fart" (Albanian proverb)
    Ok, I added
      AudioMemory(20);
    to the setup(), but still no sound!
    1,842
    Also before setup(), add AudioOutputI2S out1; // need one non-USB out or in to run
    see https://www.pjrc.com/teensy/gui/?info=AudioOutputUSB
    Mar 2018
    10
    Have you solved your issue? I'm using Teensy 3.2, and I found I can't make the teensy as a USB recording device.
    19,255
    You might also try File > Examples > Audio > HardwareTesting > WavFilePlayerUSB.
    Don't forget to edit the SD card defines for Teensy 3.6 builtin SD card.
    303
    This basic code will let you hear audio form dac and also L&R USB
    how are you listening to USB sound.....you might need to setup you PC to use the USB device for Audio instead of linein or mic etc
    I get a bit of clicking when I record the USB audio and play it back......for this simple code it just switches from one freq to next and does not worry about zero crossover....
    This is just uploaded into an bare teensy3.2 with amp speaker on dac and USB to PC .........
    EDITED ..... I had been recording on win10 pc with audacity 2.0 when getting clicks on playback etc. I have now installed latest Audacity 2.3 and it records and the playback is OK no clicks.
    //#include <SPI.h>
    //#include <SD.h>
    //#include <SerialFlash.h>
    AudioSynthWaveformSine   sine1;          //xy=244,163
    AudioOutputUSB           usb1;           //xy=557,160
    AudioOutputAnalog     dac1;
    AudioConnection          patchCord3(sine1, 0, dac1, 0);
     int freq = 100;
    sine1.frequency(freq);
    sine1.amplitude(0.7);
    AudioMemory(80);
    freq = freq + 100;
    if (freq >= 2000) freq = 100;
    Mar 2018
    10
    Thanks a lot. You code works on my Teensy 3.2. And my issue is caused by AudioMemory() which I used AudioMemory(20).
    This still doesn't work for me. I tried to change the sine function to a waveform, and the result is the same :
    //#include <SPI.h>
    //#include <SD.h>
    AudioSynthWaveform       waveform1;      //xy=378.20001220703125,246.20001220703125
    AudioOutputAnalog        dac1;           //xy=541.2000122070312,291.20001220703125
    AudioConnection          patchCord1(waveform1, 0, usb1, 0);
    AudioConnection          patchCord2(waveform1, 0, usb1, 1);
    AudioConnection          patchCord3(waveform1, dac1);
    int freq = 100;
    int led=13;
      AudioMemory(80);
      waveform1.frequency(freq);
      waveform1.amplitude(0.7);
      freq = freq + 100;
    I also checked the configuration of the sound of my computer and it all seems fine. Windows finds the Teensy, etc. but still no output.
    Feb 2014
    Colmar, France
    2,183
    As this code works for sure, you could first check with an oscilloscope on the DAC output if the Teensy is really producing an audio signal, at least on that output from which we might deduce a correct working USB output, too. Then, you should do a differential diagnose to test if your Windows PC does definitively play sound from USB. So, you need another USB audio source, i.e. a gaming headset with microphone to check. I'd guess that something in the Windows audio configuration (default audio device, usb audio input, windows mixer) is perhaps muted or disabled.
    Mar 2018
    10
    Hi. please try your teensy as a USB output device as Theremingenieur said. I think in this way you can confirm your board is OK or not.
    303
    My original idea of the simple basic sketch was to simplify it, and output audio to DAC and USB at same time. DAC is the most simple and direct from teensy.
    In order to hear DAC all that is needed is a small amplified speaker having line-in or Aux-in port. That will make sure the sketch is running and outputting to DAC....forget about USB until you get that working.
    Then with DAC working plug USB into your PC as see can you hear audio from PC while listening to DAC audio on small speaker.
    If you dont hear PC sound you will have to fiddle with the PC sound settings to get PC to be listening in to USB audio in and Playing out over either PC speakers or Lineout speakers, but listen to DAC audio at same time while setting up PC so you know the teensy sketch is still running.
