Results 1 to 5 of 5
Thread: Custom FFT Frequency Range
    Aug 2018
    6
    I have a project where I have to measure the frequencies of a mechanical device at low audio frequencies, mostly below 1KHz. The Audio Library's FFT1024 and 256 are set for a 22KHz frequency range with about 43Hz between each freq bin. For my project, I need a resolution down to about 5Hz or so...
    With the help of a couple other posts from JBeale and Frank B. I was able to code a generic FFT with variable frequency range.
    I am using the Teensy 3.2 @ 72MHz
    Here is the code I am using:
    #include <SerialFlash.h>
    AudioInputAnalog         adc1;
    AudioAnalyzeFFT1024      myFFT;
    AudioConnection          patchCord1(adc1, myFFT);
    AudioSynthWaveform       waveform1;
    AudioOutputAnalog        dac1;
    AudioConnection          patchCord2(waveform1, dac1);
    void setDACFreq(int freq) {  // change sampling rate of internal ADC and DAC
    const unsigned config = PDB_SC_TRGSEL(15) | PDB_SC_PDBEN | PDB_SC_CONT | PDB_SC_PDBIE | PDB_SC_DMAEN;
        PDB0_SC = 0; //<--add this line
        PDB0_IDLY = 1;
        PDB0_MOD = round((float)F_BUS / freq ) - 1;
        PDB0_SC = config | PDB_SC_LDOK;
        PDB0_SC = config | PDB_SC_SWTRIG;
        PDB0_CH0C1 = 0x0101;
    const uint16_t dacOutputFreq = 500;//Hz - Test Frequency for FFT
    const uint16_t dacFreqMultiplier = 22;//If using FFT256 set to 44. This give the correct Output Frequency of the DAC
      AudioMemory(12);
      AudioNoInterrupts();
      setDACFreq(2000);//For a 1KHz Frequency FFT Span
      myFFT.windowFunction(AudioWindowHanning1024);
      AudioInterrupts();
      //Using DAC Output to Test FFT input on A2
      waveform1.begin(1.0,(dacOutputFreq * dacFreqMultiplier),WAVEFORM_SINE);
      if (myFFT.available()) {
        for(int i = 0; i < 511; i++)
          Serial.println((myFFT.read(i)*10),1);
        delay(200);//Delay if using SerialPlot for Visual Output
    In order to test the program, I am using the Teensy's onboard DAC set to a specific frequency, but can run at any test frequency by setting it in code.
    Basically, the DAC output on the Teensy is connected to the A2 pin.
    Since I am changing the frequency of the update rate on the DAC/ADC there has to be a multiplier for the DAC output frequency. See code comment.
    This test program works with either the FFT1024 or FFT256.
    Here is a screenshot of the FFT output (1024) in SerialPlot which works well with the Serial output of the Teensy.
Name:	Teensy FFT Example.png
    SerialPlot can be downloaded here:
    http://https://bitbucket.org/hyOzd/serialplot
    I hope this help with other FFT projects...
    Oct 2012
    Portland OR
    570
    Thanks, very useful! BTW the link you have for serialplot did not work for me but this does: https://bitbucket.org/hyOzd/serialplot
    Aug 2018
    6
    That's strange about my link not working, but as long as folks know about SerialPlot as it's great for working with the Teensy, especially in FFT mode.
    Oct 2012
    Portland OR
    570
    ah- it is because in your link there is no colon : between the https and the //
    Aug 2018
    6
    Doh, I see it's a type-o when I copied the link...
