Results 1 to 4 of 4
Thread: Systick ISR
    Mar 2015
    UK
    261
    Systick ISR
    Can anyone point me to the Teensy 3.1 core folder/file where the systick_isr is defined? I have looked without success.
    Should I wish to replace it with my own version, how would I "undefine" the current routine before adding my own in a sketch? Or is this bad practice?
    8,814
    My editor shows me this:
    T:\arduino_1.8.5_142\hardware\teensy\avr\cores\teensy3\EventResponder.cpp:
      323
      324  // Long ago you could install your own systick interrupt handler by just
      325: // creating your own systick_isr() function.  No longer.  But if you
      326  // *really* want to commandeer systick, you can still do so by writing
      327  // your function into the RAM-based vector table.
      336
      337  extern "C" volatile uint32_t systick_millis_count;
      338: void systick_isr(void)
      339  {
      340  	systick_millis_count++;
    20,171
    _VectorsRam[15] = &myfunction;
    Feb 2014
    Colmar, France
    2,442
    ... at least until the systick_isr(void) will be declared as "weak" in one of the next Teensyduino releases, so that it could become easier to override it...
